Integration problem using substitution
16 replies · 2K views
chwala
using ## u= sin 4x## find the exact value of ##∫ (cos^3 4x) dx##[/B]
## u= sin 4x## [/B]on integration ##u^2/2=-cos4x/4 ## , →##-2u^6={cos 4x}^3 ##...am i on the right track because now i end up with ##∫{{-2u^6}/{4.-2u^2}}du## or should i use
##du=4cos 4x dx ## to end up with ## 0.25 ∫ cos^24x du## which looks wrong to me
chwala said:
## u= sin 4x##
No, you've integrated one side wrt u and the other wrt x.
so should i use the second approach?
Yes, but you need to get all of the references to x turned into references to u.
You are asked for an exact value, but it is an indefinite integral. Remember that the limits need to be expressed in terms of u as well.
yes the limits are from 0 to π/24
is ## 0.25∫{cos^24x}du## correct?
So what are the limits on u?
Yes.
Yes.
limits on u are 0 to 30, now how do i proceed with the integration?
## cos^2 4x## = ##(cos 8x+1)##/2
should we substitute again? or are we going to have##0.25∫cos^24x d {sin4x} ##
Yes.
i am a bit confused we cannot integrate a variable say ##x## with respect to another variable say ##u##, i am stuck here
No.
You have the cos2 of some angle, and you need to express that in terms of u, the sine of the same angle. Does nothing click?
haruspex said:
No.
sorry limits are from 0 to 0.5 an oversight on my part...
haruspex said:
No.
i now get it lol
## 0.25∫{1-u^2}du ## from u=0 to u=0.5 thanks mate solution is ## 0.115##
Why don't you try splitting ##cos^34x## into ##cos4x## and another term containing the term used for ##u## substitution?
i have seen the obstacle with that move...
i have seen it, check post 13
@chwala
Actually that is the move you finally made to solve. Check the time of @Eclair_de_XII 's post and your posts.
