Intersection of a circle and a sine curve
The discussion revolves around determining the number of intersection points between the sine function, \(y=\sin{x}\), and a circle defined by the equation \((x-a)^2 + (y-b)^2 = r^2\). Participants explore the complexity introduced by the trigonometric nature of the sine function in relation to the circle's parameters.
  • Participants discuss substituting the sine function into the circle's equation and express confusion regarding the resulting equation's degree. Some suggest visualizing the problem through graphing, while others question the implications of varying circle parameters on intersection points.
The conversation is ongoing, with various interpretations of the problem being explored. Some participants have provided graphical insights, while others are questioning the clarity and completeness of the problem statement. There is no explicit consensus on the number of intersections, and multiple perspectives are being considered.
Participants note that the problem may have ambiguities in its phrasing, particularly regarding the maximum number of intersections and the conditions under which they occur. The original problem is identified as a challenge from a high school textbook, which may influence the assumptions made by participants.
vcsharp2003
What is the maximum number of points at which a circle and the graph of ##y =\sin{x}## can intersect?
##y =\sin{x}##
##(x-a)^2 + (y-b)^2 = r^2##
The question is asking for the number of different solutions to the following two equations.
$$y=\sin{x}$$
$$(x-a)^2 + (y-b)^2 = r^2$$
Solving these is complex for me due to one of the equations being a trigonometric function. If I substitute y from the first equation into the second equation, I get the following.
$$(x-a)^2 + (\sin{x}-b)^2 = r^2$$
$$x^2-2ax+a^2 + \sin^{2}{x} -2b\sin{x} +b^2 = r^2$$
$$(x^2 + \sin^{2}{x})-2(ax+b\sin{x}) +(a^2 + b^2) = r^2$$
Normally an equation of degree 2 would have at most two different solutions, but even though the above equation is of degree 2 in ##x##, the introduction of ##\sin{x} ## probably means its not. I am stuck beyond this, so please help.
Can someone help me determine the number of different solutions?
I saw the answer at once without using any Math.
I suggest drawing a picture using different size circles.
If you are still stuck later today, say so and I will pass you another clue.
  • Love
I tried your recommendation on the desmos.com graphing calculator and I was always getting 2 points of intersection for various circles that I tried.
Below are three scenarios that I tried, and they all always intersect at two points. But logically, I cannot arrive at this conclusion of two points. Also, I can understand that if the circle has its center very distant above or below the x or y axis and having a small enough radius then such a circle would have no intersection points with the sine curve.
Now imagine a huge circle where the top is practically a straight line. Shift it down so that the top is practically on top of the X-axis. How many times can it intersect that sin wave?
FactChecker said:
[SPOILER="Now imagine a huge circle where the top is practically a straight line. Shift it down so that the top is practically on top of the X-axis. How many times can it intersect that sin wave?"
[/SPOILER]
If it's a straight line there would be many peaks of the sin wave that it would touch. If we take it further down so it is on the x-axis then also there would be many points on the sine curve that it would intersect.
Right. Is the problem statement complete and accurate?
Please give me the clue as I have tried your suggestion, but still I can't see the logic.
Yes, the problem seems accurate. It's a challenge problem in a high school text book.
You didn't try to move the circle. The problem statement doesn't forbid this.
Over the range of allowable a, b, r, parameters there is no maximum. It might be possible to determine (or bound) the number of intersections as a function of the parameters, but that is a much harder problem.
Sorry, you're correct. I didn't paste the original question at the start. The exact problem as it appears in the Math book is as below. From what I have gathered so far from all the replies is that the answer to this exact question is none of the given options since as the curvature of the circle decreases the number of intersections increases.
and
View attachment 363154and
Is anyone else appalled by the syntax of this question? Is (e) a correct answer? I cannot decide.
@vcsharp2003 What is the book and who publishes it ? Bring out the pitards!
I am reminded of Prof. Feynman's tale: https://rangevoting.org/FeynTexts.html
Until you mentioned it, I didn't notice that it was ambiguous. I took it as "given all possible circles, what is the maximum number of times any circle can intersect the sine function." So answer e would be my answer. (Maybe even this is ambiguous.)
Is there a way to ask it that leaves no room for ambiguity?
I'll give it a go...
What is the maximum number of times (##N## ) a circle* can intersect the graph of ##y=\sin x##?
a)##N \le 2## b) ##N\le 4## c)##N \le 6## d) ##N \le 8## e)##N \gt 16##
*It’s implicit that all possible values for the centre and radius of the circle are permissble.
Edit - corrections
  • Agree
I would say ""out of all possible circles, what is the maximum number of times any circle can intersect the sine function."
IMO, that makes it explicit that all circles are to be considered.
Its a Math book titled Mathematics 11 that is used in Grade 11 in schools of Ontario, Canada. The publisher is McGraw-Hill Ryerson and it has multiple authors from various school boards of Ontario, Canada.
You can see a full legal copy of it at the Internet Archive using the following link: https://archive.org/details/mcgrawhillryerso0000unse_d3o2, but to view the whole book you need to first register on their webiste and then click on the Borrow button. The challenge problem that I posted can be found on p 420.
It's tricky to state that problem unambiguously. I wouldn't be too hard on them for any ambiguity.
It seems that none of the options given in the challenge problem under post#13 is true.
I counted the number of intersections in post#10 to be greater than 16.
I also counted the number of intersections as 2 in post#3 .
In that case, shouldn't this challenge problem be wrong?
First off, sorry for becoming unavailable. My follow-on hint would have been to try b=r-1, r>10.
But regarding ambiguity - Here's how it was originally stated by the OP:
$$y=\sin{x}$$
I suppose you could interpret that as "find the function of a, b, and r that will the return number of solutions".
And that is certainly a tractable problem.
But even without knowing what the original verbatim test question and 5 optional answers were, I presumed that we were looking for a count and a maximum at that.
There were two reasons for this:
1) If a function was expected, the norm would be to explicitly request a function - unless the context for a function is very compelling.
2) "Different" can be also be interpreted in several ways - but it suggests looking for a maximum.
But once the verbatim test question and the 5 options have been provided, I see no ambiguity. There is no direct English-to-Math translation, but "can" generally implies what is possible - and in this case a maximum would imply a range from 0 to that maximum (all that "can" be).
Also, all of the optional answers talk about counts, not functions. None of the options allow for "12", so we are not being asked about all possible solutions - we are being asked about a subset.
Does the option "at most 8 times" mean that "8" plays a special role in this problem? If not, then selected subsets could yield answers of only 0, 1, 2, 3, and 4. But in those cases, "at most 4 times" would equally apply. So, the combination of "at most 4 times" and "at most 8 times" very strongly suggest that they are referring to a situation where the "4" or "8" are tied to the solution. There is, however, only one "more than" option (ie, "more than 16 times"), so the "16" does not need to be special.
It is only wrong if you assume the most trivial interpretation of the question. I would not do that.
Suppose you interpret the question to be: "Given a circle, what is the maximum number of intersections?".
Then you can be given a circle like ##x^2+(y+1000)^2=1##, with no intersections. I think that is too trivial to be the correct interpretation.
On the other hand, suppose you interpret the question to be: "Given all possible circles, what is the largest number of intersections that any of them have?"
Then e: More than 16 is the correct answer.
i still decry thae question.
More than 16 is a (not the!) correct answer. I think it unwise to include an example whose complications are almost entirely semantic (although this discussion, if engendered, would be educational to potential writers of textbooks. ) The math content rapidly becomes overwhelmed however.
I agree. But I don't think the authors realized the ambiguity, so I am not inclined to be very critical of them.
They are writing a textbook. It is their job to worry about clarity. A
nd where were the editors.....? I am very critical. More so because this example is purely of their own choosing
Proofreading a book is a tedious, endless, thankless, job. No matter how long and hard you try, some errors remain. IMO, there must be something demonic going on. ;-)
  • · Replies 23 ·
  • · Replies 19 ·
