Integrating to Infinity Numerically
  • Context: Python
  • Thread starter Thread starter member 428835
    Infinity Integrating
6 replies · 7K views
member 428835
Hi PF!
I am trying to integrate functions over an infinite domain. One example is $$\int_0^\infty \frac{e^{-x}}{\sqrt{x}}\,dx$$ I know the substitution ##u = \sqrt{x}## reduces this problem to integrating ##\exp(-x^2)##, but if I want to integrate the function as is, how would I do this?
I've already tried Gauss-Legendre quadrature and Romberg integration. GL reports NaN and Romberg is evidently unable to handle the infinite limits.
Python:
import numpy as np
import scipy
import scipy.linalg# SciPy Linear Algebra Library
from matplotlib import pyplot as plt# plotting
from scipy import integrate
f = lambda x: np.exp(-x)/np.sqrt(x)# function to integrate
a = 0# lower bound
b = np.inf# upper bound
toler = 10e-3# tolerance
exact = 1.772453850# exact value of integral
# Romberg Integration
I = integrate.romberg(f, a, b, rtol=toler, show=True, divmax=25)
# Gauss-Legendre Quadrature Integration
deg = 1# degree of Legendre poly
gauss = 0# initial guess
while abs(exact-gauss) > toler:
    x, w = np.polynomial.legendre.leggauss(deg)
    # Translate x values from the interval [-1, 1] to [a, b]
    t = 0.5*(x + 1)*(b - a) + a
    gauss = sum(w * f(t)) * 0.5*(b - a)
    deg = deg + 1
print gauss
print deg
Right, because actually integrating from 0 to infinity would take an infinite amount of time. You should instead integrate to a very large number. The integral should converge very fast since this is a Gaussian integral; you won't have to go that far out to get a very good approximation. If you are conserned with just how accurate the numerical solution is, you should look up the error estimates for the numerical integration methods you are using. I think for Gaussian Quadrature, it goes something like
$$\Delta f(\eta_{n})=\frac{2^{2n+1}(n!)^{4}}{(2n+1)[(2n)!]^{3}}f^{(2n)}(\eta_{n})$$
Looking more closely at your code. It is not clear to me what is happening with the variables named t and gauss. They both have a term ##(b-a)## in them but since ##b=\infty## these values will also be infinity.
The book "Numerical Recipes" explains how to handle this type of improper integral. There are two "problems" for numerical integration: 1) the integrand blows up at ##x=0##; the region of integration is infinite. Separate the problems, i.e., write
$$I = \int_0^\infty \frac{e^{-x}}{\sqrt{x}}dx = \int_0^1 \frac{e^{-x}}{\sqrt{x}}dx + \int_1^\infty \frac{e^{-x}}{\sqrt{x}}dx = I_1 + I_2.$$
Since ##I_1## blows up like ##x^{-1/2}## as ##x## goes to zero, "Numerical Recipes" says to make the substitution ##x=u^2## in ##I_1##. Because the region of integration is infinite in ##I_2##, "Numerical Recipes" says to make the substitution ##u = e^{-x}## in ##I_2##. These substitutions easily give
$$I = 2 \int_0^1 e^{-u^2}du + \int_0^{1/e} \frac{du}{\sqrt{- \ln u}}.$$
It is easy to integrate numerically each of the integrals. As you say, the first substitution turns the whole question into the integral of a Gaussian, but the idea here is to illustrate techniques that can be used on improper integrals.
Thanks a lot everyone! I always find your advise very helpful!
