Is Every Hermitian Operator Observable?
  • Context: Graduate
  • Thread starter Thread starter sweet springs
    Observable
58 replies · 12K views
sweet springs
Hi.
I know that operator of observable is Hermitian. Reciprocally, any Hermitian is observable? If not, showing some examples are appreciated.
Regards.
No, for example consider the identity operator. Certainly Hermitian, but if it were an observable then that would imply that we can directly observe the probability density.
sweet springs said:
Hi.
Regards.
The identity matrix is one example, so is any (real) constant times the identity matrix.
Another example is the so called "number operator" [tex]aa^{\dagger}[/tex], which is the product of lowering (annihilation) and raising (creation) operators. It is called the number operator because it returns the quantum number of the state it is applied to.
Hi. Thanks Monocles and SpectraCat.
Definition of observable in Dirac II-10 is "We call a real dynamical variable whose eigensates form a complete set an observable."
Identity operator satisfy eigenvalue eauation Iψ=1ψ and these {ψ} form a complete set.
Thus identity operator is observable. Am I wrong?
Regards.
I disagree. The identity operator is 1 in the case of a particle existing and 0 in the case of it not existing. Therefore, it is an observable value. A value being observable doesn't mean that its entire distribution is observable. Only eigenvalues and average values need to be observable. In the case of the identity operator, every state has the same eigenvalue, so the operator doesn't tell you much.
The number operator is also observable since it is H/(hw)-1/2, and that is a measurable value for the quantum harmonic oscillator.
I'd be hard pressed to say that every Hermitian matrix in Quantum Mechanics corresponds to something measurable... But if a hermitian matrix appears as part of the Hamiltonian, then I'd say it's something observable.
Basically, if you can build a device that depends on the value of an operator, then that operator can be said to be "observable", either directly or indirectly.
I agree with LukeD.
Also if [tex]A[/tex] and [tex]B[/tex] are hermitian, [tex]AB+BA[/tex] and [tex]i(AB-BA)[/tex] are also hermitian. If, say, [tex]A=\hat{x}[/tex] and [tex]B=\hat{p}[/tex], It'd be hard to come up with the measuring devices, let alone the meaning of the observables.
Since you read Dirac, I have to add that the postulate that, to each observable there corresponds a Hermitian operator, is motivated because of the spectral theorem that the set of all eigenvectors of a Hermitian operator forms an orthonormal basis. (I remember Dirac didn't even mention linear algebra in the book.)
Edit: What I wanted to say in the last paragraph is that, Dirac was right to say that we need a complete set of eigenstates, but he didn't have this theorem to back it up rigorously.
Hi, LukeD and Truecrimson.
Now I tend to consider any hermitian is observable.
Thank you.
The number operator is certainly an observable, there are actually quite a few ways to experimentally count the number of photons in a number state (and you don't have to do it "indirectly" by measuring the total energy of the system).
Ok, I guess I see what you are saying ... if we look for a particle, and it is there, by definition we have just applied the identity operator, so it is kind of by default included in any measurement we make. Is that another way to put it?
Yeah, that was a mistake on my part. I was thinking in terms of building a device to measure just the quantum number, but of course if we measure the energy of an HO eigenstate, we immediately infer the quantum number.
So, I guess I don't know any examples of Hermitian operators that don't correspond to observables. I guess what Truecrimson said about being able to compose complicated Hermitian operators out of other Hermitian operators might work, but that seems like a practical approach that misses the OP's point.
SpectraCat said:
Ok, I guess what Truecrimson said about being able to compose complicated Hermitian operators out of other Hermitian operators might work, but that seems like a practical approach that misses the OP's point.
Now I think I see what you mean, reminding me of what Ballentine says in his book.
Dirac, to whom we are indebted for so much of the
modern formulation of quantum mechanics, unfortunately used the word
"observable" to refer indiscriminately to the physical dynamical variable
and to the corresponding mathematical operator. This has sometimes led
to confusion. There is in the literature a case of an argument about whether
or not the electromagnetic vector potential is an observable, one party
arguing the affirmative on the grounds that the operator satisfies all of the
required conditions, the other party arguing the negative on the grounds
that the vector potential cannot be measured.
So yes, sweet springs' conclusion that "any hermitian is observable" is right in a mathematical sense.
If we define "observable" to mean "bounded self-adjoint operator", then of course every hermitian operator is an observable. We defined them to be. There is however another approach. We define our "observables" operationally, by describing the devices that are supposed to measure them. The question is then, what sort of mathematical object should we use to represent observables mathematically? This sort of thing is discussed in detail in books on the mathematics of QM, e.g. "An introduction to the mathematical structure of quantum mechanics", by F. Strocchi, and "Mathematical theory of quantum fields" by H. Araki.
I don't know this stuff myself, but I get that the basic idea is to start with a C*-algebra, define a "state" as a positive linear functional on the C*-algebra of observables, and then invoke the appropriate mathematical theorems to prove that abelian C*-algebras give us classical theories and non-abelian C*-algebras give us quantum theories. (The C*-algebra is then isomorphic to the algebra of bounded self-adjoint operators on a complex separable Hilbert space).
In this approach, it's not the case that every member of the C*-algebra corresponds to a measuring device, but I don't really have any more information on that. Perhaps someone can read those books and tell the rest of us. :smile:
Hi,
I have a new wondering.
In 9.2 of my old textbook Mathematical Methods for Physicists, George Arfken states,
1. The eigenvalues of an Hermite operator are real.
2. The eigen functins of an Hermite operator are orthogonal.
3. The eigen functins of an Hermite operator form a complete set.*
* This third property is not universal. It does hold for our linear, second order differential operators in Strum-Liouville (self adjoint) form.
The * suggests that not all Hermitian are OBSERVABLE. Can anyone suggest me some examples?
Regards.
Wait a moment -- isn't the identity operator supposed to correspond to a "trivial" measurement that, no matter what is going on in reality, always returns the number "1"?
Hi, Hurkyl
Let me confirm my understanding.
IΨ=1Ψ
Any state is eigenvector of identity operator I with eigenvalue 1. I is both Hermitian and Observable.
I am interested in some examples if any, of operators that is Hermite but not observable in the sense that whose eigenvectors do not form a complete set.
Regards.
How do you define this? Isn't it just that the identity can be expressed as [itex]\sum_a|a\rangle\langle a|[/itex] where the sum is over the eigenvalues of some operator A and the eigenvector corresponding to the eigenvalue a is written as |a>? In that case, any projection operator for a closed proper subspace will do. (Its eigenvalues are 0 or 1, so any sum over its eigenvalues would only contain two terms). Such an operator is however a mathematical representation of an operationally defined observable. (It corresponds to a device that measures A and only outputs 1 if the result is in the given range, and 0 if it's not). The simplest example is |a><a|.
I agree with Hurkyl about the identity operator.
this is an interesting post, i'd like to keep myself updated...[:biggrin:
Hi, Fredrik
Let me ask you a question in order to check if I understand your point.
{|x>} is a complete set of eigenvectors of coordinate. ∫|x><x| dx =I. Then
a) Operator say Q=∫x>0 |x><x| dx is Hermitian but not Observable, because its eigenvector set does not contain |x> x<0. Eigenstates of Q do not form a complete set.
b) Q|x> = 0|x> for x<0. The subspace composed of {|x>|x<0 } is eigensubspace of Q with eigenvalue 0. So eigenstates of Q form a complete set.
Which one (or another one?) is the right answer?
Regards.
I wouldn't define an observable that way. (I don't think anyone does). Your a) is essentially correct apart from the terminology. (I also wouldn't use the position operator as an example, because it doesn't actually have any eigenvectors. It takes some fairly sophisticated mathematics to make sense of what |x> means).
Your b) is wrong, if the definition of of "complete set" is that the identity can be expressed as a sum of projection operators for 1-dimensional subspaces with exactly one term for each distinct eigenvalue.
Hi, Fredrik
I repeat your teachings.
An operator is OBSERVABLE whether it has degeneracy or not. For example squqre of momentum P^2 is observable while eigenspace for eigenvalue p^2 has two-fold degeneracy of |p> and |-p>.
We cannot (or must not?) find eigenspace for eiganvalue 0. [STRIKE]The idea that ALL THE NOT PROJECTED states degenerate and belong to eigenspace for eigenvalue 0 was wrong.[/STRIKE]
Thanks.
I don't understand that last sentece, but think of it this way: Suppose that A has a degenerate spectrum. Then we can't write [itex]\sum_a|a\rangle\langle a|=I[/itex]. But we should be able to find a second operator B that commutes with A, and find state vectors [itex]|ab\rangle[/itex] that are eigenvectors of both A and B. If we now have [itex]\sum_{a,b}|ab\rangle\langle ab|=I[/itex], then {A,B} is a "complete set of commuting observables". If not, then we should be able to find a third operator C that commutes with both A and B, and simultaneous eigenstates [itex]|abc\rangle[/itex]. We can keep finding more and more observables until all the degeneracy is removed. Let's say that the last operator we need is Q. Then our set {A,B,C,...,Q} is a complete set of commuting observables.
I think that when this happens, there's always an observable X with non-degenerate spectrum such that all of the members in the complete set can be expressed as functions of X, e.g. [itex]A=f_A(X), B=f_B(X),\dots,Q=f_Q(X)[/itex].
Avodyne's post here explains some of the details.
Fredrik said:
...Suppose that A has a degenerate spectrum. Then we can't write [itex]\sum_a|a\rangle\langle a|=I[/itex]...[/tex]
You can't write that because [tex]|a\rangle\langle a |[/tex] is not defined for a degenerate spectrum. It's not just that the lhs doesn't equal the right hand side, the left hand side doesn't mean anything.
That would be a bad definition of a complete set.
A set (of vectors) is complete if it spans the vector space. The set of eigenvectors of an observable is complete, whether or not there is degeneracy.
The notion of completeness with regards a complete set of mutually commuting observables is a separate one.
Hi. I have further questions on eigenvalue 0.
sweet springs said:
IΨ=1Ψ
Here Observable means operator whose eigenstates form a complete set.
#1
Null Operator O
OΨ=0Ψ
Any state is eigenvector of identity operator O with eigenvalue 0. So O is Hermitian and Observable.
The both discussion seem to be similar but I feel the former right and the latter wrong. Both are wrong? Can anyone show me the right way?
#2
Measurement of some physical variable, for example coordinate X, leads value 0. X|0>=0|0>. |0> is a specific vector, δ(x). This eigenvalue equation looks like above OΨ=0Ψ, Ψ is any vector. Don't we have to distinguish these two types of eigenvalue equations for eigenvalue 0 ?
Regards.
Yeah, I should have written something like [itex]|a\sigma\rangle[/itex] instead of just [itex]|a\rangle[/itex], and written the sum in a different way too. I was a bit sloppy there.
I don't think I've heard anyone define a "complete set of vectors" that way. I've heard terms like "maximal orthonormal set", but not "complete set". That's why I've been asking sweet springs to clarify what he meant. Hm, I guess it would make sense to define "complete set" as one that has a maximal orthonormal set (i.e. a basis) as a subset.
That case doesn't need to be treated separately.
And by "complete set" you mean a set that has a basis as a subset? I think it's much better to define observables operationally, and then say that they are represented mathematically by bounded self-adjoint operators. (The set of eigenvectors of a bounded self-adjoint operator is always "complete" in the sense defined above).
sweet springs said:
#1
Null Operator O
OΨ=0Ψ
#2
Regards.
Some of the symbols you're typing don't display properly for me, on either of my two computers. It's very confusing. And as I said before, the position operator isn't the greatest example, since it isn't bounded, and doesn't have eigenvectors. You have to define a "rigged Hilbert space" just to be able to define the "eigenstates" [itex]|x\rangle[/itex].
Non-relativistic Quantum Mechanics said:
A set {f_i} of vectors is complete iff any vector in H can be written as a linear combination of vectors from the set {f_i}. A complete set of orthonormal vectors forms a basis.
[pg 149]
Another use of the word complete is in the description of a vector space. This concept is again trivial for [finite dimensional euclidean space] but non-trivial for H.
...[some stuff on the convergence of Cauchy sequences]...
All finite dimensional vector spaces are complete. That this is true for infinite dimensional Hilbert spaces is a deep theorem of analysis known as the Riesz-Fischer Theorem.
Perhaps other texts avoid the word 'complete' due to the ambiguity which it creates (see, eg, this thread!)
That first definition is a bit strange, mostly because (I think) all the math books define a "linear combination" to have a finite number of terms. The last sentence is odd too. A Hilbert space is complete by definition, so I guess they're using a non-standard definition of that too.
Here's an excerpt from Neumaier & Westra (quant-ph/08101019) that might
give insight into the algebraic approach from a different perspective.
(This is from the start of section 5.1.)
Any fundamental description of physical systems must give account of
the numerical values of quantities observable in experiments when the
system under consideration is in a specified state. Moreover, the form
and meaning of states, and of what is observable in principle, must be
clearly defined. We consider an axiomatic conceptual foundation on the
basis of quantities and their values, consistent with the conventions
adopted by the International System of Units (SI) [238], who declare:
"A quantity in the general sense is a property ascribed to
phenomena, bodies, or substances that can be quantified for, or
assigned to, a particular phenomenon, body, or substance. [...] The
value of a physical quantity is the quantitative expression of a
particular physical quantity as the product of a number and a unit, the
number being its numerical value."
They also have a footnote:
We deliberately avoid the notion of observables, since it is not clear
on a fundamental level what it means to observe something, and since
many things (such as the fine structure constant, neutrino masses,
decay rates, scattering cross sections) which can be observed in nature
are only indirectly related to what is traditionally called an
observable in quantum mechanics. [...]
IMHO, adherence to the SI term "quantity" fosters clearer thinking
about this stuff.
They go on to give a set of axioms for algebras of quantities, and
define states as linear mappings from a space of quantities to a space
of ordinary numbers. This is the basic idea of the algebraic approach.
Any class of physical systems is defined by specifying an algebra of
quantities.
As to whether any element of the algebra can be measured... that gets
tricky. Consider angular momentum [itex]J_i[/itex]. To measure the "pose"
of a system relative to that of another system from the same class we
must the consider the rotation group, which is generated by angular
momentum. Although [itex](\theta^i J_i)^2, (\theta^i J_i)^3[/itex] might be hard to imagine
measuring, we have no trouble imagining a finite rotation given by [itex]\exp(i\theta^i J_i)[/itex].
In the rest of the section 5, Neumaier & Westra go on to explain how
their axioms encompass both classical and quantum systems (including
thermodynamics/statistics). The algebraic approach thus unifies
all of physics under a more coherent umbrella. In section 5.4, they
discuss limits of experimental resolution and uncertainty, and show
how the essential difference between "classical" and "quantum" boils
down to commutativity of quantities.
Ordinary Hilbert spaces become merely a convenience, appropriate to
certain cases, on which the quantity algebra can be represented as
operators.
HTH.
Fredrik said:
That first definition is a bit strange, mostly because (I think) all the math books define a "linear combination" to have a finite number of terms. [...] A Hilbert space is complete by definition, so I guess they're using a non-standard definition of that too.
A "linear combination" in an arbitrary vector space can certainly be an infinite sum.
The case of Hilbert space is bit trickier because all vectors therein must have finite
norm. But an arbitrary infinitely-long linear combination does not necessarily have
finite norm, hence the need to place restrictions on the sum in order to have a
Hilbert space. So the two notions of "complete" are related.
Thanks for the reference. That one goes on my to-read list for sure. You know, it's not hard to post a direct link to the article. :wink: (I can usually search arxiv.org for the code you posted, and be taken directly to the right page, but this time it didn't work).
Regarding "linear combinations", I wouldn't be surprised if different people define the term in different ways, but I think it's more appropriate to define a linear combination to only have a finite number of terms. This is why: If V is a vector space over a field F, and S is a subset of V, the "subspace generated by S" (or "spanned" by S) can be defined as any of the following
a) the smallest subspace that contains S
b) the intersection of all subspaces that contain S
c) [tex]\Big\{\sum_{i=1}^n a_i s_i|a_i\in\mathbb F, s_i\in S, n\in\mathbb N\Big\}[/tex]
These definitions are all equivalent, and the fact that every member of the set defined in c) can be expressed as [itex]\sum_{i=1}^n a_i s_i[/itex], with n finite, seems like a good reason to define a "linear combination" as having only finitely many terms. That definition means that the subspace generated by S is equal to (instead of a subset of) the set of linear combinations of members of S. (Note that all of the above is true even if some subset of S is an infinite orthonormal set).
