I Interesting sound-making hydrogen-burning device
  • I
  • Thread starter Thread starter Spinnor
    Device Hydrogen
A video on the Wiki page for Hydrogen illustrates a metal enclosure filled with hydrogen gas, which, when ignited, produces sound and ultimately a bang. The flame's instability occurs as it burns above the resonant chamber's top hole, with the speed of sound in hydrogen being significantly higher than in air. As the flame pulses, it draws in air, reducing the hydrogen concentration until it falls below 75%, causing the sound frequency to decrease. When the critical air-hydrogen mixture is reached, the combustion becomes unstable, leading to an explosion. This phenomenon highlights the explosive potential of hydrogen when mixed with air under specific conditions.
Spinnor
There is an interesting video on the Wiki page for Hydrogen. A metal enclosure made of two funnels with a smaller hole at the top and a larger hole at the bottom is initially is filled with hydrogen gas. The covered holes are opened and the hydrogen escaping the top hole is lit. After a few seconds sound is produced. The pitch of the sound decreases and then there is a bang. Some interesting physics you might enjoy and puzzle over.
https://en.wikipedia.org/wiki/File:19._Експлозија_на_смеса_од_водород_и_воздух.webm
My guess.
The flame at the top is unstable as it burns above the resonant chamber top hole.
The speed of sound in H (1310 m/s) is about four times that in air, (343 m/s), (so MW H2 ≈ 1/42 that of air ?).
Each flame pulse, draws more air in from below, reducing H concentration until below 75% H. Sound frequency falls as air enters.
When the flash-point is reached, flame can enter the resonator, and consume the remaining 2H2 + O2 from the internal air.
Likes Spinnor and Lnewqban
Copied from that page and linked ones:
"Explosion of a hydrogen–air mixture. The bi-conical vessel is filled with hydrogen gas. The hydrogen is ignited and starts to burn, while air enters from the bottom, making an air–hydrogen mixture that is slowly air-enriched. When the critical composition is approached, the burning becomes unstable and produces a sound wave with a decreasing frequency (due to the oscillations of the air-enriching mixture). Once the critical composition is reached, the bang is inevitable."
"Explosive combustion of hydrogen. Escaping hydrogen is ignited, while the removal of the bottom cap allows air to enter. Eventually, the air mixes with the hydrogen inside the container, causing an explosion. A similar process occurs during a backdraft, with the introduction of oxygen and mixing with unburnt gases causing abrupt or even explosive combustion."
https://en.wikipedia.org/wiki/Backdraft
"At normal atmospheric pressure [the flammability limit] is 4% to 75%, based on the volume percent of hydrogen in oxygen it is 4% to 94%, while the limits of detonability of hydrogen in air are 18.3% to 59% by volume."
https://en.wikipedia.org/wiki/Hydrogen_safety
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
