Is a refrigeration laser thermodynamically possible?
In summary: You could plug a similar device into your wall, and have a "ventless" air conditioner (point the laser out a window or something)?
pcysics
I am NOT referring to laser cooling, the technique for supercooling atoms.
The 1980 science fiction novel Sundiver by David Brin describes a kind of spaceship that could fly into the sun.
One way described to keep the inside of the ship cool was to concentrate the heat inside the ship with some kind of heat pump, and then use the heat energy to power a laser which effectively dumps the excess heat energy out into space.
Thermodynamically, for a refrigerator to work, you need two things, right? One is some place to put the heat energy; and two is some place to put the entropy. Or, since pumping heat against the normal flow takes work, you have to increase the net entropy of the system um, somewhere? The technique seems to explain the former, but not the latter, which brings me to the question, is a refrigeration laser (as described) thermodynamically possible?
And if so where does the entropy of the system increase? Could you use part of the laser beam to power the concentrator pump in the first place?
Science news on Phys.org
Hi pcysics, welcome to PF. Laser light has relatively low entropy compared to blackbody radiation. (The extreme would be a polarized, monochromatic beam, which would have very few or one possible microstate.) Therefore, it would violate the second law for the same amount of energy from the Sun's light to be output as a laser beam.*
However, if there were a large energy source on board, a very high power laser beam might be produced that would carry away the same amount of entropy that is received from the Sun. I can't see any problems with this scenario. It wouldn't be self-renewing, however; eventually the energy source would be depleted.
*A similar and classic example of a second law violation is the "Party Boat": motor around all day making ice cubes from sea water; use the energy difference to power the engine.
So the problem here is the way we output the heat energy? If instead of using a laser, we just used a focused incandescent light source with a higher temperature than the sun, the output would have higher entropy, right? Then could the system be self-renewing? If the temperature difference were high enough, could you extract useful work from it?
So laser refrigeration is possible in principle, it just takes a lot of power. So you could plug a similar device into your wall, and have a "ventless" air conditioner (point the laser out a window or something)?
Never heard of that one.
Well, an incandescent light doesn't transfer entropy, it creates it from electrical work. So the incident entropy isn't being transferred in this case. But if parts of the ship are emitting blackbody radiation, then entropy is being transferred, albeit not at perfect efficiency.
It seems like what you're proposing is analogous to using a solar panel to run a refrigerator on Earth (a very big spaceship). No violations there.
I don't see any thermodynamic violations here either, assuming that the laser is emitting more entropy than is created by inefficiencies in utilizing the power source.
I don't mean an electric light bulb. I mean heating something to incandescence using the concentrator pump. That's the same as "if parts of the ship are emitting blackbody radiation", right? Is it self-renewing now? Can it produce useful work?
Could you dump the heat in some other way than the laser, like feed it back to the power grid? Would it still be a net drain of power in this case? And If so, since energy is conserved, where does it go?
What is a "concentrator pump," besides a term from this science fiction book?
You could use the thermal energy to run a heat engine, whose efficiency would be limited by the Carnot limit. Energy would be conserved in the form of increased temperature of the components and their surroundings.
I wasn't referring to a term from the book, but to my first post: "to concentrate the heat inside the ship with some kind of heat pump". A heat pump is the same thing as some kind of refrigerator. The exact method used to pump the heat is probably irrelevant to our discussion. A refrigerator has an insulated box which it pumps the heat out of, (into the ambient environment) the concentrator pump is just a refrigerator in reverse; it has an insulated box which it pumps ambient heat into.
Huh? The whole point of this device is to act as an air conditioner. What components? Does that mean it stops working as an air conditioner? Correct me if I'm wrong, but a heat engine doesn't put as much energy into the cold reservoir as it extracts from the hot reservoir, right? And the difference can be recovered as useful work?
I'm guessing that the energy generated by the heat engine isn't quite as much energy as is required to run the concentrator pump in the first place, but if you dump the power generated by the engine back onto the grid you can offset this energy cost partially, though it's still a net drain on the grid.
So we seem to have a contradiction here:
  1. Energy is taken from the grid to run the machine.
  2. The net temperature of the room decreases (heat energy is taken from the room, because that's what the machine is for).
  3. Energy is conserved.
The energy seems to be disappearing here, in clear violation of the laws of physics. Something's definitely wrong with my reasoning, I'm just not sure what.
Your machine is a laser, yes? Whatever the laser is pointing at will heat up. There's the "disappearing" energy.
Nope, not a laser. I said,
And I wrote in my post #6 that you could run a heat engine, which would dump thermal energy into its cold reservoir, besides heating itself due to inefficiencies.
Right, but the cold reservoir in this case would be the room itself, which the concentrator pump is extracting the heat from in the first place. This machine is supposed to be an air conditioner. Read my post #7 again.
Perhaps I'm confused, but it seems like you're talking about running two heat engines back-to-back. Would you please describe again the system you have in mind? Is it steady-state, and what are the temperatures of the components?
Sorry, it seems I have yet to develop an intuitive grasp of the second law of thermodynamics. I'm not sure what you mean by steady-state.
You've heard of electric "space heaters". They're compact and portable. They generate heat through electric resistance like a toaster, but this takes power from the wall.
Suppose I want to make a "space cooler" to have the opposite effect. Currently the closest thing to that are those window air conditioners which vent hot air outside. They're not quite as portable as a space heater, since you have to put the whole unit in the window.
We seem to have come up with a partial solution in this discussion, based on the sundiver. I suppose you could use a heat pump (say a chain of vortex tubes) to concentrate ambient heat into a small vacuum-insulated (as a thermos bottle) box up to say, around 1000 Kelvins, less than a candle flame (the concentrator pump).
This box could contain a chunk of calcium oxide (as a limelight) which would incandesce from the heat, effectively converting some of the heat energy into light. You could have the inside of the box be reflective and channel the light into an optical fiber, which you could then point out the window to vent the light without having it re-absorbed as heat by something in the house.
If I understand correctly what you've told me so far, I think this could function as a more portable air conditioner. Instead of having to put the whole unit in the window, you just have to put the end of the fiber (which can be fairly long) in the window. Now you've got a portable space cooler. It's almost as portable as those electric space heaters, but you just have two cords to deal with instead of one, the power cord and the optical fiber.
The system I just described may not be very high performance (that's an engineering problem) it's just a proof-of-concept to prove this can be done in principle. (and it could work, right?)
Now can we modify this system to require only one cord? Can we dump the energy out through the power cable into the grid or the ground?
I appreciate the detailed explanation, pcysics. I'll do my best to give constructive comments on this scenario.
I think you've got a pretty good idea of the key ideas of thermodynamics. "Steady state" just means that none of the parameters in the system changes with time. It's a good constraint to apply to a system because it means the analysis will be valid in the long term.
We have a region A (one part of your room) that is cooler than the surrounding environment. Spontaneous heat transfer from the surrounding environment results in a positive input energy E1 and a positive input entropy S1 to region A. We also have a power cord from the outside that delivers positive electrical energy E2 with little or no associated entropy. The energy is used to maintain a temperature gradient between region A and region B (the incandescent part of your room) that has a temperature higher than that of the surrounding environment. A positive energy E3 and a positive entropy S3 move up this gradient as a result of the input electrical work. Heat transfer (through an optical fiber) spontaneously transfers positive energy E4 and positive entropy S4 from region B to the surrounding environment. Entropy is generated in both rooms as a result of inefficiencies.
The steady-state requirement makes it easy to monitor energy and entropy transfers even through we don't know the exact temperatures of regions A and B. By the first law, E3 = E1 and E4 = E3+E2. By the second law, S3 > S1 and S4 > S3.
Have I got this straight?
That looks right.
The thermodynamic efficiency of any kind of heat pump is dependent on temperature: the larger the temperature difference between the hot and cold side, the lower the efficiency. So yes, you could do what you suggest, but you could do very little cooling with it.
here is the quote from the book which explains basically what David Brin (he is a astroner with a Master degree in applied physics and a Doctor in Philosofy of space exploration) thought about his "refrigerator laser"
Project Icarus it was called, the fourth space program of that name and the first for which it was appropriate. Long before Jacob's parents were born—before the Overturn and the Covenant, before the Power Satellite League, before even the full flower of the old Bureaucracy—old grandfather NASA decided that it would be interesting to drop expendable probes into the Sun to see what happened.
They discovered that the probes did a quaint thing when they got close. They burned up.
In America's "Indian Summer" nothing was thought impossible. Americans were building cities in space—a more durable probe couldn't be much of a challenge!
Shells were made, with materials that could take unheard of stress and whose surfaces reflected almost anything. Magnetic fields guided the diffuse but tremendously hot plasmas of corona and chromosphere around and away from those hulls. Powerful communications lasers pierced the solar atmosphere with two-way streams of commands and data.
Still, the robot ships burned. However good the mirrors and insulation, however evenly the superconductors distributed heat, the laws of thermodynamics still held. Heat will pass from a higher temperature to a zone where the temperature is lower, sooner or later.
The solar physicists might have gone on resignedly burning up probes in exchange for fleeting bursts of information had Tina Merchant not offered another way. "Why don't you refrigerate?" she asked. "You have all the power you want. You can run refrigerators to push heat from one part of the probe to another."
Her colleagues answered that, with superconductors, equalizing heat throughout was no problem.
"Who said anything about equalizing?" the Belle of Cambridge replied. "You should take all excess heat from the part of the ship were the instruments are and pump it into another part where the instruments aren't."
"And that part will burn up!" one colleague said. "Yes, but we can make a chain of these 'heat dumps,'" said another engineer, slightly more bright. "And then we can drop them off, one by one ..."
"No, no you don't quite understand." The triple Nobel Laureate strode to the chalkboard and drew a circle, then another circle within.
'Here!" She pointed to the inner circle. "You pump your heat into here until it is, for a short time, hotter than the ambient plasma outside of the ship. Then, before it can do harm there, you dump it out into the chromosphere."
"And how," asked a renowned physicist, "do you expect to do that?"
Tina Merchant had smiled as if she could almost see the Astronautics Prize held out to her. "Why I'm surprised at all of you!" she said. "You have onboard a communications laser with a brightness temperature of millions of degrees! Use it!"
Enter the age of the Solar Bathysphere. Floating in part by buoyancy and also by balancing atop the thrust of their refrigerator lasers, probes lingered for days, weeks, monitoring the subtle variations at the Sun, that wrought weather on the Earth.
other parts of the book explain it better.
I sent David Brin a message pointing out to discussions on the net saying his refrigerator laser was implausible and asking him if he really thought the concept would work, if it would only work with the physics knowledge of the Galactics (in the books), etc
here is his answer
"Thanks for your thoughtful and interesting message. It truly is gratifying when people write, and I always try to answer.
As a matter of fact, I ran the refrigerator laser past a couple of Nobel Prize winning physicists, back in the 1980s. Plasma physicist Hannes Alfven could find nothing wrong with my reasoning... and found it "plausible."
Remember the comparison to the refrigerator in your kitchen. With an effectively infinite energy source (wall current) your fridge pumps heat from one space (the freezer box) into another space (the surrounding kitchen)... along with the waste heat involved in the process. It simply works.
If the sun's Chromosphere is the 'kitchen' and the ship is the freezer
So... two Nobel Prize winning physicists supported the concept, including a plasma physicist.
but here in the forum, we are saying its impossible...
Here's the problem: we NEVER do physics simply via hearsay!
As far as I can tell, you did not cite a single peer-reviewed citation to back any of such claim. Note that any moron can write a book and have it published. Just browse the net and see a ton of crackpottery being published in books.
For something like this to be judged as valid, it needs to have very clear description of not only the mechanism, but also the physics involved. The DETAILS are missing here! Just saying "2 Nobel prize winners" can't find anything wrong with it is utterly weak if THAT is all this person have! I can show you several nobel prize winners pushing theories that many of us scratche our heads. Shall I quote you a passage from Robert Laughlin's book calling out a particular Nobel prize winner for an obviously wrong conclusion about superconductivity?
If you have peer-reviewed publication supporting this, then please cite it. If not, then you don't have much to stand on and you are violating the PF Rules that you had agreed to for advertising such a thing on here.
Zz.
Zz.
sorry, how exactly what I posted falls on the Advertising Rule? I did not link to any website or blog.
You are advertising something that only gets mentioned in a book. Advertising isn't necessarily related to something commercial. Many crackpots try to advertise their theory on here, and that's the only means for such things to see the light of day.
I'm a bit concerned that you're not at all worried about my query if something like this has been published in peer-reviewed journals. This should have been the #1 issue that you should have addressed, not my "advertising" prohibition.
Zz.
I did not create the thread, nor I am pushing the issue any further. Also, I did not advertise the book, for it was the creator of the thread who said it was a David Brin book. I only posted a passage of the book, so maybe we could better understand the concept.
When I said two Nobel laureates had thought the concept plausible, you answered by saying there are tons of Nobel laureates that commit stupid mistakes in other subjects. Thats a fine answer for me.
You worry that I did not care about the issue of the peer reviewed journals. But why should I worry, if I am not the one that created the thread about refrigerator lasers? I only continue a subject created by another but I am the one called the attention by a moderator? You should ask the thread creator if a refrigerator laser has been published in a peer reviewed journal.
The only "rule" I broke was "advertising", and that again, by a stretch of imagination. Btw, refrigerator lasers are NOT a theory. They are a piece of sci-fi, and the book author is not advertising here. Nor am I advertising a theory, since its not even a theory, just a cool concept used in a sci-fi book. I don't remember Clarke submitting to peer review geosynchronous sattelites or space elevators.
The problem with the concept of using a laser to eject heat, using heat as the power source for the laser is that in order to create a laser from a heat source, the heat source must do work. In order to do that, you must have heat flow. In order to do that, you need a temperature difference from a hot to a cold reservoir.
The problem is that the amount of energy you can eject with a laser is no greater than the work done in creating the laser light. That work is limited by the temperature difference between the hot and cold reservoir.
Essentially, you are trying to use a heat engine to run a heat pump and using the heat pump to maintain the temperature difference that enables the heat engine to run. The best you can do is break even. Otherwise, you have a net flow of heat from cold to hot which violates the second law.
So in answer to your question, this concept is thermodynamically impossible.
AM
The difference here is that one is asking for clarification, the other is providing answers AND challenging the fact that on "here", it has been claimed to not work. Which one do you think your post falls under? When you make such statements AND, the only criteria you used is some hand-waving claim made by someone that Nobel Laureates can't find anything wrong with that, then the SOURCE that you are using to justify your claim is dubious!
If Arthur C Clarke were to come here AND made such dubious claim, we would haul him off as well! There is a reason why we call this "Physics Forums" and not "Science-Fiction Forums".
Zz.
AM
thanks, a very good and clear explanation.
Taking the argument to extreme, we are talking about covering an area of the sun and dumping the heat flux across that area to a heat sink of nearly absolute zero temperature. That is what the sun is already doing and it retains its high 'surface' temperature anyway.
If we take the argument to a[n il]logical maximum, the sun is entirely surrounded by our heat gathering surface and the energy is collected in a single location where our 'communication laser' pumps all that heat into space. If our laser is 1/1,000,000 the surface area of the sun, it would need to pump out a million times the solar output. Meanwhile, the entire surface of our solar shell must furiously work to concentrate heat toward the laser.
Q1. Is this a correct scenario?
Q2. Does the 'total coverage' aspect negate some or all of this scenario?
Q3. Can a refrigeration laser operate under this scenario?
Q4. If the sun operated at 500 degrees Fahrenheit or even 5000 degrees Celsius, would we even be having this debate?
Assume that we would still need to cool the 'Sundiver' for an indefinite period.
Having written the preceding, there are two lasers at work in the scenario. The first is the refrigeration laser that cools the inward-facing shell. The second is the communication laser transmitting to space.
Okay, so what is going on here is that we have outward thrust supplied by the comms laser and heat absorption from the inward-facing heat sink generated by the cooling effect of the refrigeration laser.
Excuse me for brainstorming a bit. First time encountering this forum.
So, we have inward force applied by the outward radiation at/near perihelion. If we maintain inward orientation throughout the passage, then the thrust should have relatively little effect on the orbital characteristics since no acceleration or deceleration is applied; instead it is applied orthogonally with the orbital path. Or have I got that wrong? I think it might make the orbit increasingly elliptical. Never could master that orbital dynamics video game on my dad's Timex Sinclair.
So, given a large enough internal supply of energy, a refrigeration laser is possible, but not self-renewing, as the supply will eventually be depleted. I still don't understand how to actually build one, even in theory.
You have all the power you want? From the sun, right? You can't extract heat energy thermodynamically, but maybe that's not the only power source available from the sun. Can't you use photovoltaics to absorb light energy? Maybe capture energetic electrons magnetically? Or occasionally refuel a self-sustaining fusion reactor from stellar hydrogen?
The heat sink being 4 kelvin outer space, right? If it were that easy, we could just plant a refrigeration laser on the surface of the Earth, point it into space, and get free energy! After all, Earth is about 288 kelvin, and even hotter in some places. There, global warming crisis solved. Get cheap renewable power plants literally anywhere exposed to open sky, and as a bonus, they actually refrigerate the planet! No way this could really work...
Wait, could this actually work?
Refering to my limelight space cooler:
I think this is more of an engineering problem, but maybe it isn't necessary to achieve 1000 Kelvins for the space cooler to work. I've heard that cheap green lasers are actually infrared lasers and a frequency doubler. Maybe you can generate light from a much lower temperature? Or do frequency doublers only work on lasers?
Never forget that Overall head transfer = Overall heat transfer coefficient * Area * (Temperature of hot surface - Temperature of cool surface). That is, Qdot=UA(deltaT). So, with the sun radiating into space's 4 Kelvin heat sink it is working at max heat transfer rate for the surface area until and unless we raise the effective surface temperature of the sun with our RHL (Ridiculously Hot Laser), lower the temperature of space (heh!), or increase the 'effective surface area' of the sun.
Much more likely to work is a Gattling Gun cooling scheme wherein cold slugs that become its temporary heat sinks are fired to the probe. Following use, they are recycled into space to escape the sun's influence and cool down far enough away that the temperature is appropriate - or - they are plunged into the sun for disposal.
On the modeling or proof-of-concept side, can we make a free-floating balloon with solar cells on its sunward side that can decrease the temperature of the air surrounding its entire surface (minus the side with the 'communication laser')? If we can do that, then the model is workable and the only thing left is to scale up the solution to match the target environment. I remain skeptical.
1. Is a refrigeration laser thermodynamically possible?
This is a commonly asked question among scientists and researchers. The answer is yes, a refrigeration laser is thermodynamically possible. It has been theorized and studied by many scientists and there have been successful demonstrations of such a device in laboratory settings.
2. How does a refrigeration laser work?
A refrigeration laser works by using a process called laser cooling, which utilizes the principles of thermodynamics and quantum mechanics. It involves directing a laser beam at a material, causing the atoms in the material to absorb and re-emit photons. This process results in the transfer of energy from the material to the photons, causing the material to cool down.
3. What are the potential applications of a refrigeration laser?
A refrigeration laser has many potential applications, particularly in the field of cryogenics where traditional cooling methods may not be feasible. It can be used to cool materials to extremely low temperatures, which is useful in fields such as quantum computing, superconductivity, and materials research.
4. Are there any limitations to refrigeration lasers?
Like any technology, refrigeration lasers have their limitations. One limitation is that they can only cool materials to a certain temperature, known as the Doppler limit. Another limitation is that they require precise and expensive equipment, making them more suitable for laboratory settings rather than everyday use.
5. Are there any current developments or advancements in refrigeration laser technology?
Yes, there are ongoing research and development efforts to improve and advance refrigeration laser technology. Scientists are exploring new materials and techniques to achieve lower temperatures and more efficient cooling. Some recent advancements include the use of solid-state refrigeration lasers and the development of more compact and portable systems.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • Thermodynamics
  • General Engineering
