Integrating Factor and Potential Function for Non-Exact Multi-Variable ODEs
4 replies · 3K views · last reply
sleventh
Hello All,
Given the equation (2/y + y/x)dx + (3y/x + 2)dy
I am first asked to show the equation is not exact. To do this I showed the mixed partials were not equal i.e.:
(2/y + y/x)dy != (3y/x + 2)dx
I am then asked to find an integrating factor and show the potential function is given by
f = x^2 + y^3 + xy^2
I have consulted my ODE's textbook but can not see how to apply the methods there to a multi-variable problem. I also haven't had much luck online.
Thank you for your help
sleventh said:
Hello All,
That isn't an equation; it is just an expression. Perhaps you want to set it = 0.
Try multiplying your equation by xy to clear the fractions. Also, since you are given a potential function, you could work backwards to see what to do.
thank for your reply LCKurts
I see how multiplying by xy allows for an exact equation (and i think it's assumed to equal zero) since the mixed partials are equal. But to be honest, I do not see how you solve for the integrating factor other then guess by experience nor do I see how to actually solve for f(x,y) once you have your integrating factor. Thank you for any help.
Well, multiplying by xy is a no-brainer to get rid of the fractions. Sometimes if an equation is not exact, you can find an integrating factor that is a pure function of x or y. If you are interested, I printed an article about that that you can read as post #2 in the thread:
https://www.physicsforums.com/showthread.php?t=342132
As to how to solve the equation once you have it exact, look at example 2 in
http://tutorial.math.lamar.edu/Classes/DE/Exact.aspx
for an easy to read example.
That example was incredibly helpful. I was overcomplicating but now see it is in the fact
Equation: d/dx of Psi(x, y(x)) equals 0, where Psi is a function of x and y(x), written in standard calculus notation.
can be written from
Equation: Ψ_x + Ψ_y dy/dx = 0, written with subscript partial derivatives of Ψ and a total derivative dy/dx.
looking at the single variable case i thought you had to use the e^int(p(x)) expression, but that is just a simple case used as example.
One last question i do not see how multiplying by a integrating factor allows for a general solution. Wouldn't you be changing your function by doing this?
  • Equation: d/dx of Ψ(x, y(x)) equals 0, where Ψ is a function of x and y(x) and the derivative is taken with respect to x.
