IR LED and phototransistor switch for 12V DC motor
  • Thread starter Thread starter mac37m
    Ir Switch
2 replies · 4K views
mac37m
I'm building a small project and would like some assistance from you folks.
I have this motor 5rpm -12vdc and I'm using a Class 2 plug in transformer (input 12VDC 60Hz 23W - output 12VDC 1000mA) to power it up.
I would like to add a IR LED/Phototransistor between the two to act as a on off switch.
when a solid item goes between the LED and phototransistor it will stop or turn the motor off
and when it's clear it will turn on.
the distance of the IR LED/Phototransistor will be about two inches.
thanks in advance.
for a small application like this motor, you should invest in an arduinio. By doing this all you really have to worry about is a handful of line of code, and the usage of a NPN transistor, a flyback diode (to prevent current surge damaging electronic components when the motor stops)
if you go this way, this youtube video should help out:
http://www.youtube.com/watch?v=js4TK0U848I&feature=relmfu
