tellmesomething
- 449
- 68
- Homework Statement
- Theres a typical potentiometer setup I had of a dc current source connected in series with a resistor across a metre bridge with a wire mounted on it. I attached the ends of the metre bridge with the battery through connecting wires of very low resistance.
If end A is connected to positive terminal of the dc current source and the negative terminal is connected to the resistor Which is connected to B, and I connect another wire from A, I put a secondary cell with positive terminal towards the end A and a resistor of 600kohms in series with it and connected a galvanometer in series and then connect the galvanometers other terminal with a jockey.
- Relevant Equations
- None
I was asked if the balancing length at which the galvanometer shows no deflection be affected by the internal resistance of the dc source. I am not sure why my answers incorrect my reasoning was yes if I had put a higher resistance then the voltage drop across the metre bridge would decrease, meaning the gradient V/L would also decrease so the if the balancing point was being found at say 50cm it would be found at a length greater than that now...
Why is this wrong?
Why is this wrong?
