Is a 10.0 earthquake actually possible?
- Thread starter ElliotSmith
- Start date
- Tags
- Earthquake
56 replies · 18K views · last reply
- 19,385
- 15,623
- 12,022
That's the whole point, it is in increments, not a bunch of M10 events. There is no comparisonFactChecker said:It seems that the uplifting of the great mountain ranges like the Rockies, Alps, Andes, etc. would supply enough energy for magnitude 10 earthquakes if the techtonic plates got stuck enough to release energy in a single large earthquake. What would one call the processes that release such energy in small, continuous increments that prevent stresses to build to that extent?
and as stated several times, there just isn't a plate boundary capable of accumulating enough stress
to produce a M10. The friction on the fault surface is overcome before enough stress can accumulateD
ElliotSmith
- 167
- 104
A M10 is 5 times more powerful than the strongest quake on record, which was a 9.5 in San Francisco, which happened in 1906.
Homework Helper
- 9,651
- 4,867
This is exactly what I had in mind in my first post, #14. In my ignorance I expressed it as energy released in smaller earthquakes. My thought was that something (be it friction overcome, smaller quakes, or something else) would happen before an M 10 level of stress was reached.davenn said:That's the whole point, it is in increments, not a bunch of M10 events. There is no comparison
- 12,022
ElliotSmith said:A M10 is 5 times more powerful than the strongest quake on record, which was a 9.5 in San Francisco, which happened in 1906.
this is incorrect
The 1906 San Francisco quake was only around a 7.9
You really meant to say the Chilean quake of 1960 which was the Mw 9.5Dave
RonL
- 219
After reading through this article, I'm left wondering if there might be tremendous sized voids inside Earth's mantle, that if displaced in some way could allow major shifts in rock formations. Does anyone have ideas about this?
https://www.nationalgeographic.com/...ntains-taller-everest-lurk-deep-inside-earth/
- 19,385
- 15,623
Given the pressure, it's hard to see how "voids" of any significant size could be sustained.RonL said:After reading through this article, I'm left wondering if there might be tremendous sized voids inside Earth's mantle, that if displaced in some way could allow major shifts in rock formations. Does anyone have ideas about this?
DaveC426913
2025 Award
- 24,750
- 9,171
Indeed. The fact that Earth's interior is heterogenous (like: having interior mountains) doesn't mean these structures are rigid and surrounded by voids. They simply are embedded in other likewise very dense - but perhaps more pliable - media.phinds said:Given the pressure, it's hard to see how "voids" of any significant size could be sustained.
Instead of ice cubes in a tumbler, think crunchy peanut butter.
Mentor
- 4,789
- 3,854
Okay: re relieving pressure by making small quakes does NOT work to prevent bigger ones:
https://earthquake.usgs.gov/learn/topics/megaqk_facts_fantasy.php
PLEASE read the link before you post any more suppositions. Thank you.
Further ad hoc assertions will be moved the Earth's core.
Parts of this thread reminded me of why the USGS published this pop science version. Note 'facts and fantasy'
Have a nice day.
Have a nice day.
AndromedaRXJ
- 56
- 5
Ygggdrasil said:Thinking historically about the most powerful earthquake causing events on Earth, I found this:
source:https://blog.nationalgeographic.org/2010/03/04/asteroid-terminated-dinosaur-era-in-a-matter-of-days/
What about The Great Dying (Permian-Triassic extinction event)?
Mentor
- 4,789
- 3,854
End Permian extinction.
Long term massive volcanic eruptions in what is now Siberia which lasted for long periods:
https://samnoblemuseum.ou.edu/understanding-extinction/mass-extinctions/end-permian-extinction/
##CO_2## levels rose enormously: ocean and ambient surface temperatures soared. Temperatures would have been high enough to kill off almost all land and marine plants, algae, and phytoplankton. 95% percent of marine species died off.
No asteroid collisions to blame.
AndromedaRXJ
- 56
- 5
jim mcnamara said:End Permian extinction.
But were there 10.0 earthquakes during the Permian extinction?
Mentor
- 4,789
- 3,854
I do not know. Paging @Ophiolite he may know definitively one way or the other.
DaveC426913
2025 Award
- 24,750
- 9,171
How old is he?jim mcnamara said:...definitively...
Ophiolite
- 484
- 274
I'm not current on the consensus of probable cause of the Permian extinction. I lean to environmental changes related to continental distribution, shallow water extent, ocean currents, atmospheric composition (not just CO2) etc. , but not a bolide impact. However, it is an interesting question - I'll see what I can turn up.jim mcnamara said:I do not know. Paging @Ophiolite he may know definitively one way or the other.
I do recall giving CPR, unsuccessfully, to the last trilobite.DaveC426913 said:How old is he?![]()
Mentor
- 4,789
- 3,854
I think that the question reflects a little misunderstanding. For an M10 earthquake on a slip strike fault to happen, the fault would have extend almost all the way around the planet. No such fault is known to exist.
From
https://www.usgs.gov/faqs/can-megaq...s_science_products=0#qt-news_science_products
The scale is a logarithmic one, so each magnitude step is 10 times greter than the previous one. So an M11 would require a larger Earth than we have.
From
For a subduction fault zone the size would be smaller because the energy released (the M10 thing) is proportional to the surface where the faulting plates overlap. It still would be really unlikely.No, earthquakes of magnitude 10 or larger cannot happen. The magnitude of an earthquake is related to the length of the fault on which it occurs. That is, the longer the fault, the larger the earthquake. A fault is a break in the rocks that make up the Earth's crust, along which rocks on either side have moved past each other. No fault long enough to generate a magnitude 10 earthquake is known to exist, and if it did, it would extend around most of the planet.
The largest earthquake ever recorded was a magnitude 9.5 on May 22, 1960 in Chile on a fault that is almost 1,000 miles long…a “megaquake” in its own right.
- 12,022
jim mcnamara said:I think that the question reflects a little misunderstanding. For an M10 earthquake on a slip strike fault to happen, the fault would have extend almost all the way around the planet. No such fault is known to exist.
From
https://www.usgs.gov/faqs/can-megaq...s_science_products=0#qt-news_science_productsFor a subduction fault zone the size would be smaller because the energy released (the M10 thing) is proportional to the surface where the faulting plates overlap. It still would be really unlikely.
Yes, exactly, as I was trying to get across to readers way back in post #19
Mentor
- 4,789
- 3,854
Well, @davenn, I'm not sure our effort will work. We can try. But. Were are fighting:
This is about the San Andreas fault system:
https://www.imdb.com/title/tt3488056/ How many people have read the USGS site versus how many have seen movies like the above?
- 12,022
jim mcnamara said:I'm not sure our effort will work. We can try. But. Were are fighting:
uh huh, it's an uphill battle to get the truth out to the masses
Dave
Physics4Eva
- 13
- 8
As said by the following website, an earthquake of magnitude 10 would need a fault extending around most of the planet:
- 12,022
Physics4Eva said:As said by the following website, an earthquake of magnitude 10 would need a fault extending around most of the planet:
yes, as stated in previous posts
Physics4Eva
- 13
- 8
Sorry didn't look at any previous quotes LOLdavenn said:yes, as stated in previous posts![]()
Too many
