Integrating over the unit circle
The discussion focuses on the integration of analytic functions over the unit circle, specifically addressing the computation of the derivative of a function \( f(z) \) under the condition \( |f(z)| \le 1 \) for \( |z| = 1 \). The integral formula used is \( f'(z_0) = \frac{1}{2 \pi i} \int_C \frac{f(z)}{(s-z_0)^2} ds \), with \( z_0 = 0 \) leading to \( f'(0) = \int_C \frac{f(z)}{s^2} ds \). The discussion highlights the importance of correctly applying the modulus and understanding the behavior of \( |s^2| \) on the unit circle, concluding that \( |s^2| = 1 \) on this curve.
  • Understanding of complex analysis, specifically analytic functions
  • Familiarity with contour integration techniques
  • Knowledge of the properties of the unit circle in the complex plane
  • Proficiency in applying the Cauchy integral formula
  • Study the Cauchy integral formula and its applications in complex analysis
  • Explore the properties of analytic functions on the unit circle
  • Learn about the implications of the maximum modulus principle
  • Investigate the relationship between contour integrals and derivatives of analytic functions
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as educators looking to enhance their understanding of analytic functions and integration techniques.
Bashyboy
Suppose that the function ##f(z)## is analytic and that ##|f(z)| \le 1## for all ##|z| = 1##.
I was hoping someone could verify my work.
Okay, if I understand correctly, ##|f(z)| \le 1## is true for all all complex numbers ##z## on the unit circle. In my book we have a theorem which states that the derivative of ##f(z)## can be computed by calculating an integral; that is,
##f'(z_0) = \frac{1}{2 \pi i} \int_C \frac{f(z)}{(s-z_0)^2} ds##
In this particular case, ##z_0 = 0##, which gives us
##f'(0) = \int_C \frac{f(z)}{s^2} ds##
where we will integrate over the unit-circle. Taking the modulus of both sides,
##|f'(0)| = | \int_C \frac{f(z)}{s^2} ds|##
There is a theorem which states that ##|\int_C f(z) dz| \le \int_C |f(z)| dz##. Using this we get
##|f'(0)| \le \int_C |\frac{f(z)}{s^2} | ds \iff##
##|f'(0)| \le \int_C \frac{|f(z)|}{|s^2|} ds##
Because we are integrating over the unit circle, ##|f(z)| \le 1## over the unit circle; substituting this larger quantity in, we get
##|f'(0)| \le \int_C \frac{1}{|s^2|} ds##.
I am stopping here, because, as I write it, it no longer seems correct.
What happens to the differential dz when you take the absolute value inside the integral?
What happened to your pre factor of 1/(2πi)?
What is |s^2| on the unit circle?
hmmm...I am not sure...##|dz| = \sqrt{(dx)^2 +(dy)^2}##?
Ah! I always seem to neglect that portion.
##|s^2| = |s|^2## but ##|s| \le 1## so ##|s^2| \le 1##
Yes, you must take the absolute value also of the differential. I am assuming you are using z = x + iy here.
No, we are on the curve that is the unit circle, not in the unit disk (which is an area and not a curve).
Ah, of course. So ##|s^2|## would be ##1## on the unit circle.
Correct. Putting these pieces together, you should now be essentially done.
  • · Replies 17 ·
