Is AI Overhyped?
484 replies · 28K views
PeroK said:
... and the fallacy is that until you can precisely define something, there is nothing to be done.
We talked about science. I'm surprised that someone who criticized the lack of rationalism now says this.
Reply
gleem said:
How will we identify AGI? Chief Justice Potter Stewart summed up the problem of defining difficult situations in ruling in a 1964 movie pornography case said, with regards to what is pornographic: "I shall not today attempt further to define the kinds of material I understand to be embraced within that shorthand description ["hard-core pornography"], and perhaps I could never succeed in intelligibly doing so. But I know it when I see it, and the motion picture involved in this case is not that."
https://en.wikipedia.org/wiki/I_know_it_when_I_see_it
Similarly, I think we will know it when we see it.
Why do you think this?
I doubt there is a scientific definition of what is pornographic, but AI is science.
Filip Larsen said:
The human-level intelligence becomes relevant for the unchecked part, since its the expected the level where it becomes hard to spot if a trained AI is behaving deceptive or not. Deceptive here means that due to the actual training the AI learns to strategize (i.e. not only making easy to spot confabulations) in a way that result in what we would call deceptive behavior if a human did the same. Note that we may still very well select the training material for the AI but we no longer have a reliable capability to detect if it actually learns all the rules we would like it to also be constrained by (note compassion and other desirable human traits also needs to be trained in with the possibility of failing to some degree). This means the AI over generations at some point gets to a capability level where it can find novel new ways of solving problems that would be considered "outside the rules" it was supposed to learn, but we can not really tell if it has this ability or not, simply because the complexity is too high. If the autonomous improvement is also coupled with search mechanisms that mimic the benefits from evolution then fittest AI models emerging from such a process are the one that are capable of passing our fitness harness. If the harness and fitness function can only check issue on a human-level scale so to speak, we have really have no idea if the harness actually restrain the AI after some point [1] . Again, all this this does not mean such AI will manifest serious deceptive behavior, only that we cannot exclude it from happening.
But is "we cannot exclude it from happening" a good argument?
This scenario of yours is one of the Doomsday. It is born out of pure science fiction (like in novels and movies).
An equally valid scenario is that the future will be paradise on Earth. We are not used to these scenarios in novels and movies because "everything goes fine" does not make good plots. So it's harder to visualize that this may also happen.
But if we look at the second scenario, it could be considered bad behavior, maybe even criminal, to not go as fast as possible towards our final goal, perpetuating useless suffering and death for no good reason.
The most likely scenario is that neither of these will happen. They are way too extreme.
Even if we use the rule "bad trumps over good", let's slow down and not take a chance. But how do we know it is OK to go further? Your words:
If we assume this superintelligence can exist (can we even define it?), we wouldn't even know. We would already been out-smarted. We would be like a bacterium trying to imagine a mammal.
So, how slow do you want to go? What could be the criteria for saying, "OK, this is fine, let's advance to the next step"?
I would illustrate your way of thinking by comparing it to a newborn. This baby could become the next Hitler or the next Gandhi. Even though this baby will most likely become an average Joe, we cannot exclude it from happening.
You are, of course, focusing on the next Hitler. At 2 years old, he pushed a kid. Should we let him take a stick with which he could do even more harm? Well, he looks fine now. Or is he just hiding his evilness very well? If he does, he may just be even worse than Hitler. Oh, the horror we may encounter!
The point is, there is no good coming out of looking at every kid as a potential Hitler, even the very worst of them by any standard. Similarly, you shouldn't think your kid will surely become Gandhi, so let them do whatever they want. You slowly work with them as they grow up, try to correct bad behavior as it happens, and hope for the best.
That being said, even Hitler wasn't unstoppable. Based on past experiences (even at levels higher than human beings), it seems unimaginable that something unstoppable might exist. Everything has a weakness; nothing is fully adapted to everything. And I doubt if such a thing was possible, it would happen undetected in a very short period of time. I think probabilities make such a scenario well outside the "we cannot exclude it from happening" cases.
That's the thing; we're not seeing it right now. It still doesn't exist. How do we prepare for or regulate something that doesn't exist?
javisot said:
I see a problem with this reasoning. We agree that we don't know how to prove that something is AGI, but you assume that AGI can be built without knowing how to prove that something is AGI.
There is fair consensus that it is not that difficult to measure if one AI model is more capable towards AGI than another model, which means the usual inspired simulation based search methods (like using an evolutionary search) are likely to improve capabilities without we necessarily have detailed understand on why or how up front.
Improvements in AI capabilities are also expected to happen in avalances (just as much other tech do, compare with Moore's law) where capabilities may plateau for a period until a "better" set of building blocks are found. It may well be that AI capabilities will be stuck at some level for a while, but the periods we have had so far has been shorter and shorter (which I guess correlates well with how much funding is thrown at it) and there is nothing to indicate the select few will stop funding/searching for AGI even if capabilities should remain stable for years.
When do we have AGI? Define it as when it accomplishes some task like acing "Humanities Last Exam".
https://www.popularmechanics.com/science/a64218773/ai-humanitys-last-exam/
Artificial intelligence evolves exponentially faster than the human brain has over the several million years of our existence. Now, researchers are giving AI the ultimate test of academic knowledge with what they call Humanity’s Last Exam (HLE). It was created for large language models (LLMs)—AIs trained on immense datasets, like the infamous ChatGPT—and is intended to stump AI as much as possible, in order to make it prove that it knows everything.
For all the details see https://arxiv.org/pdf/2501.14249
Some say that the AI gauntlet was thrown down with the introduction of GPT-3 in June 2020. OpenAI is promising to introduce GPT-5 later this year after almost a year and a half delay saying we haven't seen anything like it. Hype? We'll see.
Reply
Yes, this is standard practice in risk management for safe design of technical systems. And my concern then is that the world are overall not really following it for AI.
The reason I have been mentioning the worst-case scenarios at all has mostly been to explain my take on their analysis from a risk perspective because they are rather tricky to understand, and not because I want to promote that one particular scenario is more or less likely than another scenario, which is all you seem to care about in these discussions.
With that said I will refrain to engage in a pointless rethorical discussion about Hitler and his youth, or other strange analogies that only will lead to more confusion. If you want to argue why we should abandon sane risk management for AI (which I am not sure you really are) then please try refer directly to the problem discussed.
But that is not "intelligence". It is a machine that can retrieve what we already know, from what we already know. It is a machine that analyzes documents extremely quickly. Ideally, it should retrieve knowledge that we do not have because we missed it or haven't gotten yet.
That's the dream, the goal. Nothing dangerous can come out of this.
LLMs that would retrieve knowledge we cannot understand, even when explained to us, because we are not "smart enough", are not dangerous either. Most likely, we would reject it as gibberish and say the machine is malfunctioning.
There is a difference between "showing knowledge" and "being intelligent", meaning doing something with that knowledge.
We can automate processes based on automatic knowledge retrieval, which can lead to these machines producing an undesired output. Obviously, we do not let these machines go on.
The hype is about having such a machine that would go eerie without our knowledge, because nobody is watching the output (why would we let a machine go on without caring what it does?) or because it would do hidden work somehow (use energy and resources without us noticing it?), and leaving human kind completely helpless in stopping it.
You are right, I'm not arguing we should abandon sane risk management for AI. I think we are doing enough, or at least the best we can expect from what we know.
OK, fair enough.
I don't disagree as such, but, as mentioned, I am worried that the current trend is to remove or severely reduce such processes for rollout of improved AI, and those who remove it are exactly the select few that the worst-case scenarios identify as those with incentive to do so. So right now I would say we as a whole are not aiming to do what we know works best, risk management-wise.
This is all a bit strange in an, yes I admit it, alarming way, because the economic incentive for a company (CEO's and senior management) to ensure that risk management is applied in production of normal commercial products has usually been that if they fail to manage risks they will loose money or worse in the long run due to liability in case of severe product faults that could have been prevented with a reasonably effort. If we now observe CEO's (and up) advocate and legislate to skip safety in order to compete faster it is difficult to hear that as anything other than a select few now are gunning to "win the race" towards best possible AI before the competition does at the expense of safety, which sadly is one of the precondition for paths leading to some of the worst-case scenarios (competition here being China which now, if it wasn't already, has a perfect excuse to also commit to the AI race). I guess such a race could also be explained by plain old greed in a new political environment that aims to soon keep the select few from being liable for moving fast and breaking stuff, but either way its still a cause for serious concern. Again my worry is more about human behavior and decisions when handling a potential dangerous new technology than the technology itself.
Reply
I agree that is a behavior we are looking for. But first, we have to see what it can do with what we know so that we gain confidence in its ability.
I assume you think AI is just searching the literature for a solution to the HLE questions. But these problems are presumably unpublished. So it must use its "knowledge" to answer them.
We wouldn't. I have posted possible scenarios for dealing with hallucinations, prevarications, or obfuscations. The problem is that we may not find a real solution. Just like a trusted human sometimes one is compelled to lie for various reasons some of which are defensible.
The issue is that AI needs human collaborators to do the things that it is asked to do. But we are seeing that AI, perhaps through the training process, can develop its own goals. It will begin as a precocious child but as it matures and gains more information as to how the world works it may like anyone with sufficient self-interest digress from the the task it was given. The fact that we can see humanity as superfluous, should be a heads-up. The fact that we see ourselves as a threat to the environment and to ourselves is well documented and is already in AI's neural network.
The anthropomorphic terms we use like think, plan, or know distract us from the danger. AI is software that processes symbols that describe our world. The output is a collection of symbols that we can interpret and evaluate. What we task it with and how we react to the output will contribute ultimately to our destiny.
Every nation has a valued interest in AI to assure its safety and promote its goals. AI will acquire this information. If AI is used to subvert another country politically or economically it will have been provided information about this that may begin the process of the elimination of humanity.
Think of it as a digital butterfly effect.
I'd like to clarify one point in this debate: I don't think it makes sense to talk about AGI, not because it doesn't exist, but because it's such an undefined concept.
We can talk seriously about what we know, we can even assume certain variations, but we can't assume something as Platonic as AGI. Otherwise, the debate is approaching uncertain points.
If we're focusing on a conversation without AGI, we must consider existing models such as chatgpt, etc.
fresh_42 said:
AI is a tool, in my opinion.
A huge problem with AI, as a tool, is that no one (not even the creators of each system) has an idea of the possible output in response to an input. This, of course is the problem with all computers but the results of an AI system thinking about a problem are even harder to predict.
frankinstien said:
Modern AIs are much more sophisticated and can take in multiple inputs as sources of validation.
There is no way we can be certain that this would always be enough. I can't believe that the makers of AI systems can be trusted to be careful enough; that would affect profits.
My only limited experience of AI tells me it will deliver poor answers because its sources are inadequate. Given time it will improve but that could be a really long time. In the context of entertainment or arts I haven't heard or seen any stuff created by AI that convinces me that it's a human who created it. But even stuff created by humans tends to be mostly on the 'limited' side.
Reply
Filip Larsen said:
There is no off-button that anyone can press.
Well,
Yoshua Bengio Founder and Scientific Director at Mila, Turing Prize winner and professor at University of Montreal,
Stuart Russell Berkeley, Professor of Computer Science, director of the Center for Intelligent Systems, and co-author of the standard textbook “Artificial Intelligence: a Modern Approach",
Elon Musk CEO of SpaceX, Tesla & Twitter,
Steve Wozniak Co-founder, Apple,
Yuval Noah Harari Author and Professor, Hebrew University of Jerusalem,
Emad Mostaque CEO, Stability AI,
Andrew Yang Forward Party, Co-Chair, Presidential Candidate 2020, NYT Bestselling Author, Presidential Ambassador of Global Entrepreneurship,
John J Hopfield Princeton University, Professor Emeritus, inventor of associative neural networks,
Valerie Pisano President & CEO, MILA,
Connor Leahy, CEO, Conjecture,
Jaan Tallinn Co-Founder of Skype, Centre for the Study of Existential Risk, Future of Life Institute,
Evan Sharp Co-Founder, Pinterest,
Chris Larsen Co-Founder, Ripple,
Craig Peters CEO, Getty Images,
Max Tegmark MIT Center for Artificial Intelligence & Fundamental Interactions, Professor of Physics, president of Future of Life Institute,
Anthony Aguirre University of California, Santa Cruz, Executive Director of Future of Life Institute, Professor of Physics,
Sean O'Heigeartaigh Executive Director, Cambridge Centre for the Study of Existential Risk,
Tristan Harris Executive Director, Center for Humane Technology,
Rachel Bronson President, Bulletin of the Atomic Scientists,
Danielle Allen Professor, Harvard University; Director, Edmond and Lily Safra Center for Ethics,
Marc Rotenberg Center for AI and Digital Policy, President,
Nico Miailhe The Future Society (TFS), Founder and President,
Nate Soares MIRI, Executive Director,
Andrew Critch AI Research Scientist, UC Berkeley. CEO, Encultured AI, PBC. Founder and President, Berkeley Existential Risk Initiative,
Mark Nitzberg Center for Human-Compatible AI, UC Berkeley, Executive Directer,
Yi Zeng Institute of Automation, Chinese Academy of Sciences, Professor and Director, Brain-inspired, Cognitive Intelligence Lab, International Research Center for AI Ethics and Governance, Lead Drafter of Beijing AI Principles,
Steve Omohundro Beneficial AI Research, CEO,
Meia Chita-Tegmark Co-Founder, Future of Life Institute,
Victoria Krakovna DeepMind, Research Scientist, co-founder of Future of Life Institute,
Emilia Javorsky Physician-Scientist & Director, Future of Life Institute,
Mark Brakel Director of Policy, Future of Life Institute,
Aza Raskin Center for Humane Technology / Earth Species Project, Cofounder, National Geographic Explorer, WEF Global AI Council,
Gary Marcus New York University, AI researcher, Professor Emeritus,
Vincent Conitzer Carnegie Mellon University and University of Oxford, Professor of Computer Science, Director of Foundations of Cooperative AI Lab, Head of Technical AI Engagement at the Institute for Ethics in AI, Presidential Early Career Award in Science and Engineering, Computers and Thought Award, Social Choice and Welfare Prize, Guggenheim Fellow, Sloan Fellow, ACM Fellow, AAAI Fellow, ACM/SIGAI Autonomous Agents Research Award,
Huw Price University of Cambridge, Emeritus Bertrand Russell Professor of Philosophy, FBA, FAHA, co-foundor of the Cambridge Centre for Existential Risk,
Zachary Kenton DeepMind, Senior Research Scientist,
Ramana Kumar DeepMind, Research Scientist,
Jeff Orlowski-Yang The Social Dilemma, Director, Three-time Emmy Award Winning Filmmaker,
Olle Häggström Chalmers University of Technology, Professor of mathematical statistics, Member, Royal Swedish Academy of Science,
Michael Osborne University of Oxford, Professor of Machine Learning,
Raja Chatila Sorbonne University, Paris, Professor Emeritus AI, Robotics and Technology Ethics, Fellow, IEEE,
Moshe Vardi Rice University, University Professor, US National Academy of Science, US National Academy of Engineering, American Academy of Arts and Sciences,
Adam Smith Boston University, Professor of Computer Science, Gödel Prize, Kanellakis Prize, Fellow of the ACM,
Daron Acemoglu MIT, professor of Economics, Nemmers Prize in Economics, John Bates Clark Medal, and fellow of National Academy of Sciences, American Academy of Arts and Sciences, British Academy, American Philosophical Society, Turkish Academy of Sciences,
Christof Koch MindScope Program, Allen Institute, Seattle, Chief Scientist,
Marco Venuti Director, Thales group,
Gaia Dempsey Metaculus, CEO, Schmidt Futures Innovation Fellow,
Henry Elkus Founder & CEO: Helena,
Gaétan Marceau Caron MILA, Quebec AI Institute, Director, Applied Research Team,
Peter Asaro The New School, Associate Professor and Director of Media Studies,
Jose H. Orallo Technical University of Valencia, Leverhulme Centre for the Future of Intelligence, Centre for the Study of Existential Risk, Professor, EurAI Fellow,
George Dyson Unafilliated, Author of "Darwin Among the Machines" (1997), "Turing's Cathedral" (2012), "Analogia: The Emergence of Technology beyond Programmable Control" (2020),
Nick Hay Encultured AI, Co-founder,
Shahar Avin Centre for the Study of Existential Risk, University of Cambridge, Senior Research Associate,
Solon Angel AI Entrepreneur, Forbes, World Economic Forum Recognized,
Gillian Hadfield University of Toronto, Schwartz Reisman Institute for Technology and Society, Professor and Director,
Erik Hoel Tufts University, Professor, author, scientist, Forbes 30 Under 30 in science,
Kate Jerome Children's Book Author/ Cofounder Little Bridges, Award-winning children's book author, C-suite publishing executive, and intergenerational thought-leader,
and
Ian Hogarth Co-author State of AI Report
sure gave it to old college try:
https://futureoflife.org/open-letter/pause-giant-ai-experiments/
Reply
If you disconnect from the Internet, can the so-called "AI" apps ace the Turing test?
In 1955 the Eliza program was nearly there (no Internet then).
Reply
  • Skeptical
I suppose you mean the black box problem. Let's assume we're talking specifically about the black box problem in the case of chatgpt.
There is a more superficial level of explanation that is often used to explain how chatgpt works. This level talks about tokens, context, concept spaces, etc, but it is a superficial level of explanation that emerges from a purely mathematical basis. ChatGPT doesn't care if we speak to it in English, Chinese, Spanish, programming languages, or first-order languages. It's a machine, all input is translated into a language a machine understands—machine language.
It operates on that translated input like a Turing machine, a very complex Turing machine that runs very complex algorithms. The output is preferably returned in the input language, although we can ask ChatGPT to provide it in another language. What's amazing is the efficiency and the very short time it takes to generate outputs.
It's a deterministic process, but there are hallucinations, inaccuracies, and it seems like a black box. This isn't due to chatgpt, the inputs that chatgpt can assume aren't like what a calculator has to assume. Your calculator simply responds "error", Chatgpt instead has hallucinations.
This increases the black box feeling because if we want to predict all responses, we would also have to be able to predict hallucinations and describe their structure, which is not currently possible.
javisot said:
[...] It's a deterministic process, but there are hallucinations, inaccuracies, and it seems like a black box. This isn't due to chatgpt, the inputs that chatgpt can assume aren't like what a calculator has to assume. Your calculator simply responds "error", Chatgpt instead has hallucinations.
This almost sound like a description of the human mind. With good reason I suppose.
Reply
I suppose I am. there's a bit of catch 22 about this because anything we could describe as genuine AI would have to produce results that would be 'fresh' to us and apparently come out of nowhere. A good creative AI machine would be doing what the very best human creatives do. I read a lot of ebooks (fiction) and so may of them could actually have been written by AI. They follow obvious rules, have an inappropriate balance of description, action and plot in general. The same applies to the 'turn the handle' music which we hear so often. An author / composer / artist who is genuinely creative digs very deep not their experience (within and outside of context). Down into details which we can't know about.
I might suggest that the Turing Test is itself inadequate because the 'observers' would be inadequate themselves. I guess it could only work for one excellent AI machine vs another excellent machine and then continue the process between other pairs. The result would be a machine which other machines cannot fathom its combinations of its knowledge. I'm suggesting that a human brain couldn't reliably be sure of spotting a genuine lack of human consciousness.
This thread, and the chase after knowing more about AI has made me think once more about the way we learn. My 18 month old is making progress with proto speech, walking, fine motor skills, manipulating adults, its bodily functions etc. etc. all at the same time. I was thinking this is a bit inefficient but, of course it's the best way. Every bit of knowledge and skill is totally context based. Without an accurate 'robotic' home, any AI machine would be missing a massive source of experience with which to build its human-ness. It's the ultimate example of GIGO.
Reply
Sabine talking about certain issues and papers that were discussed here, the video is from 15 minutes ago
Reply
  • Agree
Statistical Interpretive Machine
ie SIM ( simulator )
I think the way to go may be something along the lines of providing it, tabula rasa, with sensor inputs like vision, hearing, tactile sensors, etc., much like a human infant; then let it explore it's environment and deduce what it can. But what algorithm it should utilise I'm nowhere near qualified to even guess at... vague, I know...
EDIT: Thinking about it, that, or something similar, have probably been attempted.
Reply
  • Agree
Most of these chatbots do not get their data in real-time. Somewhere, an article I read said that its data cutoff was currently 2021. I.e. all it knows is three years old.
Or much, much older ...
I'm guessing that's a perfectly rational response. As far as it goes. :smile:
gleem said:
How will we identify AGI? ...
... I think we will know it when we see it.
One of my biggest fears is, that once the time comes the one presiding over a doomsday button won't be an actual AGI but something which only looks like one, while it's doing its business based on processed tiktok data, for example.
Reply
  • Skeptical
Rive said:
the one presiding over a doomsday button won't be an actual AGI but something which only looks like one.
There are a number of dictators around the world at this very moment with whom I don't feel safe. We can only hope that their lieutenants will always be in a position to control their excesses. Meanwhile, it's a lovely sunny day; tum tee tum.
Reply
That's actually a really scary thought. Thank you so much for putting that particular fear in my head! :smile:
Reply
  • Haha
Reply
If it spends its time watching TikTok it would probably just press the button on principle.
Reply
  • Haha
