Is AC energy really transferred as EM wave?
The discussion revolves around the nature of AC electricity and its relationship with electromagnetic (EM) waves, particularly in the context of transmission lines. Participants explore theoretical models, the propagation of AC current, and the implications of electromagnetic shielding.
  • Some participants assert that electricity is transferred on transmission lines as electromagnetic waves, while others challenge this view, suggesting that AC systems do not fundamentally operate as EM wave propagation phenomena.
  • Several models are proposed for understanding electricity, including quantum electrodynamics (QED), Maxwell's Equations, and circuit theory, with a caution against mixing these models to avoid confusion.
  • There is a discussion about the nature of AC current as a transverse wave and how it behaves when propagating through transmission lines, with some participants expressing confusion about this relationship.
  • Concerns are raised about the effectiveness of conductors in eliminating EM waves, with references to the metal grid in microwave ovens and its role in RF shielding.
  • Some participants express a desire for clarification on how AC current can propagate along metal conductors without being eliminated, questioning the underlying principles of electromagnetic shielding.
Participants express differing views on whether AC electricity can be accurately described as EM wave propagation. There is no consensus on this issue, and multiple competing perspectives remain throughout the discussion.
Participants highlight limitations in understanding due to the complexity of models and the nuances of electromagnetic theory. There are unresolved questions regarding the behavior of AC current in relation to EM waves and the implications of shielding.
  • #31
davenn said:
In an AC circuit, say, the transmission of energy from your power generating station to your home, the electrons in the wires in the generator probably never make it to your home, they just oscillate back and forwards over a very short distance at 50 Hz/ 60Hz (depending where your are from) As they oscillate back and forwards, they undergo acceleration during each half cycle and its this cycling (oscillation) that generates the EM wave that I said above.
The energy is transmitted along the outside of the cable ( transmission line) via the EM wave
Ok. Suppose we have direct current in a solid conductor. But even in the case of d.c. electrons does not move with constant velocity because they interact with crystall lattice. So they should emit energy in the form of EM waves. Does electrons emit EM waves during their movenment in conductors? What is the magnitude of the energy loss?
  • #32
There is a vast range of velocities because the conduction electrons are in random motion, the average drift velocity is typically only a mm or so per second. For AC of any significant frequency, the actual displacement is incredibly small. So electron movement is really not a good way to discuss electric current.
I could suggest that the noise energy due to random electron movement is what you're probably looking for. It's always there in any electronic component.
  • #33
sophiecentaur said:
"Is just"? There is a world of difference between two parallel wires and a single, thicker wire. The propagation of an EM wave over a conductor (E field, nominally transverse) is actually not transverse. There is a slight forward tilt to the wave front, due to losses in the conductor. A number of insulated wires or layers could not support or explain this phenomenon. Your model is flawed, I'm afraid.
Well, maybe I should have said: "let us model the skin effect in a thick 60 Hz AC power wire by many thin parallel wires", instead of "thick wire is just many thin wires".
  • #34
IMHO the magnitude of the loss of kinetic energy is huge, because acceleration is huge.
  • #35
Skin effect is explained by a very simple concept and by looking at the field distribution of a straight line conductor.
The field strength is strongest at the centre of the conductor. As the AC current varies the field collapses and regenerates in opposing directions according to the frequency. The varying field induces a reactive impedance (back emf) in the conductor which varies with field density. This impedance is strongest at the centre of the conductor and weaker at the surface. Since current follows the least impedance path, the current tends to flow in the conductor surface (the skin).
You will find that in high power high frequency transmitter sites the HF power conductors are hollow copper tubes. Not because they conduct better, but because to fill them is a waste of copper.
  • #36
I'm sure they do, but remember that other than the surface electrons, the electrons are inside of the conductor, so any EM waves are quickly absorbed and turned into heat.
But what is the time frame for the acceleration? Is the electron being stopped almost completely, or is it mostly just scattering off a bit?
  • #37
Oh, your explanation is clear and helpful. I suppose I get it. Besides, could you please explain from Wiki perspective? I have attached it at the first page. Perhaps, you will feel it interesting as well. Thx a lot.
  • #38
Do the Math. What is the Mass involved? (One electron per atom ) what is the drift velocity? (Say 1mm/second) How much KE would there be in 1g of wire?
  • · Replies 21 ·
