Investigating Crash Dynamics: Lexmark Indy Race Drivers
The discussion focuses on the physics of race car crashes, particularly in the context of the Lexmark Indy race. Key concepts include inertia, momentum, and the forces involved in high-speed collisions, emphasizing that inertia can lead to severe injuries during crashes due to the difficulty of stopping a moving body. The role of seatbelts is highlighted, as they help manage the transfer of momentum and prevent fatal impacts with the car's interior. Additionally, friction is compared to inertia, noting that it requires varying amounts of force to initiate and maintain motion. Understanding these dynamics is crucial for analyzing the safety and design of race cars.
Princess Raja
What impact does physics facts like momentum, friction, collision, forces, inertia and second collision have on race driver crashes.
Particular race: The Lexmark Indy.
Particular year: None
I can't seem to find a good crash and that's why I require assistance.
In high speed collisions, Inertia can often be fatal.
Inertia is an objects reluctance to change direction or alter it's motion. So it has direct connotations with Momentum. If you are moving in a care at 120mph, you are also moving at 120mph as observed by someone in an inertial frame of reference. In a crash, both the car AND you need to be stop. The car is totalled due to it's design (crumple zones and such), but you (a fleshy construct) will not be stopped until ALL of your momentum has been transferred. Your high inertia which is dependent on your mass and the speed at which you are moving will make this difficult and painful.
Now transfer of momentum requires a force. To get rid of your momentum a change in momentum (which is a force must be induced). So without a seatbelt you would crash into the windscreen, and due to Newton's 3rd Law, the windscreen would induce an equal and opposite force back on you. So you would be crushed to death.
It gets messy with the explanations when you start considering Kinetic energy also.
Thankyou, that makes sense :) but is friction like Inertia?
Friction is like inertia in that you need to overcome a higher resistance when changing or beginning acceleration, then after the object is in motion less force is required to keep it in.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
