Integrating \sqrt{x-x^2} using Trig Substitution
  • Thread starter Thread starter autodidude
    Integrate
5 replies · 18K views
autodidude
Integrate [tex]\sqrt{x-x^2}[/tex]
The attempt
I did a trig substitution, letting [tex]cos(\theta)=\frac{x}{sqrt(x)}[/tex] and after some manipulation ended up with [tex]-2\int \ |sin(\theta)cos(\theta)|sin(\theta)cos(\theta) d\theta[/tex] which I have no idea how to integrate.
If I make a u-substitution and let u=cos(theta) rather than simplify to get the above, I get [tex]2\int \ u\sqrt{u^2-u^4}du[/tex] which I can't make any progress on either.
The original integral must be over a range in [0, 1]. This means you can restrict theta to [0, pi/2], allowing you to drop the modulus function, leaving sin2cos2. Can you solve it from there?
The more common way to do a problem like this is to complete the square inside the radical then substitute. I think it goes a bit easier that way.
@haruspex: Yeah, I tried that and when I got the incorrect answer, I went back and saw that I overlooked the fact that you need to insert the modulus wheen rooting a square. Will try again in case I made an error though.
@Dick: Thanks, I'll see where I can get with that.
Like Dick said. Look at it like this try to reformulate it so you get something like this:
[tex]\int\sqrt{\frac{1}{4}-(x-}\frac{1}{2})^{2}dx[/tex]
and substitute u : [tex]u=x-\frac{1}{2};dx=du[/tex]
and see what you can get.
try factorizing out the x... then use a substitution sqrt x = something... simplifies things a lot!
