Interaction force, two dipoles
The discussion focuses on calculating the force between two dipoles in an electric field, specifically how to determine the factor by which the distance \( r \) must increase to reduce the net force by a factor of 64. The relevant formula for the force on a dipole \( p \) in an electric field \( E \) is given by \( F=(p\cdot\nabla)E \). The electric field of a dipole is expressed as \( E=\frac{p}{4\pi\epsilon{r^3}}(2\cos\theta\hat{\theta}+\sin\theta\hat{r}) \). The derived force equation is \( F_{(r,\theta)}=-3\frac{\cos\theta}{4\pi\epsilon{r^4}}(2p_\theta+p_r) \).
  • Understanding of dipole moments in physics
  • Familiarity with electric fields and forces
  • Knowledge of vector calculus, specifically the gradient operator
  • Basic principles of electrostatics, including Coulomb's law
  • Study the derivation of the electric field of a dipole
  • Learn about the implications of dipole alignment on force calculations
  • Explore the concept of force reduction in electrostatics
  • Investigate the mathematical techniques for manipulating vector fields
Students of physics, particularly those studying electromagnetism, as well as educators looking for practical examples of dipole interactions and force calculations.
mathman44
A dipole p is directed in the positive z direction at the origin.
The force on a dipole p in an electric field E is F=(p\cdot\nabla)E
If a second dipole is placed at (r, \theta), by what factor must r increase – in terms
of p, \theta and r – so that the net force between the two dipoles decreases by a factor of 64?
I don't know how to start this... any hints please? This isn't homework, just a practice test question.
Well, you have a situation where one dipole is exerting a force on another...you already know how to determine the force exerted on a dipole from an external electric field, so...what is the electric field of a dipole? What force does that field exert on a dipole a distance r away from it (do not assume that the dipoles are aligned)?
E=\frac{p}{4\pi\epsilon{r^3}}(2cos\theta\hat{\theta}+sin\theta\hat{r})
If I break p apart into p_r and p_\theta, dot it with del, then multiply by E, I get a mess of an answer.
This is what I got, by the way:
F_(r,\theta)=-3\frac{cos\theta}{4\pi\epsilon{r^4}}(2p_\theta+p_r)
Any help please?
  • · Replies 16 ·
