Interesting Linear Algebra Problem
4 replies · 2K views
Newtime
Let x=(1,0,0) y=(2,1,0) and z=(2,2,1) be column vectors in R3. Consider the set V={tx+sy+uz 0[tex]\leq[/tex]t,s,u[tex]\leq[/tex]1}. What does this look like specifically?
n/a
No work here, just a thinking problem, but I thought that the set V would fill the solid (a paralellapipid?) formed by the three vectors x,y, and z. Is this correct? Other than visualization, I suppose a reason for this would be that it is analagous to a similar problem in R2 in which the set vills the parallelogram formed by the two vectors. Thanks.
If the given vectors were linearly independent, set V would be a three-D region in space, but if they are linearly dependent V will be only a one- or two-dimensional subset of R3.
They are linearly independent. And I know they fill some space in R3 but the question was which space...as into describe it. So my best explanation is the vectors fill the paralellepiped formed by the three vectors. Isn't this correct?
Yes, you are visualizing it correctly.
Thanks, I figured I was but wanted to check with all the gurus here.
