Inverse Function for (e^x)/(e^x + 1): Steps and Example Solutions
13 replies · 3K views
physstudent1
Find the inverse:
y = (e^x)/(e^x + 1)
I switched x with y and solved for y but I ended up getting lne^y - lnx = lne^y +ln1 and then -lnx= ln1
on Phys.org
could you show your work?
and I think you split up e^x+1 to lne^y+ln1? you can't do that.
ohhh your right it should be
e^y = x(e^y+1)
then
lne^y = lnx + ln(e^y+1) but I'm still stuck from here
hm..ok take the ln(e^y+1) to the right side and simplify by combining the ln's
edit: whops meant take lne^y to the right side, lnx to the left and you should be able to simplify it
what is there to combine
so get -lnx = ln(e^y + 1) - lne^y
then -lnx = ln((e^ y +1)/e^y) ? this doesn't seem like it helped now I am back to where i started.
hm..no I multiplied by -1 on the RHS and LHS and got x=-lny but plugging that in I get y=1+y >.<
could you show the steps I'm not seeing it
wow did that wrong too >.>
my algebra is really bad right now for some reason...hm..try multiplying/dividing by [tex]\frac{e^{-x}}{e^{-x}}[/tex]
ok yes multiply/divide by that and you will find the inverse.
so do that by the original equation before i start trying to find the inverse ?
i got -ln(1/x -1) = y for the inverse would anyone agree ?
yes and try to get x^-x all by itself on the RHS or LHS so you don't have something like ln(e^x+1)=y
yep that's what I got, and you can check by plugging it in. also should be x=f(y).
