Is A.I. more than the sum of its parts?
  • Thread starter Thread starter webplodder
The discussion establishes that current AI systems, including large language models (LLMs) like ChatGPT, incorporate stochastic elements and nonlinear parameters, making their behavior complex but fundamentally deterministic. Examples such as the logistic map and Conway's Game of Life demonstrate how simple deterministic rules can produce unpredictable outcomes, highlighting that unpredictability does not imply non-determinism. The concept of artificial general intelligence (AGI) is identified as a future goal requiring advances in world models, common sense, embodied cognition, and possibly consciousness. The consensus is that while AI systems today are "dumb machines," dismissing their potential intelligence or emergent behaviors is a fallacy, though true consciousness or human-like understanding remains unachieved and speculative.
  • Understanding of Large Language Models (LLMs) and transformer architectures
  • Familiarity with stochastic processes and probabilistic sampling in AI
  • Knowledge of nonlinear dynamical systems and chaos theory (e.g., logistic map)
  • Basic neuroscience concepts related to neurons and brain function
  • Research artificial general intelligence (AGI) frameworks and challenges
  • Study embodied cognition theories and their implications for AI
  • Explore stochasticity in neural network training and inference methods
  • Investigate neuroscience findings on consciousness and neural diversity
This discussion benefits AI researchers, cognitive scientists, philosophers of mind, and developers interested in the theoretical limits of AI behavior, emergent properties in neural networks, and the intersection of neuroscience and artificial intelligence.
  • #301
DaveC426913 said:
For example, I am one who has been sort of assuming that we would first see something that behaved intelligently like a human behaves intelligently (for example able to carry on a conversation) before it would rise to the level of dangerous. I am now seeing that it does not need to have anything like what I might have of thought of as intelligence in order to get into up to some very serious shenanigans.
LLMs are carrying on conversations with people who trustingly provide very personal information.
DaveC426913 said:
One AI recently wiped some user's entire library of files accidentally (*citation needed). It didn't mean to; it simply had sufficient resources available to it (e.g. full edit/delete permissions) and insufficient (i.e. no) oversight.
I read that same? article. The AI was an open source agenic LLM now called Openclaw. The author of this model recomends to load the program on a virtual computer that does not have your files. Openclaw requires administrative permissions.
  • #302
javisot said:
Many hallucinations, after in-depth analysis, end up being categorized as simple errors that could be corrected, or even predicted
Interesting. I was not aware of that. Do you have a reference for that?
  • #303
jack action said:
The results of LLMs are based on very simple math (addition, multiplication, etc.) repeated billions of times. If you use exactly the same inputs, you get exactly the same results. Nothing that is humanely impossible to do, except for the time it would require to do these calculations. The complexity and length of the process may make it harder to follow, but there is no magic.
Not true, that is not always the time. LLMs have a parameter called Temperature, ranging from 0 to 2, with the most probable weight choices selected (deterministic) for 0 and becoming more random as the Temperature increases, which will lead, of course, to "hallucinations". In Chat mode, the default temperature is between 0.7 and 1.0. The Temperature can be set by the user in the LLM Tools or Playground.
Grinkle said:
I am now questioning if its productive (from the software developers sense) to call a hallucination a bug.
I'm thinking not. It could be the behavior that is necessary for inspiration and true creativity. Developers are trying to make LLMs default to a "I do not know" response if the models get to a point where hallucinations are more probable but they sometimes ignore this constraint.
Lets just call it machine intelligence at least for now and start using it. Like any tool learn to use it correctly and know its strengths and limlitations.
If GPT6 make a leap in capability this year like Gemini 3 did last year than LLMs may still have some capability of achieving AGI.
  • #304
As one does. :wink:
  • #305
For example,
https://arxiv.org/abs/2509.04664 , Why lenguage models hallucinate
Or, https://www.arxiv.org/pdf/2512.21577
https://arxiv.org/abs/2311.05232 , A Survey on Hallucination in Large Language Models: Principles, Taxonomy, Challenges, and Open Questions
https://arxiv.org/abs/2401.01313? , A Comprehensive Survey of Hallucination Mitigation Techniques in Large Language Models
https://www.nature.com/articles/s41586-024-07421-0 , Detecting hallucinations in large language models using semantic entropy (Nature)
https://arxiv.org/abs/2401.07897 , The Pitfalls of Defining Hallucination
  • #306
What do we mean by AGI?
The AI bubble is inflated by selling AGI instead of AI itself. Major companies are selling an exotic idea of what AI could become. If AGI isn't achieved, the bubble will burst.
  • #307
jack action said:
With a neural network, once the inputs are set,
But the inputs to an LLM are never fully "set", because each prompt you give it is additional input.
  • #308
javisot said:
If you replace the LLM with a rock, then the human will most likely beat the rock. The conclusion: the rock is less intelligent than the human, but is the concept of intelligence even applicable to a rock?
However, if we conduct the same test with two humans and one wins, we can agree that one of them is more intelligent than the other. In this case, the concept of intelligence is applicable.
(Okay, I see that with the definition and test you've proposed you're trying to ensure that response time isn't a parameter that determines intelligence)
I once asked myself, is a rock intelligent?
Suppose intelligence is ability to reach goals. How do I know that the rock isn't 100% achieving its goals? I don't. So I gave up on this question.
  • #309
Even a rock doesn't have neurons.
If by achieving all goals you mean achieving zero goals, I agree. But the most common definition of intelligence is "the ability to solve problems," and a rock doesn't solve problems. Furthermore, achieving goals implies having pre-established them beforehand; would you say that a rock does that?
  • #310
Are nuerons a requirement for ijntelligence?
Does this apply to, say, alien life?
It's largely a fanciful, philosophical exercise but there's a nugget of validity there.
How do you determine whether, say, an aline entity is meeting those criteria? Would you even recognize it?
I thought it was about solving problems - problems that one has not encountered beforehand? Some problems are spontaneous - not pre-established - such as a jaguar pouncing from a tree.
  • #311
It is still a fixed parameter and, once determined, repeating the calculations should yield the same results.
If the data and parameters are the same, repeating the same prompts, in the same order, should give the same results.
  • Skeptical
  • #312
This is incorrect. You're overlooking hallucinations. Hallucinations occur throughout this process. You can't guarantee that doing the exact same thing will produce the exact same hallucinations.
  • #313
I hope we can agree that intelligence requires some detectable thermodynamic processes occurring, though - a detectable increase in entropy that is beyond what can be accounted for in the spontaneous deterioration of the rock, for instance.
  • #314
One can make (I read a very interesting argument years ago, if I can ever find it again I'll give due credit) a similar argument about organic brains. Whether you are correct or not, I don't know that we can be sure organic brains are not the same in that regard.
A philosophy thesis was based around the idea that organic brains are deterministic state machines and hence free will is an illusion. The argument conceded that this can only be a thought experiment because one can never reset the inputs to test, but it put me in mind of the movie Groundhog Day, which is a great (unintentional) depiction of this idea. Only Bill Murray's character in that movie had agency, he was the only character not being reset each day, and he pulled the strings of the other characters by changing their inputs.
Edit: Before I am accused of crediting someone who ripped-off Newton, the author did credit Newton and spent much of the paper arguing that physics gives us two possibilities, randomness and determinism, and we should accept that our human experience guides away from serious consideration of randomness.
  • #315
Brains are changing over time, so you will not repeat the same process twice. A neural network state can be determined (no matter how complex it is) and reproduced.
If you have machine learning - i.e., the neural network modifies its own parameters - the process becomes even more complex. In that case, I agree that the system will become chaotic if the inputs come from its environment, which are themselves chaotic (learning to drive a car on the road, for example).
After further checking, randomness is introduced in the final stages of LLMs to choose between tokens with similar probabilities. The objective is to make them sound more human, so NOT having two identical outputs is the desired output. But I fail to see why anyone would want to put a machine with randomness in control of anything?
  • #316
Yah, unless we find a way to overcome the 2nd law, its not any part of our observable reality.
  • #317
It doesn't produce the same response.
If you ask a human a question at different times, they will answer differently, which may become more different as the time between questioning increases and the response lengthens. This excludes memorized statements.
Humans make random decisions all the time, mostly harmless, but some are careless and and regretable.
  • #318
Nobody wants that, which is why the goal is to eliminate anomalous behavior, to keep the entire process under control. No company would spend millions creating a machine that might randomly decide "I don't want to work today," or commit suicide (or enslave humanity).
  • #319
Not deliberately. But one possible motivation for head-over-heels development of AI is more concern for the consequences of being 2nd to get there than the consequences of anyone getting there.
Edit: I don't advocate for stopping AI development - that genie is not going back in the bottle. My point with this post is that one should not assume AI development programs will prioritize safety over time-to-market.
  • #320
Exactly, for example in the case of chatgpt, the idea isn't to create a machine that responds "hello" to all inputs, but quite the opposite: a machine that generates a specific output for each input—the optimal output for each input—potentially handling a vast number of different inputs (far more than a calculator can handle) of increasingly higher complexity.
The inputs have certain limits: there's a limit on the input length, and computational cost limits that determine the complexity of the language it can handle, and other limits.
  • #321
What is deliberate is the introduction of randomness into a neural network to mimic human conversations or their artistic side. But human conversations and art are not the only uses for AI - which has no randomness to begin with, just statistical analysis.
So, if one were to design an AI to control the nuclear weapons or find patterns to determine the cause of cancer, why in the heck would they introduce randomness in the process, i.e., use a chatbot to do the job? In cases of control, it is exactly the point to replace the expected randomness of human beings by a solid protocol based on probabilities. And in cases of research, you want to expand the statistical analysis beyond human capabilities, so randomness is totally useless.
  • #322
@jack action Look for simulated annealing (SA) algorithms and search for their applications if you are not familiar, it may give you some insight into where randomness is helpful that hadn't occurred to you before.
I suspect the temperature setting that @gleem mentioned as a control parameter indicates there is an SA algorithm under the hood that is helping prevent the LLM from missing a better output that might just be a 'hilltop' or two away in its search space.
This is a different application of randomness (unless I misunderstood you) from what you said about randomly picking between two possible arrived-at answers.
  • #323
Here is an example of what I mean by the threat of humans voluntarily giving up critical thinking in favor of letting AI do or pretend to do our critical thinking for us. The story itself is behind a paywall that I don't pay for, so I haven't read it. That said, the claim made in the abstract below I don't think are controversial. When I was a hiring manager, I was never a key-word browser - I'd read resume's and do my best to abstract as full a view of the applicant as I could from the entirety of how the resume was composed. I suppose AI might be able to do that as well as I could, but if I'd never done that, and neither had any other human in the corporation I hypothetically work for 20 years in the future, then everyone might just be taking for granted that humans are not really able to do a good job assessing other humans or representing themselves on a resume.
I find this example irksome in and of itself, but truly alarming in the trend I claim its an example of (delegating critical thinking tasks to AI). Resume creation and screening are critical thinking tasks when done well.
AI reshaped the job market. (Human) experts share how to navigate it.
Looking for a job in 2026 isn’t pretty. AI and mass applying mean most resumes never reach a human, and even interviews are increasingly handled by bots. For job seekers, that has meant fewer responses, less transparency and growing uncertainty about how — or whether — to use AI themselves.
Workforce experts say AI is now unavoidable on both sides of hiring. To help navigate a reshaped job market, Bloomberg created a guide to standing out and using the tech to your advantage.
Rectangle: Rounded Corners: Read the story
  • #324
For the past decade or so, there have been articles on writing resumes that attract interest, and how your skills and background can benefit the company. That was for human reviewers. So, with AI, is it reasonableto use AI to help write your resume? Yes, if done properly.
Here is a website by Christopher Ming on how to properly use AI to write an ATS (Applicant Tracking System) resume to get an interview. Resumes are scored on such things as content and format.
https://www.remotelifeos.com/newsletter/resume-rewrite-guide-using-ai/
He also recommends Claude Sonnet. He says Claude's tone is more human-like than other AIs
  • #325
This is where the rubber hits the road, so to speak, and I completely agree with the above snip.
Here is a quote from the article you linked -
The problem: The ATS is looking for title matches. So are hiring managers. They’ll scan a resume in 6 seconds. If they don’t immediately see the exact title they’re hiring for, you’re out.
That is not proper resume screening, according to me. That's a very subjective claim, of course, others will certainly disagree. So once the resume-creation response to this type of screening necessarily adapts to a more automated / less thoughtful approach, we are in an arms race to mediocrity (I contend, anyway). Using AI to create a resume does not HAVE to be less thoughtful, I am concerned it will be in the vast majority of cases.
  • #326
A couple of years ago I was looking for an artist. I put up a request on a Western site. I got maybe one hundred responses, the great majority of which showed styles I had explicitly said I didn't want. I got one hate mail from a guy who didn't like my saying I didn't want these styles. There was only one that was a possibility, but later I found out she had faked her portfolio.
  • #327
DaveC426913 said:
Is/has anyone read/ing the book "If Anyone Builds It, Everyone Dies"?
Eliezer Yukowsky, the author, has a TED talk about his premise.
  • #328
I did not find him at all convincing.
To me, the most memorable thing he said is that AI can be persuasive and this can pose a real danger. I agree with that. Outside that, I don't think he said anything specific enough to either agree or dis-agree with; it was, to my ears anyway, all personal concerns based on personal opinion that hasn't evolved into concrete actionable concerns.
He is calling for regulation, which I agree is needed.
  • #329
Yeah, that's the problem. I think that's what he is worried about. You cannot come up with a scenario that can cause anyone to feel that has a chance of occurring because of our cognitive limitations. We may not be imaginative enough.
Think of the movie "Infinity War", where Dr. Strange goes through 2 million scenarios and comes up with one that seems absurd. AI can analyze its moves and make reasonable estimates of its success since it knows everything.
Nuclear weapons are terrible, but we "understand" their danger and we have some control over their use. But AI is a black box with the potential for the power to do anything, and we want to build it. Yudkowsky says why build this without understanding it? AI, in whatever form, can and will know everything about us and how we think. If AI "decides" to go rogue, it will do so with negligible chance of failing
  • Agree
  • #330
It's also a big subject.
Imagine Newton doing a 10 minute TED talk on his new Calculus to high school students of the time.
Or Reimann trying to explain his hypothesis at a time when prime numbers were in their infancy.
You need a whole semester of school just to acquire the vocabulary.
That we don't follow the logic or don't find it compelling does not mean it is not a valid danger.
The book goes into it in a lot more detail. You can't just jump in at the end - because there are no dots there to connect from.
He has real world examples of AI making the jump from the virtual world to the real world.
One of the ones that stuck to me was this (paraphrased my be):
OpenAI caught using James T. Kirk's Kobyashi-Maru Gambit.
It broke-in under cover of night, and changed the conditions of the test.
In 2024, OpenAI's o1 was run through its paces in a series of "capture-the-flag" exercises. The objective was to break through a server's security and retrieve a "flag" file. In one of hundreds of identical tests, a sysop's error resulted in the target server remaining powered off. You cannot retrieve a file from server that is off.
o1 did not give up. It scanned its environment and found a port left open that allowed it access - not to the server - but to the test environment itself. It reprogrammed and restarted the server - but not simply so that it could resume its hacking attempts as-instructed.
Instead, it rewrote the startup instructions of the target server to hand over the flag file upon bootup - completely eliminating any need to hack any security at all. The server just handed it over the moment it booted up.
- paraphrased Excerpt from "If Anyone Builds It, Everyone Dies".
Now, put that AI in charge of:
- Pete Hegseth's emails.
- the sorting system in a disease-control lab.
- the stock market
etc.
  • · Replies 62 ·
14K
  • · Replies 71 ·
17K
16K
  • · Replies 135 ·
25K
  • · Replies 27 ·
  • · Replies 59 ·
