Iron core for Electrostatic coil
The discussion focuses on the use of 1018 steel for constructing an iron core in a Stubblefield coil. Participants emphasize the importance of using cold-rolled versus hot-rolled steel for optimal magnetic performance, specifically regarding magnetic collapse and retention. The conversation also highlights the significance of using laminated sheets to reduce eddy current losses in transformers. Additionally, the construction of the Stubblefield coil involves winding copper and steel wires together in a bifilar manner, with careful attention to insulation and layering.
  • Understanding of Stubblefield coil construction techniques
  • Knowledge of magnetic core materials, specifically 1018 steel
  • Familiarity with eddy current losses in transformers
  • Experience with winding techniques for electromagnetic coils
  • Research the differences between cold-rolled and hot-rolled steel for magnetic applications
  • Explore the principles of eddy current losses in laminated magnetic cores
  • Learn about the construction and operation of Stubblefield coils
  • Investigate the effects of moisture on the performance of dissimilar metal interactions in coils
Electronics enthusiasts, experimental physicists, and hobbyists interested in building and optimizing Stubblefield coils and other electromagnetic devices.
FSumm
I am just an electrician doing experimental work with a Stubblefield coil. From what I've read the most common steel is 1018. If Stubblefield used a common bolt I assume this would fall into the 1018 realm. Would the 1018 iron core be better cold rolled or hot rolled for the magnetic collapse as well as the least amount of magnetic retention? Should I use a different type of steel?
I have an unknown steel 4 inch 3/4" sample rod that I put on 2 magnetron toroidal magnets overnight. I then put it up against an old color monitor and it showed no magnetic field at all. I did the same with a galvanized iron wire and that does show a magnetic field.
Would this be a good test for iron cores or should an electromagnet be made to see if it retains the magnetic field? Thank you for any help!
WOW, my first question was going to be what is a "Stubblefield coil"? I Googled and came up with some "marginal" science applications.
The purpose of the steel is for a iron core? Many iron core transformers are "laminated" sheets, not solid. This reduces eddy current losses.
As far as the "iron" itself, perhaps a higher concentration is better? I'm not sure how hot rolled or cold rolled affects core performance? An interesting question that I'm sure transformer manufacturers know the answer to...
Here is a wiki link, sounds like "soft" iron is the way to go, I assume that means "low carbon":
http://en.wikipedia.org/wiki/Magnetic_core
Yes the 1018 steel has a large iron content and low carbon. I am just wondering about the hot or cold aspects and how their differing internal structures would affect the field collapse and if one has a greater degree of remanence.
Hello FSumm,
The Stubblefield Coil is a reality, and it appears to work although at this date, we are not very sure how.
You will need to wind 2 bare wires, a Copper wire, which must be insulated in cotton thread someway, and a bare steel wire.
Build a counter rotating wheel setup with 3 cotton reels on each disk, feed the copper wire through the axle, go and search for my machine on OU to give you some idea of what you need etc etc.
Wind both together wires in Bifilar, (2 together) very tightly, but be very careful you don't short them together.
Between EVERY layer of turns, place a cotton layer the full width of the turns with a bed sheet or pillow case.
Then continue the winds.
No one seems to know how many layers or total winds, to make up the coil.
It seems there is an interaction between the Iron and the Copper wires, when they are damp, too wet, reaction decays, too dry reactioon decays. The reaction is between dissimilar metals, the current/voltage builds up, then reaches a trip over to off threashold, the magnetic field collapses, the secondary coil (which I haven't discribed) absorbs the energy and produces power.
Thats it in a nutshell.
Now go to it and make your self powering Stubblefield Coil, once you see it running for months, powering a motor or light, then you will understand the enormious invention is in front of you.
Good luck with it.
Google "Lasersaber Stubblefield coil" to see his working and his youtube Parts 1 to 5 on how to build one. There I have answered all your questions :)
  • · Replies 43 ·
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 42 ·
