Is graphing the best method for finding the limit of a rational function?
  • Context:
  • Thread starter Thread starter nycmathdad
    Limit
5 replies · 2K views
nycmathdad
Find the limit of x/(x^2 - 4) as x tends to 2 from the right.
If I plug x = 0, I will get 0/-4 = asymptote. Again, is graphing the best to do this one?
I can also create a number line.
<----------(-2)----------(0)---------------(2)-------->
I can then select values for x from each interval. I then plug those values into the given function to see if the intervals are positive or negative.
True?
Beer soaked fill in the boxes hint follows.
True?
As x approaches 2 from the $\boxed{?}$, x approaches $\boxed{?}$ and
$x^2−4$ approaches $\boxed{?}$ from the $\boxed{?}$. Therefore,
the ratio $\frac{x}{x^2−4}$ becomes $\boxed{?}$ in the $\boxed{?}$ $\boxed{?}$, so $$\mathop {\lim }\limits_{x\to2^+} \frac{x}{{x^2-4}} = \boxed{?}$$
Note: Number of question marks corresponds to number of letters or symbols.
Again, to support whatever conclusion you get from filling in the boxes, make a table with the following values of x: 2.1, 2.01, 2.001
Do try to take the time to read your book instead of insisting on your ineffective method:
2. I don't have time to read the textbook lessons. I usually make use of the chapter outline as my guide. For example, Section 1.5 is all about Limits at Infinity. I then search You Tube for Limits at Infinity video lessons. I take notes on everything said in the video lesson. I work out all sample questions with the video instructor. Is this a good way to learn the material?
For x> 2 $x^2- 4$ is positive. As x approaches 2 from the right, $\frac{x}{x^2- 4}$ goes to $+\infty$.
For x< 2 $x^2- 4$ is negative. As x approaches 2 from the -eft, $\frac{x}{x^2- 4}$ goes to $+\infty$.
x= 2 is a vertical asymptote.
So the answer is positive infinity.
No. I miswrote (I'm doing that too often lately!) . I apologize for that.
I meant to say "For x< 2 $x^2- 4$ is negative, As a approaches 2 from the left, $\frac{x}{x^2- 4}$ goes to $- \infty$". NEGATIVE infinity, not positive infinity. $\frac{x}{x^2- 4}$ does NOT have a limit as x goes to 2.
Ok. I will practice more problems before moving on in the textbook.
