Is Average Speed a Scalar quantity?
Average speed is classified as a scalar quantity because it is represented solely by a numerical value without direction. In contrast, velocity is a vector quantity that includes both speed and direction. The discussion highlights that the classification of average speed can vary based on the definition of scalar being used. In relativistic contexts, average speed may not be considered a scalar since it can change with different frames of reference. Overall, average speed remains a scalar in conventional terms, defined simply as a number.
shangriphysics
It depends on which definition of scalar you are using. It is not a scalar in the relativistic sense, since the value will change depending on your frame of reference. But it is a scalar in the sense that it is just a number, with no direction.
Likes 1 person
Thanks Jedi and Khashishi!
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 48 ·
