Integration using residu theorem
6 replies · 2K views · last reply
MaxManus
Solve
[tex]\int_{0}^{\infty} \frac{x^2}{(x^2+1)(x^2+4)} dx[/tex]
works here
http://www.codecogs.com/latex/eqneditor.php
using residues
Can I use residues here?
The contour intergral will be a quarter of a circle in the first quadrant and lines along the positive x- and y- axis of
[tex]\frac{z^2}{(z+i)(z-i)(x+2i)(z-2i)}[/tex]
But can I use Cauchy's Residue Theorem when I get divide by 0 in the contour? i and 2i is on the contour.
Would it help if I noticed that
[tex] \int_0^{\infty} \frac{x^2}{(x^2+1)(x^2+4)} \, \mathrm dx = \frac12 \int_{-\infty}^{\infty} \frac{x^2}{(x^2+1)(x^2+4)} \, \mathrm dx [/tex]
Thanks, that solved the problem
[tex]0.5*2*\pi*i*(res(i) + res(2i)) = \pi*i*(\frac{-1}{6i} +\frac{1}{3i}) = \frac{\pi}{6}[/tex]
Exactly, well done.
(Of course, you would still have to prove that the identity I stated is actually true, and describe which contour you will choose. :))
Thanks
The identity is true because f(x) = f(-x) so the integral from 0 to infinity is half the integral of f from -infinity to infinity.
I'm using the contour with a half circle in the first and second quadrant with center in (0,0) and radius i equal infinity and the contour along the x-axis from -infinity to infinity.
Ah, so you mean that you are calculating the limit of [itex]R \to \infty[/itex] of
[tex] \int_{-R}^R \frac{z^2}{(z^2+1)(z^2+4)} dz + \int_{C_R} \frac{z^2}{(z^2+1)(z^2+4)} dz[/tex]
where [itex]C_R: [0, \pi] \to \mathbf{C}, t \mapsto = R e^{i t}[/itex] is a half-circle of radius R.
And you claim that this is equal to the original integral, that is: the second part, which you added to close the contour, does not contribute.
Provided that you all did write this down, just didn't type it out, and proved the claim, I agree :-)
(Sorry for being so annoying :))
Yes
[tex] <br /> \int_0^{\infty} \frac{x^2}{(x^2+1)(x^2+4)} \, \mathrm dx = \frac12 \int_{-\infty}^{\infty} \frac{x^2}{(x^2+1)(x^2+4)} \, \mathrm dx <br /> [/tex] = [tex]0.5* \int_{C_1} \frac{z^2}{(z^2+1)(z^2+4)} dz - 0.5* \int_{C_2} \frac{z^2}{(z^2+1)(z^2+4)}[/tex]
where C_1 is the closed half circle with radius infinity and C_2 is the open half circle with radius infinity.
The C_1 integral is given by Cauchy's Residue Theorem and the C_2 integral is equal to zero.
Thanks for taking the time to help me
