Integrating Sums (Laplace Transform)
The discussion centers on deriving the Laplace transform of an arbitrary nth degree polynomial using the formula \(\mathcal{L}\{t^n\} = \frac{n!}{s^{n+1}}\) for \(s > 0\). Participants clarify that the polynomial \(p(t) = a_0 + a_1 t + a_2 t^2 + ... + a_n t^n\) can be expressed as a sum, allowing the use of the linearity property of the Laplace transform. The final formula for the Laplace transform is established as \(\mathcal{L}[p(t)] = \sum_{i=0}^{n} a_i \frac{i!}{s^{i+1}}\), confirming that constants can be factored out during integration.
  • Understanding of Laplace transforms, specifically \(\mathcal{L}\{t^n\}\)
  • Familiarity with polynomial functions and their representations
  • Basic calculus concepts, including integration and limits
  • Knowledge of the linearity property of Laplace transforms
  • Study the properties of Laplace transforms, including linearity and time-shifting
  • Learn about the application of Laplace transforms in solving differential equations
  • Explore the concept of inverse Laplace transforms and their calculations
  • Investigate the use of Laplace transforms in control systems and signal processing
Students and professionals in engineering, mathematics, and physics who are working with differential equations, control systems, or signal analysis will benefit from this discussion.
rmiller70015
Using:
<br /> \mathcal{L}\big\{t^n\big\}=\frac{n!}{s^{n+1}}\text{for all s&gt;0}
Give a formula for the Laplace transform of an arbitrary nth degree polynomial
<br /> p(t)=a_0+a_1t^1+a_2t^2+...+a_nt^n
\mathcal{L}=\lim_{b\rightarrow\infty}\int_{0}^{b}p(t)e^{-st}dt
I figured that the function p(t) is a sum and can be expressed as:
\sum_{i=0}^{n}a_it^i
And integration gives:
\lim_{b\rightarrow\infty}\int_{0}^{b}\Bigg(\sum_{i=0}^{n}a_it^i\Bigg)e^{-st}dt
I'm not quite sure what to do next, I don't recall if I can move the integral and limit inside of the summation or not without being arrested by the math police for violating math laws.
rmiller70015 said:
Using:
For this problem, I don't see that this equation is actually relevant. You're supposed to use the equation given at the beginning of your post, in the problem statement.
In any case, what you wrote here is roughly the definition of the Laplace Transform. It should actually be written as
$$\mathcal{L}[p(t)]=\lim_{b\rightarrow\infty}\int_{0}^{b}p(t)e^{-st}dt$$
Again, use the equation at the top, not the definition. The only other thing you need is that ##\mathcal{L}[af(t)] = a\mathcal{L}[f(t)]##, where a is a constant. IOW, the Laplace transform of a constant times a function is the constant times the Laplace transform of a function. If you need to prove this, it's simple to do using the L.T. definition.
Likes rmiller70015
rmiller70015 said:
Using:
Of course you can: the sum has a finite number of terms, and the integral of a sum is the sum of the integrals---basic calculus 101. You can sometimes have problems with trying to interchange integration and summation, but only when the summations have infinitely many terms (i.e., are infinite series).
Likes rmiller70015
So then I pull out the a constants from the 3
That's the problem I was thinking I had to use the definition of a Laplace transform to answer this not just a table of transforms or in this case the one they gave us. If that's the case I just get:
a_n\frac{n!}{s^{n+1}}
No, that's not the answer. And I didn't suggest that you use a table of transforms. What I said was, use the equation you posted in your problem statement.
What I meant was in this part of the chapter the book likes to ask us to use the integral definition of a transform but on this problem they do not specifically ask that. Also I was too hasty when writing this I guess. What I wrote down on paper was \sum_{i=0}^{n}a_i\frac{i!}{s^{i+1}}
Edit: to n not infinity
But they specifically ask that you use the formula you wrote at the top.
Looks good.
Likes rmiller70015
  • · Replies 31 ·
