Is it possible to create weightless rotors using magnetic fields?
  • Thread starter Thread starter MReX19985
    Magnetics
The discussion centers around the concept of creating weightless rotors using magnetic fields, specifically through an electric motor design with uniform poles and an iron core capable of generating eddy currents. Participants debate the feasibility of this idea, questioning the notion of a weightless rotor since iron is inherently heavy. The potential application for no-contact vehicle brakes is highlighted, alongside considerations for using high voltage and low current to reduce heat. Concerns are raised about the need for a solid engineering background to validate such innovative ideas, emphasizing the importance of calculations and scientific principles. Ultimately, the conversation concludes with skepticism about the practicality of the proposed concepts, leading to the thread's closure.
MReX19985
Hello
I had an idea a while ago
If we have an electric motor with 8 poles where all poles are the same (north or south) 360 degree
And rotor is iron core which can have eddy current
What came in my mind is the rotor will be wightless but don't know what will happen
Perfect use of this idea is vehicle brakes with no contact
Another thing came in mind is why useing high current when we can use high voltage with littel amerage where we have a very amount of gauss and reducing heat on rotor
Looking forward to see your opinions,Thanks
Why would the rotor be weightless, it is iron. Iron is not weightless.
Yes, eddy currents are commonly used as a no-contact braking mechanism
Likes MReX19985
Well thanks for your replay and sorry my question was not clear
In my thinking rotor would be wightless becase of the magnatic field will pull it 360 degree, am i right?
The part two is to make this breaks act as a motor and i saw the stepper motor, make the stator poles do steps simultaneously 8 poles (3 right 3 left) 2 off
Make motor pull insted of repelling with hight voltage low current
I like your curiosity and inventiveness. However, to succeed in engineering, you have to do a lot more work than just throw out ideas. You need to do calculations to be sure things will work before presenting those ideas to others. In English we have a saying, "Ideas are a dime a dozen." Which means we can have more ideas than there are grains of sand in the Sahara Desert, but they are of little value without the extra effort to sort the good ones from the bad ones.
I urge you to continue your studies. If you study engineering, you will learn tools and methods you can use to evaluate ideas.
Likes MReX19985
Thanks sir you answered my question
I have everything i need , But work
I'm already planned to work on this project to come up with revolutionary invention sounds too big , But that makes me feel comfortable
But i made this topic because i had douts
unfortunately is seems you don't want to listen to advice concerning your doubts :frown:
And without a strong physics and engineering background, do you really think you could come up with something that hasn't already been thought of ?
You can't play the game if you don't know the rules :wink:Dave
Likes MReX19985
I'm a good listener, Need advice that's why i have douts about myself,
I used to educate myself everyday on the internet and seen a lot of useful things online
Thanks Dave
Likes davenn
Just for a moment, consider the magnets replaced by elastic bands. They are pulling 360 degrees in all directions (just like the magnets were).
Does that make the core weightless? No.
Likes MReX19985
LOL, that not what i meant, for a moment you are right but what gives the wight is gravity which is made from the earth
I'm talking about a small gravity made from strong manatic field (electromagnets) about 200 tesla 200 volts 200,000,000,000 gauss
In the end i can't talk too much until i prove it physically
Current motor designs both attract AND repel - flipping at the moment of closest approach.
http://www.dynamicscience.com.au/tester/solutions1/electric/3poledcmotot.htmlIf you were to make a motor that only attracts, it would not be as strong/fast/powerful as a modern motor.
Likes MReX19985
I don't know what you're getting at, but it appears to be beyond the realm of current science and therefore doesn't belong here on PF. If you believe I am mistaken please contact myself or another mentor.
Thread locked.
