Is it possible to create weightless rotors using magnetic fields?
  • Level: Graduate
  • Thread starter Thread starter MReX19985
    Magnetics
10 replies · 2K views · last reply
MReX19985
Hello
I had an idea a while ago
If we have an electric motor with 8 poles where all poles are the same (north or south) 360 degree
And rotor is iron core which can have eddy current
What came in my mind is the rotor will be wightless but don't know what will happen
Perfect use of this idea is vehicle brakes with no contact
Another thing came in mind is why useing high current when we can use high voltage with littel amerage where we have a very amount of gauss and reducing heat on rotor
Looking forward to see your opinions,Thanks
Why would the rotor be weightless, it is iron. Iron is not weightless.
Yes, eddy currents are commonly used as a no-contact braking mechanism
Well thanks for your replay and sorry my question was not clear
In my thinking rotor would be wightless becase of the magnatic field will pull it 360 degree, am i right?
The part two is to make this breaks act as a motor and i saw the stepper motor, make the stator poles do steps simultaneously 8 poles (3 right 3 left) 2 off
Make motor pull insted of repelling with height voltage low current
I like your curiosity and inventiveness. However, to succeed in engineering, you have to do a lot more work than just throw out ideas. You need to do calculations to be sure things will work before presenting those ideas to others. In English we have a saying, "Ideas are a dime a dozen." Which means we can have more ideas than there are grains of sand in the Sahara Desert, but they are of little value without the extra effort to sort the good ones from the bad ones.
I urge you to continue your studies. If you study engineering, you will learn tools and methods you can use to evaluate ideas.
Thanks sir you answered my question
I have everything i need , But work
I'm already planned to work on this project to come up with revolutionary invention sounds too big , But that makes me feel comfortable
But i made this topic because i had douts
unfortunately is seems you don't want to listen to advice concerning your doubts :frown:
And without a strong physics and engineering background, do you really think you could come up with something that hasn't already been thought of ?
You can't play the game if you don't know the rules :wink:Dave
I'm a good listener, Need advice that's why i have douts about myself,
I used to educate myself everyday on the internet and seen a lot of useful things online
Thanks Dave
Just for a moment, consider the magnets replaced by elastic bands. They are pulling 360 degrees in all directions (just like the magnets were).
Does that make the core weightless? No.
LOL, that not what i meant, for a moment you are right but what gives the wight is gravity which is made from the earth
I'm talking about a small gravity made from strong manatic field (electromagnets) about 200 tesla 200 volts 200,000,000,000 gauss
In the end i can't talk too much until i prove it physically
Current motor designs both attract AND repel - flipping at the moment of closest approach.
Diagram of a three-pole DC motor on a red and blue magnet pair, with an AA Duracell battery connected by wires and an arrow labelled attraction on the rotor.
http://www.dynamicscience.com.au/tester/solutions1/electric/3poledcmotot.htmlIf you were to make a motor that only attracts, it would not be as strong/fast/powerful as a modern motor.
  • Diagram of a three-pole DC motor on a red and blue magnet pair, with an AA Duracell battery connected by wires and an arrow labelled attraction on the rotor.
I don't know what you're getting at, but it appears to be beyond the realm of current science and therefore doesn't belong here on PF. If you believe I am mistaken please contact myself or another mentor.
Thread locked.
