Integration U substitution then square it I think.
15 replies · 3K views
Zsmitty3
1. ∫ 1/(2√(x+3)+x)
2. Not sure if I'm beginging this correctly or not but I get stuck.
3. Let u= √x+3 then u2 = x+3 2udu=dx dx=2√[(x+3)
Therefore: ∫1/u2-3 Not sure where to go from here?
Ok what you did is good but take x from your u^2 you will get x=u^2-3. Then substitute it back into you integral and it should be simple from there.
So plug it into the original integral and get ∫1/(2√(u2-3+3) ?
So the 3's equal 0
Gives you: ∫1(2√u2)
Sqrt and 2 cancel leaving you 1/2u
but then that gives you 2u-1
integrating that gives you u0 which is where I keep getting stuck.
If I sub the other way and put x in for u^2-3 then that gives me 1/x. Integral of that is ln absvalue x. When I plug in numbers to make it a definite integral and check it on my calc. that doesn't work.
I didn't read the rest of this, but this is wrong. ##\int \frac{1}{u}du = \ln |u| + c## (c is the constant).
The rule ##\int u^n du = \frac{1}{n+1}u^{n+1} + c## only applies for ##n \neq -1##.
So you can pull out the 1/2 and make it .5∫(1/u)
The integral of that is .5(ln absvalue(u))
Sub u back in and get
.5(ln(√x+3)) abs value of √x+3 of course
that's still not giving me a right answer though when I check it.
So the 3's equal 0
Gives you: ∫1(2√u2)
No, you don't get 2u-1 .
[itex]\displaystyle \frac{1}{2\sqrt{x+3}+x}\[/itex] becomes [itex]\displaystyle \ \frac{1}{2u+u^2-3}\ .[/itex]
-1/u+ln(2u)-u/3 Just plug in √x+3 back in for u.
So that gives you -(1/√x+3)+ln(2√x+3)-(√x+3)/3) ?
It's not clear how you got that.
The integral [itex]\displaystyle \ \int \frac{dx}{2\sqrt{x+3}+x}\[/itex] becomes [itex]\displaystyle \ \int \frac{2u\,du}{u^2+2u-3}\ .[/itex]
Now use partial fractions.
You mean partial fraction decomposition or just split them up into separate fractions?
Can you make the u2+2u-3 = (u+3)(u-1)
Then A/(u+3) + B/(u-1) ?
So 2=A(u-1)+B(u+3)
Let u= 1
2=A(0)+B(4)
2=3B so B=(1/2)
Let u=-3 and A=-1/2
When you put those in can you just bring the 1/2's out in front of the fraction or do you have to distribute then through the bottom of the integral?
-1/2∫1/(u+3)+1/2∫1/(u-1)
ends up being 1/2* ln(√x+3)-1/√x+3)+3
Zsmitty3 said:
So 2=A(u-1)+B(u+3)
Let u= 1
2=A(0)+B(4)
2=3B so B=(1/2)
Let u=-3 and A=-1/2
Try to be more careful.
That should be:
2u = A(u-1) + B(u+3) .
