Inverse Function: Solving for y in 2(x-3)/y = 3
  • Thread starter Thread starter Nelo
    Inverse
7 replies · 2K views
Nelo
y = 3
___
2(x-3)
Ive tried several times, I can't get the steps down. They say use reverse bedmass, and I don't understand.
Here's what i did.
y= 3/2(x-3)
x= 3/2(y-3)
x= 3/2y-6
x+6=3/2y
x+6
___ = 3
Which is already wrong, as you can see. Can someone please tell me the step so i can stop being stuck on this for 2 hours? =)
"x= 3/2y-6"
You were correct up to here. If it helps, write parenthesis in the denominator.
x=[itex]\frac{3}{(2y-6)}[/itex]
What you did was just canceled out the 6 in the denominator which you cannot do. Our objective is to get y by itself. Do that by multiplying 2y-6 to both sides. That should get rid of the fraction and leave you with.
x(2y-6)=3
Try getting y by itself from here.
Ok...
x = 3 / (2y-6)
x(2y-6) 3
_______ = _____
(2y-6) (2y-6)
2xy-6x 3
______=_____
2y-6 2y-6
Pretty sure I am already wrong. .. .
When I mean multiply both sides you don't do it like this:
[itex]\frac{2y-6}{2y-6}[/itex] x=[itex]\frac{3}{2y-6}[/itex][itex]\frac{2y-6}{2y-6}[/itex]
[itex]\uparrow\uparrow\uparrow\uparrow[/itex] That is a no no.
You do it like this:
x([itex]\frac{2y-6}{1}[/itex])=[itex]\frac{3}{2y-6}[/itex]([itex]\frac{2y-6}{1}[/itex])
Notice how the (2y-6) in the right side would cancel out. That would leave us with this.
x(2y-6)=3
Remember this: If you do anything to one side, you MUST do it to the other side of the equation.
So... the x still factors into 2y-6 on both sides..? your eq would give 2xy-6x/x on the left side..
What do you mean "factors on both sides)? My equation would not leave you with a fraction (though the answer would be a fraction). Try distributing the x term to (2y-6). Then just solve for y.
*Update: I see what you did. No that is wrong. Remember your algebraic properties:
a*[itex]\frac{b}{c}[/itex]=[itex]\frac{ab}{c}[/itex]
So, i did it like this..
2x(y-3) = 3
2x*y -6x =3
2x*y = 6x+3
y= 6x+3 /2x
y= 3x +3/2x
The answer is 2/3x +3 , however. Why is the x on the bottom?
Starting from here:
"2xy = 6x+3"
We would divide 2x to get y by itself.
[itex]\frac{2xy}{2x}[/itex]=[itex]\frac{6x+3}{2x}[/itex]
I see you split the fraction on the right side to divide 6x/2x, however you forgot to cancel out the x. However you cannot divide 3/(2x), so that is why 2x is in the denominator. The answer would look like this.
y=[itex]\frac{3}{2x}[/itex]+3
I do not see how the right answer is: "2/3x +3" (assuming this is (2/(3x))+3) the 3 is supposed to be in the numerator and 2x is supposed to be in the denominator.
