Inverse functions and tangent lines
6 replies · 6K views
wuffle
2 problems, i solved both of them but I am not 100 % I am right
Find all points on the curve y=x-2cosx where the tangent line to the curve is parallel to the line y=x and write an equation of the tangent line at such point
Let f^-1 be the inverse of the one -to- one function f(x)=x^3+x.
Find (f^-1)'(10).
slope of tangent line=f'(of the point)
1st.
This seemed tricky and I did not figure it out till I had a good 11 hour sleep, what I did:
y=x , parallel lines have same slopes=>slope of tangent line is 1
y'=1+2sinx
1+2sinx=1
x=0+2pi*n
we found all points on the curve where tangent is parallel to y=x
lets find y coordinate
y=0-2cos(0)=-2
equation of tangent line
y+2=1(x-0)
y=x-2
2nd.
I think this has a twist in it but I can't find it :( , here's what I did
f^-1(x)=1/(f'(f^-1(x))
we need to find f^-1(10)
since we got f(x) its not hard to do so
10=x^3+x
x=2
f^-1(x)=1/(f'(2))
f'=3x^2+1
f^-1(x)=1/13
this is the answer?
Please check what I have written, I apologize for such a mess t.t
Problem #1:
You are missing some roots for the equation, [itex]\sin(x) = 0\,.[/itex] Look at the unit circle. For what angle(s) is y = 0 ?
Because you are missing some of the solutions, you are also missing at least one tangent line. Also, why is it that a single tangent line is sufficient for all the values of x that you did find?
Find (f^-1)'(10).
1st.
y'=1+2sinx
1+2sinx=1
x=0+2pi*n
Actually sin(x) = 0 for x = n*pi, not just multiples of 2pi.
y=0-2cos(0)=-2
No. This is just one of the points at which the tangent line has a slope of 1. Your problem statement says "write an equation of the tangent line at such point". It's not clear to me what this means.
y+2=1(x-0)
y=x-2
2nd.
10=x^3+x
x=2
f^-1(x)=1/(f'(2))
f'=3x^2+1
f^-1(x)=1/13
this is the answer?
Problem #2:
What you have done is correct.
For exponents and/or superscripts, use the Advanced message screen. (Click on "Go Advanced" below.)
Once on the advanced message screen, use the "X2" button above the message box.
Then you can write (f^-1)' (x)=1/(f '(f^-1(x)) as (f -1)' (x)=1/(f  '(f -1(x))
SammyS said:
Problem #1:
Yep, you are right, sinx=0, x=pi n , not 2pi n.
sinx=0
x=pi * n
for x=pi
y=pi+2
y-(pi+2)=1*(x-pi)
Well, it asks to write an equation of the tangent line, so I was thinking it was only 1, guess I was wrong.But can't I write infinitive amount of tangent lines?since of n?what do I do then?Do I also write for n =-1 ,+-2, +-3?
Prob. #1:
cos(±π) = -1
= cos(±3π) = cos(±5π) = cos(±7π) = ...
Also, the line y = x - 2, is tangent to y = f(x) at all points where x = 2πn, so you luck out. (You probably should show that this is the case.)
A different line is tangent to y = f(x) for x = odd multiples of π .
SammyS said:
Prob. #1:
cos(±π) = -1
Thanks a lot for your help!
