Intergrating a Differential Equation using the intergrating factor method
thomas49th
[tex]\frac{dy}{dx} + \frac{y}{2x} = -x^{\frac{1}{2}}[/tex]
[tex]yT =\int{QT}dx + C[/tex]
where T is the intergrating factor
T = [tex]e^{\int{P}dx[/tex]
and P is the co-efficient of y from the differential equations
well to find T we need to do:
[tex]e^{\int{\frac{1}{2x}}}dx[/tex]
[tex]e^{\frac{1}{2}\int{\frac{1}{x}}}dx[/tex]
[tex]e^{\frac{1}{2}ln|x|}[/tex]
[tex]= x^{\frac{1}{2}}[/tex]
so using [tex]yT =\int{QT}dx + C[/tex]
you get
[tex]yx^{\frac{1}{2}}= \int{x^{\frac{1}{2}x^-{\frac{1}{2}}}dx[/tex]
[tex]yx^{\frac{1}{2}}= \int{1}dx[/tex]
[tex]yx^{\frac{1}{2}}= x + c[/tex]
the answer in the back of the book says [tex]yx^{\frac{1}{2}} = \frac{1}{2}x^{2}[/tex]
Where have I gone wrong?
[tex]\frac{dy}{dx}-\left(-\frac{1}{2x}\right)y=-x^{\frac{1}{2}}[/tex]
Which makes your integrating factor [tex]x^\frac 1 2[/tex]
[tex]yx^\frac 1 2=-\int x^\frac 1 2 x^\frac 1 2dx=-\int xdx[/tex]
Watch your inputting.
[tex] yx^{\frac{1}{2}}= \int{x^{\frac{1}{2}}x^-{\frac{1}{2}}}dx[/tex]
woops. above is what is ment to say
[tex]x^{\frac{1}{2}}x^{-\frac{1}{2}}[/tex]
simplifies to 1 right?
[tex]x^{\frac{1}{2}}x^-{\frac{1}{2}}[/tex]
No! Is the negative with x^1/2 or with just the 1/2?
[tex] x^{\frac{1}{2}}x^{-\frac{1}{2}}[/tex]
is what i mean
is what i mean
I knew what you meant, but why would the negative be with the 1/2 making it [tex]x^{-\frac 1 2}[/tex]?
Isn't the right side [tex]-\int x^\frac 1 2dx[/tex] then multiplied by your integrating factor, [tex]-\int x^\frac 1 2x^\frac 1 2dx[/tex].
