Integrating Factor Homework: y'+ (2/t)y = (cost)/(t^2), y(pi)=0
The discussion focuses on solving the differential equation y' + (2/t)y = (cos(t))/(t^2) with the initial condition y(pi) = 0. The correct integrating factor is determined to be μ(t) = t^2, not 2t, which is a common mistake due to misapplying the formula. The process involves multiplying the entire equation by the integrating factor to simplify it into a single derivative form. The integration of the resulting equation leads to the solution y = (sin t)/(t^2). Understanding the derivation of the integrating factor is emphasized as crucial for accurately solving such equations.
Bashyboy
y' + (2/t)y = (cost)/(t^2), and the following condition is given: y(pi) = 0
After employing the integrating factor, I find the solution to be:
y=e^{-2t} \int e^{2t} \frac{\cos(t)}{t^2} dt.
Evidently, this simplifies all the way to y = (sin t)/(t^2). I am not sure as to how this integral should be solved. Any hints would be much welcomed.
I think you should show all your steps, starting with exactly how you applied your integrating factor. Clearly, there's an error somewhere.
I see what I did wrong.
mu of t, the integrating factor, \mu (t) = e^{\int \frac{2}{t}}dt = e^{2 \ln t} = e^{2t}
Do you see where I went wrong? It should be \mu (t) = 2t
This is an example of what happens when you memorize formulas (imperfectly) rather than learning basic definitions and how the formulas are derived.
An "integrating factor" is a function, \mu(t) such that multiplying the equation by it converts the left side into a single derivative. Here, that means we must have \mu y'+ (2\mu/t)y= (\mu y)'. Expanding the derivative on the right that becomes \mu y'+ \mu' y= \mu y'+ (2\mu/t)y which reduces to \mu'= 2\mu/t, a separable differential equation for \mu. d\mu/\mu= 2dt/t integrates to ln(\mu)= 2ln(t) or \mu= t^2 NOT "2t" (I have neglected the "constant of integration since we only need a single function).
Multiplying the entire equation by t^2 gives t^2y'+ 2ty= (t^2y)'= cos(t) which is easy to integrate.
Likes riceking95
##e^{2 \ln t} = (e^{\ln t})^2 = t^2##, that's your integrating factor.
Your integrating factor is NOT ##2t##. ##2t## is in fact the derivative of your integrating factor, and you should be able to see this from applying product rule to ##yt^2##.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
