How to Compute Inverse Fourier Transform for a Specific Function
The discussion focuses on computing the Inverse Fourier Transform of the function \(\frac{\alpha^2}{2\pi}\exp\left(-\frac{1}{2} \alpha^2 C^2(K) \tau \omega^2\right)\). The correct result for the Inverse Fourier Transform is \(\frac{\alpha^2}{2\pi}\frac{1}{\sqrt{2 A}}\exp\left(\frac{t^2}{4A}\right)\) where \(A < 0\) is a critical condition. Participants clarified that a variable transformation can simplify the integral to a standard form, specifically \(\int e^{-x^2} dx\), which is essential for solving the problem accurately.
  • Understanding of Inverse Fourier Transforms
  • Familiarity with Gaussian integrals
  • Knowledge of complex exponentials
  • Basic calculus and integral transformation techniques
  • Study the properties of the Inverse Fourier Transform in detail
  • Learn about Gaussian integrals and their applications
  • Explore variable transformation techniques in integral calculus
  • Review the implications of complex numbers in Fourier analysis
Mathematicians, physicists, and engineers working with signal processing, particularly those involved in Fourier analysis and integral transforms.
mathy_girl
Hi all,
I'm having a bit trouble computing the Inverse Fourier Transform of the following:
\frac{\alpha}{2\pi}\exp\left(\frac{1}{2} \alpha^2 C^2(K) \tau \omega^2\right)
Here, C^2(K), \alpha and \tau can be assumed to be constant. Hence, we have an integral with respect to \omega.
Who can help me out?
So you want to find the inverse Fourier transform of
\frac{\alpha}{2\pi}\exp(A \omega^2)?
It should be:
\frac{\alpha}{2\pi}\frac{1}{\sqrt{-2 A}}\exp\left(\frac{t^2}{4A}\right)
It should be:
A < 0 is necessary.
One can do a suitable variable transform to get the integral in the form
∫e-x2 dx
with limits -∞ to +∞
which can be looked up in a standard table of integrals. I suspect the answer is what jpreed gave in post #2.
Whoops.. I just figured that there are two small mistakes in my first post, I would like to have the Inverse Fourier Transform of:
Here, note that \alpha is squared, and a minus sign is added in the argument of exp.
Don't know if that makes a lot of difference?
Not really. Just replace A with -A in all the responses.
mathman said:
A < 0 is necessary.
That would become
-A < 0​
or in other words
A > 0​
