Integrating x^3 lnx dx - am i on the right track?
The discussion centers on the integration of the function x^3ln(x)dx. The initial approach using u-substitution with u = ln(x) is valid, leading to the expression e^(4u)udu. However, participants recommend switching to integration by parts as a more effective method. The integration by parts setup involves u = ln(x) and dv = x^3dx, ultimately yielding the integral Sx^3ln(x)dx = 1/4(x^4)ln(x) - 1/16x^4 + C. The importance of verifying the solution through differentiation is also emphasized.
  • Understanding of integration techniques, specifically integration by parts
  • Familiarity with u-substitution in integral calculus
  • Knowledge of differentiation and its application in verifying integrals
  • Basic algebraic manipulation skills
  • Study the method of integration by parts in detail
  • Practice u-substitution with various functions
  • Learn how to differentiate complex functions to verify integration results
  • Explore advanced integration techniques such as integration by parts with multiple iterations
Students and educators in calculus, particularly those focusing on integration techniques and verification methods. This discussion is beneficial for anyone looking to enhance their problem-solving skills in integral calculus.
drjohnsonn
integrating x^3lnxdx
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
substituting that, i got e^(4u)udu
then i let v = 4u
dv/du = 4
1/4du = dv
substituting that, i got 1/4integral e^v vdv
I haven't gone beyond that step yet. I was hoping someone more knowledgeable than I currently am could tell me if I am on the right track or let me know at what point I went wrong. Responses very much appreciated!
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
You're fine up to this point! Using u-substitution won't do anything helpful for you at this point; you are basically left trying to integrate the same problem. I would suggest integration by parts!
Hello drjohnsonn. Welcome to PF !
As scurty suggested, try integration by parts.
Thanks! I am quite a novice as of now and have not quite gotten to that point yet. I suppose I'll have to wait a bit before I finish working on this. But is the reason for having to integrate by parts that there is no general product integration rule?
Well, I immediately think integration by parts when I see a term that can be reduced by differentiating (u in this case) and a term that doesn't get "more complicated" by anti-differentiating (##e^{4u}## in this case). It's tough to explain, someone else might have a better general rule for when to integrate by parts.
Also, for what it's worth, you could have integrated by parts right from the start with no u-substitution. ##u = ln(x), \quad dv = x^3 \ dx##
Correct.
In fact integration by parts is based upon the product rule for differentiation.
Thanks for the advice!
Am I accurate in doing this:
u = lnx dv=x^3dx
du = 1/xdx v = Sx^3dx = x^4/4
and since Sudv = uv - Svdu
Sx^3lnxdx = 1/4(x^4)lnx - 1/4Sx^3dx = 1/4x^4lnx - 1/16x^4 + C
if i skipped something, point it out. i kind of ended up looking at the answer before i finished and hope that didn't fool me into incorrectly solving it
Looks good :smile:
There's an easy way to check: Differentiate. Differentiation is oftentimes far easier than integration (and the only time it isn't is when both are easy). Upon differentiation you should recover the original equation.
It's always a good idea to double check your work.
wootwoot
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
then i let v = 4u
dv/du = 4
1/4du = dv
Yes. I think you are on the right track. Now, you can do integration by parts again to get the answer.
  • · Replies 22 ·
