Intensity of central maximum when width of single slit is doubled
The discussion revolves around the intensity of the central maximum in a single-slit diffraction pattern when the width of the slit is doubled. Participants explore the relationship between slit width, amplitude, and intensity, questioning the implications of these changes on the resulting diffraction pattern.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants express confusion about the relationship between slit width and intensity, with one participant suggesting that doubling the width should quadruple the intensity due to increased amplitude. Others question the definitions of terms used in the intensity equations and the implications of different interpretations of the variables involved.
There is an ongoing exploration of the definitions and relationships between the variables in the intensity equations. Some participants have offered insights into the implications of the equations, while others are seeking clarification on specific points, indicating a productive exchange of ideas without a clear consensus yet.
Participants reference specific equations and texts, highlighting potential discrepancies in interpretations. There is a focus on the distinction between incident intensity and the intensity at the center of the diffraction pattern, as well as the implications of assumptions made regarding the slit width and its effect on intensity.
songoku
Please see below
θ = λ / b
I ∝ ##A^2##
My answer is (D) but the correct answer is (B). I thought the intensity will be 4 times since the slit width is doubled and amplitude becomes twice. What is my mistake?
Thanks
Area of the slit is doubled. If pinhole, the area is enlarged 4 times as your speculation.
I'm inclined to agree with your reasoning and answer.
See equations 3.4.5 and 3.4.6 here: https://phys.libretexts.org/Courses/University_of_California_Davis/UCD:_Physics_9B__Waves_Sound_Optics_Thermodynamics_and_Fluids/03:_Physical_Optics/3.04:_Single-Slit_Diffraction
##I_0## = incident intensity.
Edit: This is a mistake. ##I_0## is not the incident intensity - so the rest of this post is wrong. See Post 5#. Apologies.
##x## = slit-width (note that '##a##' is used in the above link).
##\theta## = angle from principal axis.
Let ##\alpha = \frac {\pi x \sin\theta}{\lambda}##.
The intensity of slit’s diffraction pattern is given by ##I = I_0 [\frac {\sin \alpha}{\alpha}]^2##.
This can be written using the ‘sinc’ function as ##I = I_0~\text{sinc}^2 {\alpha}##.
For ##\theta = 0, \alpha= 0, \text{sinc}(\alpha) = \text{sinc}(0) = 1##. So the intensity at the central maximum (where ##\theta=0##) is equal to ##I_0##, which is independent of slit-width, ##x##.
This makes the answer to the original question ##I_0, \frac {\lambda}{2x}## which is not an option on the list.
Or have I made a mistake?
The ##I_0## in the formula is not the "incident intensity". That is, ##I_0## is not the intensity of the light that is incident on the slit. ##I_0## represents the intensity at the center of the central peak of the diffraction pattern. ##I_0## will depend on the slit width. I agree with @songoku and @vela that doubling the slit width doubles the amplitude of the light at the center of the central peak. Thus, ##I_0## will quadruple.
[Edit: This assumes that we are dealing with "Fraunhofer diffraction" so that the formula ##I = I_0 [\frac {\sin \alpha}{\alpha}]^2## is applicable. Otherwise, it gets much more complicated.]
Steve4Physics said:
There I found ALERT
Alert
It is important to understand that this expression compares the amplitude at various angles to the amplitude on the center line, equal (or approximately equal) distances from the slit. It does not provide a comparison of the amplitude of the light wave after passing through the slit to the amplitude of the plane wave before it enters the slit.
I wonder why the author do not or cannot use intensity of incident light ?
In seciton 61 of Classical Theory of Fields by Landau and Lifshitz
where I supose LHS of the last formula udI is a typo which should be dI. RHS is different by factor ##ak/\pi## from the web author's, where a is slit width and k is wavenumber of light. The intensity is proportional to slit width. Multiplication factor is, as an examle,
\frac{I_{max}}{I_{incident}}=\frac{2a}{\lambda}=\frac{0.05mm}{500nm}=100
anuttarasammyak said:
In seciton 61 of Classical Theory of Fields by Landau and Lifshitz... RHS is different by factor ##ak/\pi## from the web author's, where a is slit width and k is wavenumber of light. The intensity is proportional to slit width.
Landau and Lifshitz's formula for an infinitely long slit: $$dI = \frac {I_0}{\pi a k} \frac {\sin^2 ka\theta}{\theta^2} d \theta$$
The LHS of the equation, ##dI##, represents the "intensity of the diffracted light in angular range ##d \theta##". I believe this is to be interpreted as the energy per unit time that is diffracted into the angular range ##d\theta## by a unit length of the infinitely long slit. So, ##dI## has the dimensions of power per unit length of the slit.
Landau and Lifshitz (LL) define the symbol ##I_0## on the RHS as the "total intensity of the light incident on the slit". By dimensional analysis of the equation, you can check that ##I_0## has the same dimensions as ##dI##. So, I think ##I_0## must represent the total power incident on a unit length of the slit. If we let ##\mathscr{I}_0## denote the usual meaning of incident intensity as power per unit area incident on the slit, then ##I_0## in the LL equation is ##I_0 =\mathscr{I}_0 \, 2a##, where ##2a## is the width of the slit.
Thus, if we express the LL formula in terms of the incident intensity ##\mathscr{I}_0##, it reads $$dI = \frac {\mathscr{I}_0 \, 2a}{\pi a k} \frac {\sin^2 ka\theta}{\theta^2} d \theta =\frac {(2 a)^2 k \mathscr{I}_0 }{2\pi} \left( \frac {\sin ka\theta}{ka\theta}\right)^2 d \theta$$.
For ##\theta \rightarrow 0##, this gives $$dI = \frac {(2 a)^2 k}{2\pi} \mathscr{I}_0 \,d\theta$$ So, doubling the slit width ##2a## for fixed incident intensity ##\mathscr{I}_0##, will quadruple the intensity at the center of the central maximum. This is in agreement with other textbooks.
I could be wrong in my interpretation of the symbols in the LL equation. So, I welcome corrections.
Thanks. I have no other reference. Could you show me textbooks, free and online if possible.
Thanks.
\frac{dI}{I_0} = \frac {a k} {\pi}\frac {\sin^2 (ka\theta)}{(ka\theta)^2} d \theta=\frac {2a} {\lambda}\frac {\sin^2 (ka\theta)}{(ka\theta)^2} d \theta=\frac {1} {\pi}\frac {\sin^2 (ka\theta)}{(ka\theta)^2} d (ka\theta) This is an equation with no physical dimension. I wonder how your ##I_0 =\mathscr{I}_0 \, 2a## plays a role here. Say ak >> 1
\int \frac{dI}{I_0} = 1
Rearrange ##\int \frac{dI}{I_0} = 1## as $$I_0 = \int dI.$$ Using ##I_0 =\mathscr{I}_0 \, 2a##, this is$$\mathscr{I}_0 \, 2a = \int dI.$$ The LHS equals the total energy per second arriving at a unit length of the slit. The RHS is the total energy per second diffracted at all angles by a unit length of the slit. So, this just represents conservation of energy.
Your ##\mathscr{I}_0 ## has unit Watt/m^2 and ##I_0## has unit Watt/m. May I interprete that your ##I_0## includes large waste energy shuttered by wall because it has no condition on sideway ?
Yes, I defined ##\mathscr{I}_0## to be the intensity of the light (Watt/m^2) arriving at any point of the infinitely long slit. So, the amount of energy per second arriving within a unit length of the slit would be ##\mathscr{I}_0## times the width, ##2a##, of the slit: ##\mathscr{I}_0 \, 2a##. This has units Watt/m where the m refers to considering a unit length of the slit.
Yes. I interpret the Landau and Lifshitz symbol ##I_0## (Watt/m) as also representing the total energy per second arriving at a unit length of the slit. ##\mathscr{I}_0 \, 2a = I_0##.
I'm not sure what this means. Can you rephrase it? ##I_0## includes all of the energy that arrives at the empty space of a unit length of the slit. It does not include any energy arriving at the material wall surrounding the slit opening.
I agree with you. Let me say my understanding.
expresses distribution according to angle which is normalized to 1. We should multiply input energy ( per second per unit slit length) [watt/m] = 2a [m] * incident light energy (per second per unit area) [watt/m^2] whose dimension is same as ##E^2c##, to it to get the result we need, i.e. energy per slit unit length, per second, per unit angle. So the coefficient is proportional to (2a)^2/##\lambda##.
Re my post #2, Orange line area is double of Blue line area. Thanks.
Thank you very much for all the help and explanation annutarasammyak, vela, Steve4Physics, Tsny
  • · Replies 17 ·
