Is a nth order ODE considered linear if n=2?
  • Thread starter Thread starter Saladsamurai
    Linearity
4 replies · 2K views
Saladsamurai
I am reading through my Diff Eqs Text and I follow most of the lingo. However I am just a tad confused by the statement:
An nth order ODE is said to be linear if F is linear in y,y',...y^(n)
Then it gives the example:
[tex]a_n(x)\frac{d^ny}{dx^n}+a_{n-1}(x)..+a_0(x)y=g(x)[/tex]
It then says: 'On the left-hand side of the above equation the dependent variable y and all of its derivatives, y,y',y'',...y[itex]^n[/itex] are of the first degree.
Clearly I missed something in Calc. If n=2, I have: [tex]\frac{d^2y}{dx^2}[/tex]
Why is this linear if n=2?
Thanks,
Casey
You're confusing the *order* of the derivative with its *degree* in the equation.
y'' + y = 0
is a second-order linear equation. Second-order because the highest order derivative in the equation is a second dervative. Linear because the equation itself is linear in both y'' and y.
In contrast:
(y'')^2 + ay^3 = 0
is a second-order NON-linear D.E. Second-order for the same reason. NON-linear because it is QUADRATIC in y'' and CUBIC in y. I hope this clears things up.
y'' + y = 0
In contrast:
(y'')^2 + ay^3 = 0
I think it does. y' just means "the 1st derivative" and similarly for y" however if either one y' or y" or y for that matter were raised to any power above 1, the DE would no longer be linear.
Thanks!
HallsofIvy said:
Yes, that is correct. Also note that other "non-linear" functions of the dependent variable, y or its derivatives, such as sin(y) or exp(y"), would make the equation non-linear.
Great, thanks Halls and cepheid. Hey also, I know that the right-hand side can be equal to 0 or a function of the independent variable; what about a constant?
Like [itex]\frac{d^2y}{dx^2}-\frac{dy}{dx}+6y=7[/itex] ?
