Is energy conservation necessary?
- Context: Graduate
- Thread starter atyy
- Start date
14 replies · 3K views
Discussion
- 2,692
atyy said:Must energy be conserved in a consistent Poincare invariant theory?
It's not necessary in Newtonian physics. Are things different in special relativity?
It would be easier to think about some hypothetical Galilean invariant theory that included violation of energy conservation. It's not obvious to me what such a law or theory would look like. I assume you have something in mind. Then we could play with what would happen if tried to make it Poincare invariant.
- 3,379
PAllen said:It would be easier to think about some hypothetical Galilean invariant theory that included violation of energy conservation. It's not obvious to me what such a law or theory would look like. I assume you have something in mind. Then we could play with what would happen if tried to make it Poincare invariant.
Hmm, I guess I was thinking about inelastic collisions, but nothing more specific than yet.
Would Stoke's law work?
- 9,573
- 2,692
atyy said:Hmm, would Stoke's law work?
I guess I was thinking about inelastic collisions, but nothing more specific than that.
Is Stokes law (of viscous friction) Galilean invariant? That is, first must write it in a form that that is invariant for fluid flow and direction [and direction of gravity. edit: direction of gravity not relevant for simple form of the law]
What is your proposed law for inelastic collisions? I have noticed you often write extremely terse entries and expect others to guess what you mean. Since you are proposing the exercise, why not specify a working example?
For example:
- would conservation of momentum hold?
- would you propose that heating does not occur or is not energy for the purposes of this game?
Mentor
- 50,835
- 26,842
atyy said:Hmm, I guess I was thinking about inelastic collisions
Inelastic collisions still conserve energy, don't they? They just don't conserve *kinetic* energy--some of the initial kinetic energy gets converted to heat (in the simplest case where there are no other internal energies involved).
[Edit: I see I hadn't fully understood the ground rules.]
- 2,692
Anyway, I think Stoke's law is pretty easy to write in a suitable form with fluid velocity and particle velocity as 3-vectors (norm of difference of vectors). For inelastic collisions, assume heat does not exist, and conservation of 3-momentum holds (KE is simply lost).
So, then the question becomes, can one design a Poincare invariant object to use in place of a 3-vector that does not bring in energy?
I wonder if there are any 'no go' theorems related to this? For example, there are well known theorems that no law satisfying Newton's third law, and allowing objects to interact at a distance, can be Poincare invariant.
- 3,379
PAllen said:I wonder if there are any 'no go' theorems related to this? For example, there are well known theorems that no law satisfying Newton's third law, and allowing objects to interact at a distance, can be Poincare invariant.
Yes, something like that would answer the question.
To go off topic a bit, in the case of "action at a distance", I believe the no go theorems have a loophole, so that things can act at a distance if they have a Lagrangian formulation but no Hamiltonian formulation (not sure if I got that backwards) - which I think is how Feynman and Wheeler's theory slips through.
- 9,573
- 2,692
atyy said:Yes, something like that would answer the question.
That would not satisfy Newton's third law. The delay would cause a violation. Specifically, this theory appears to reproduce Maxwell without a field. However, Maxwell interaction violates Newton's third law.
- 3,379
PAllen said:That would not satisfy Newton's third law. The delay would cause a violation.
Yes, that seems to be the case. Actually, I read your statement too quickly and thought you were talking about the Currie, Jordan, Sudarshan "no-interaction" theorem (which you weren't).
Parlyne
- 551
- 3
Poincare invariance implies conservation of energy (also, momentum, angular momentum, and the quantities which serve as the generators of boosts from a group theoretic perspective but which don't, to my knowledge, have any generally accepted name). Remember that Noether's theorem relates symmetries to conservation laws. Energy, in particular, is related to time-translation symmetry, which is the the time component of the translational part of Poincare symmetry.
Mentor
- 37,153
- 16,238
If energy were not conserved and the theory were Poincare invariant then it could not be expressed in terms of a Lagrangian.atyy said:Must energy be conserved in a consistent Poincare invariant theory?
If a theory can be expressed in terms of a Lagrangian then Poincare invariance implies time translation invariance which implies energy conservation.
I believe that it is possible to come up with theories that cannot be expressed in terms of Lagrangians, but I have never actually studied that in depth.
- 2,530
And what do you mean by "energy"? If energy is the thing that is conserved in a Lagrangian theory due to a specific symmetry, then your question is not meaningful. It seems that you are looking for an example in a different situation, so you need to say what energy is.
- 9,573
- 2,692
DaleSpam said:If energy were not conserved and the theory were Poincare invariant then it could not be expressed in terms of a Lagrangian.
Friction (that is not modeled microscopically) is often cited as a law that cannot be expressed with any action principle.
- 9,573
- 2,692
Parlyne said:Poincare invariance implies conservation of energy (also, momentum, angular momentum, and the quantities which serve as the generators of boosts from a group theoretic perspective but which don't, to my knowledge, have any generally accepted name). Remember that Noether's theorem relates symmetries to conservation laws. Energy, in particular, is related to time-translation symmetry, which is the the time component of the translational part of Poincare symmetry.
And this is consistent with the problem of friction in Galilean relativity. Modeled macroscopically, a friction law will not be time symmetric, thus violates energy conservation (unless heat is introduced into the laws).
Then, the issue for Poincare invariance is that, unlike Galilean relativity, a boost cannot be separated from time translation.
- 3,379
Thanks Parylne, Dale Spam, Matinbn and PAllen for the comments! Based on them, I googled "relativistic Brownian motion", and found http://arxiv.org/abs/0812.1996 and http://arxiv.org/abs/0902.4651 . I haven't read them yet, but it seems a place to look.
Graduate A global energy conservation law in general relativity
- Kostik
- · Replies 36 ·
- Special and General Relativity
- Replies
- 36
Undergrad Energy conservation in general relativity
- KleinMoretti
- · Replies 12 ·
- Replies
- 12
Undergrad Does energy conservation hold for all types of dark energy?
- KleinMoretti
- · Replies 4 ·
- Replies
- 4
High School Energy Conservation w/ Charged Battery Time Travel
- Lars Krogh-Stea
- · Replies 3 ·
- Replies
- 3
High School How does general relativity show energy conservation?
- sqljunkey
- · Replies 5 ·
- Replies
- 5
Undergrad Recovering Newton's energy conservation law for an Earth's lab
- epovo
- · Replies 35 ·
- Replies
- 35
Undergrad Schwarzschild: Energy Conservation at Finite r
- kent davidge
- · Replies 1 ·
- Replies
- 1
Graduate Is Energy conservation among sectors (EM,GR,QM) a principle?
- Roberto Pavani
- · Replies 28 ·
- Classical Physics
- Replies
- 28
Undergrad Is gravitational energy necessary in general relativity?
- KleinMoretti
- · Replies 6 ·
- Replies
- 6
High School Why a ball bounces back to height h using momentum and energy conservation
- Dark85
- · Replies 6 ·
- Mechanics
- Replies
- 6
