Interference and diffraction of light
12 replies · 5K views · last reply
poohead
green light of wavelength 5000 A is incident normally on a grating, and the 2nd order image is diffracted 32 degrees from the normal. how many lines/cm are marked on the grating
A=10^-10 n= 2 degree= 32 d=? wavelength- 5000 A
the answer to the question is 5300 lines/cm
wavelength=d sin degree/ n
we tried to solve for d using the following above equation but came out with the wrong answer, need help please i am in a fatal situation here,
d is the distance between slits, not the number of slits per cm.
So then what would I do to get an answer with lines/cm
Given the spacing between lines, figure out how many fit into a centimeter.
I don't understand then what equation i am to use to solve for such
Here's an example: If d = 1/100 of a cm, how many lines are there per centimeter?
100? but you said that d is the distance between slits, not the number of slits per cm. so what am i trying to find for this situation?
poohead said:
100?
Right. If you can do this example, use similar reasoning to solve your problem.
That's true. You use d to calculate the number of slits per cm.
Your final answer will be the number of lines per cm. You start by finding d.
sorry I am still confused on how to get there, what would i possibly do with d?
Try this analogy: Along a path there is a tree every 1/4 mile. How many trees per mile?
Here "1/4 mile" plays the same role as "d".
there would be four, but so i solved for d and i get 1.81x10^-6, so now i convert that into cm?
Careful how you round off.
Yes, find d in cm.
