Interfering Photons: How Paul Dirac Explained the Double Slit Experiment
Photons do not couple with each other, yet they create an interference pattern in the double slit experiment, illustrating wave-particle duality. When photons are fired one at a time, they still produce a double slit pattern, but detecting which slit they pass through disrupts this pattern, resulting in a mixture of intensities instead. This phenomenon highlights the principle that measurement affects the system, aligning with Heisenberg's uncertainty principle. Understanding these concepts is crucial for grasping quantum mechanics, as emphasized in Feynman's lectures. The discussion underscores the importance of wave-particle duality in explaining quantum behavior.
cragar
If photon's cannot couple with other photons , then when we shoot photons through a double slit and we get an interference pattern , How are the photons interfering with the other photons , and if there is no such thing as half photon like the photon is either absorbed or it is not , then how is the localized energy of the photon interfering with the slit , Or if we shoot them one at a time will still get the inference pattern , To Quote Paul Dirac "The photon then interferes with itself " I hesitated to post this.
All matter exhibits both wavelike and particle-like properties, so one can't simply imagine firing a photon like one hits a golf ball. In fact, photons are one of the prime examples of wave-particle duality.
It's actually one of the central topics of quantum mechanics, and I suggest a textbook to completely get a grasp of it.
I think this thread is what you're looking for:
https://www.physicsforums.com/showthread.php?t=57528
you could try reading feynman lecture series vol 3, it explains the wave particle duality in the context of double slit experiment and how it leads to the Heisenberg's uncertainity principle...it is indeed the foundation of q mech...without Heisenberg's uncertainity quantum mechanics would be meaningless!
okay thanks for the answers , when we fire one photon at a time is it a double slit pattern or do we get a mixture of a single slit and double slit pattern .
You needn't have hesitated.
cragar said:
when we fire one photon at a time is it a double slit pattern[?]
Exactly, it is.
in a double slit set up, firing one photon at a time would lead to a double slit pattern..however if one tries to detect through which slit each photon passes one looses the double slit pattern...the resulting pattern in the latter case is mererly the addition of the intesities I1 and I2 from each of the slits. without the phase factor...this is the alternative statement to uncertainity principle...the very act of measurement disturbs the system and causes the uncertainity! reading feynamn will make it clearer !
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
