Interpreting a scale factor vs. distance graph
The discussion revolves around interpreting a graph that relates scale factors and distances in a hypothetical universe, particularly in the context of Type Ia supernovae and cosmological measurements. Participants explore concepts such as redshift, the Hubble constant, and the implications of the graph for understanding the universe's structure and expansion.
  • Some participants discuss the meaning of the scale factor in the context of the graph and its implications for cosmology.
  • One participant suggests that the graph can be used to find the Hubble distance and Hubble constant, assuming the speed of light is the same in that universe.
  • Another participant mentions calculating redshift and velocities but expresses uncertainty about further interpretations.
  • There is a claim that the graph indicates a linear relationship between redshift and distance, referencing Hubble's observations.
  • Participants debate the interpretation of redshift, with one noting that it is not a general property of space but specific to objects at certain distances.
  • One participant raises a question about how to convert redshift to recession velocity, emphasizing the need to consider cosmological factors.
Participants express various interpretations and calculations related to the graph, but there is no consensus on the correct approach to deriving values or the implications of the findings. Multiple competing views remain regarding the interpretation of redshift and its relationship to distance.
Participants note the importance of unit consistency when calculating the Hubble constant and the need to consider the cosmological context when interpreting redshift values.
naushaan
TL;DR
Hi guys, I'm having trouble with interpreting scale-factor and distance graphs of Type 1a supernovae.
'Imagine that you live in a different universe, which may have a different cosmology to our own. You measure the distances to and redshifts of a large number of Type Ia supernovae, and you use the redshifts to calculate the scale-factor of the universe at the time when the supernova exploded. You get the following graph of distances and scale-factors.'
The question is asking to deduce as much as you can from the plot below:
Astronomy news on Phys.org
So what have you come up with so far?
What is the meaning of scale factor here?
From the graph you can find the Hubble distance and, if the speed of light is same for that universe, you can extract the Hubble constant for that universe. And by using Hubble constant you can find the Hubble Time. And that's all I guess
i've calculated redshift and velocities so far, but haven't really gotten far with the question otherwise
will do that! thank you
And are you going to tell us what you got for those things?
I guess you find the answer. I think that from the graph we can also assume that universe is homogenous and isotropic (?). But I am not sure ..
so for redshift i got 0.53, and from then i calculated the Hubble constant to be 7.6e24m/s. I am struggling with how to interpret these findings.
how would we know that?
you have missed an important bit off the end of that
Thats not quite right. First redshift value for what object ? Redshift is not some sort of a general property of space. You can find the corresponding redshift for an object, that has a distance d.
From the graph its clear that there's a linear relationship between ##z## and ##d##. This was what Hubble observed in 1920.
Here the y axis, velocity, is just ##cz## since ##z = v/c##. The x-axis represents the distance in parsecs.So the graph that you are given can be turned into Redshift vs Distance (##z## vs ##d##) graph. (You don't have to do that of course). And from that it can be turned into velocity vs distance graph which that is what Hubble did.
And you also know that, this linear relationship can be written as,
##cz = H_0d##
So from your graph we can find the value of the ##H_0/c## or the Hubble distance by turning the scale factor into redshift for 2 points and measuring the slope of the line that connects these two points.
Now, if we assume that ##c## is the same in this imaginary universe as well, we can find the ##H_0## (If we cannot assume that ##c## is the same, then the only information you can get is ##H_0/c##)
Do your calculations again. But be careful about the units. In your graph the distance is given as billion light years. However Hubble constant has units of ##kms^{-1}Mpc^{-1}##.
##cz = H_0d##
this makes so much sense, thank you very much!
I have looked at this question for some time. We are given redshift for SN1a. From that there is not a simple velocity calculation v=cz unless the SN1a is close by. Cosmology and the scale factor need to be taken into account. Does anyone have a simple way to go from redshift to recession velocity? Thanks.
14K
  • · Replies 27 ·
  • · Replies 23 ·
