Is it possible for a person in motion to fall over a ledge?
The discussion centers on the physical possibility of a person falling over a balcony railing while running. A person measuring 183cm and weighing 82kg has a center of gravity approximately at 105cm. Given that the balcony railing is 108cm high, it is established that the individual could indeed fall over the railing due to the dynamics of motion, where the center of mass can shift significantly during running. The conversation highlights the importance of understanding biomechanics and suggests that experimental techniques are more reliable than simulations for demonstrating this phenomenon.
  • Understanding of classical mechanics
  • Knowledge of human biomechanics
  • Familiarity with the concept of center of mass
  • Basic principles of physics experiments
  • Research forensic biomechanics and its applications in legal contexts
  • Explore experimental techniques for studying human motion
  • Learn about the physics of center of mass in dynamic systems
  • Investigate simulation tools for modeling physical interactions
This discussion is beneficial for forensic scientists, biomechanics researchers, and anyone interested in the physics of human motion and its implications in safety and legal scenarios.
jimmypantspants
The facts are that the person is 183cm, 82kg, meaning his center of gravity is about at 105cm, he was running towards a railing of a balcony that is 108cm high, and allegedly hit the railing then fell over. Is this physically possible?
Of course. Silly question, IMO.
yes.
You mean "fell over the railing"? Yes, sounds possible. A running human is not a rigid sliding block, and the center of mass moves more than 3cm vertically during running.
The upper part of the body would rotate around the railing, moving his CoM towards the wrong side and bringing his feet off the floor in a somersault.
Thanks for the reply! Is there any proof I could use in an official debate? A law or theory ...?
In a court of law you would need some recognized expert on forensic bio-mechanics. But in order to demonstrate that it is possible you just could reproduce the situation (not on the balcony).
Ok thank you! Is there any way I could do so without physically recreating it? A physics simulation? A bit of a stretch hahaha but I don't know what else.
If you run, your center of balance is higher so you have time in the air to complete your stride, unless you are jazz-running or something. Since there are so many open variables here, you probably want to switch your question over from, "is it possible" to "is it likely". As the barrier gets higher, it gets less likely to fall over; but certainly it is still possible if the person sort of leaps over.
If the question is just: "Is it possible?", then an experiment is much simpler, quicker, more reliable and requires much less expertise than a computer simulation.
How did you work out his centre of gravity was at 105cm?
Well approximately that, because i saw that the center of mass of a male is 58% up his body
What are the physics behind falling over a railing? As in someone running into a balcony railing and falling up and over?
It's best to use experimental techniques to answer questions like that... :wink:
You have the simple part: classical mechanics. And the complicated part: Complex human anatomy, with muscle contractions triggered in a way that is unpredictable in such a extreme situation. This basically makes any type of modeling of such an event pure guess work.
See post #5 above.
Strange things happen when flexible objects fall over "railings"..
12K
  • · Replies 20 ·
9K
  • · Replies 76 ·
15K
  • · Replies 24 ·
