Intuition behind Integration by parts
The discussion centers on the technique of integration by parts, which is the integral counterpart of the product rule in differentiation. It emphasizes that when solving for the integral ∫u(x)v'(x)dx, the choice of u and v should be based on which integral is easier to compute. The mathematical meaning of the differential element du is clarified, highlighting its significance in calculus as a representation of an infinitesimally small change in u. Understanding these concepts is crucial for effectively applying integration techniques.
  • Understanding of basic calculus concepts, including differentiation and integration.
  • Familiarity with the product rule in differentiation.
  • Knowledge of substitution methods in integration.
  • Concept of differential elements in calculus.
  • Study the derivation and applications of the integration by parts formula.
  • Learn about the method of substitution in integration.
  • Explore advanced integration techniques, such as trigonometric integrals.
  • Practice solving integrals using both integration by parts and substitution methods.
Students and educators in mathematics, particularly those studying calculus, as well as anyone seeking to deepen their understanding of integration techniques and their applications.
Polymath89
I have some problems understanding the intuition behind the integration by parts technique. I don't quite see why you solve for \int u(x)v\prime (x), instead of one of the other parts, what makes it easier to solve for that particular term?
And in general when working with integration techniques, does an expression like du have any mathematical meaning by itself or are those substitutions just used to make integration easier?
Integration by parts is essentially the integral counterpart of the product rule in differentiation.
If f(x) = u(x) * v(x), then f'(x) = u(x) * v'(x) + u'(x) * v(x)
If we integrate the equation above, we get
∫f'(x)dx = ∫(u(x) * v'(x) + u'(x) * v(x))dx
= ∫u(x) * v'(x) dx + ∫u'(x) * v(x)dx
Simplifying a bit, we get
f(x) = ∫u(x) * v'(x) dx + ∫u'(x) * v(x)dx
or
∫u(x) * v'(x) dx = f(x) - ∫u'(x) * v(x)dx = u(x)*v(x) - ∫u'(x) * v(x)dx
Notice that I solved for ∫u(x) * v'(x) dx. I could just as easily have solved for the other integral. So in answer to your question, it doesn't make any difference. The only criterion is that ∫u'(x) * v(x)dx should be easier to work with than the other integral.
Yes, it has meaning. When you use a substitution, say u = 3x2, then du is the differential of u. In this case, du = d/dx(3x2) * dx = 6x*dx.
In my experience, choose to be u the function with the simplest derivative. If you can choose a function like "2x" - make it u because when taking the integral of vdu, you want du to contribute little complexity to the integral.
As for your comment about the mathematical meaning of du, its understandable to have the feeling that it has no mathematical meaning because most people don't see the meaning until they are done learning calculus and are instead applying it.
It is a differential element of u. What does that mean? I think of it as "a piece of u so small that it can barely be said to exist at all."
Look at it this way - the derivative notation, dy/dx, is a slope. The reason why we are saying "differential element of y over a differential element of x" is because even though the rate of change of a function may not be constant, the differential elements are so small that we can take the rate of change "over the course of a differential element" as being constant because there is no room for variation. That's why for a function like x^2 it makes sense to say (dy/dx) = 6 at some point even though the rate of change of the function is continuously changing.
Thats was pretty helpful, thanks a lot guys.
  • · Replies 16 ·
  • · Replies 21 ·
