Is it possible to dissolve diamonds with water?
  • Thread starter Thread starter pkt
    Dissolve Water
Diamonds cannot be dissolved in water under normal conditions. The discussion clarifies that while superheated water can etch diamonds when subjected to extreme pressure, this process does not equate to dissolution. The term "dissolve" is defined conventionally, and etching is considered a form of material removal rather than true dissolution. The community emphasizes the importance of precise terminology in scientific discussions.
  • Understanding of diamond structure and properties
  • Knowledge of etching processes in materials science
  • Familiarity with superheated water and its effects on materials
  • Basic concepts of dissolution versus etching
  • Research the effects of superheated water on various materials
  • Learn about etching techniques in materials science
  • Explore the chemical properties of diamonds and their resistance to solvents
  • Investigate the physics of pressure and temperature in material interactions
Materials scientists, chemists, and anyone interested in the properties and behaviors of diamonds in various environments.
pkt
Chemistry news on Phys.org
No.
Do you see any reason to expect that?
No. At least not in any relevant amount.
@pkt if you knew the answer why did you post the question?
PF is here to help students with questions from STEM subjects. We are a team of volunteers here trying to help out and we don't pose questions to fool others. It is our hope that you won't repeat this strategy in the future.
That is not really "dissolving diamonds in water". They superheated water and put it under extremely high pressure between diamonds and graphene. That damaged the diamond.
pkt said:
If this is what you mean by "dissolve", then you have a very strange and unconventional definition of it. So not only should you have posted this link at the very beginning of your post, you should have also revealed your personal definition of "dissolve".
Otherwise, this is not what we conventionally will call "dissolve".
Zz.
Smells like a philosopher's spirit. AFAIK, this community is not about that life.
[Mentor's note: Some unnecessary snark, in violation of the Physics Forums rules, has been edited out of this post]
Etching is very much dissolving.
You just didn't understand the article you linked later, or you phrased your question in a wrong way.
Can helium dissolve a diamond? No. But if you shoot helium nuclei (or atoms) at a diamond you can certainly etch some material away.
When you get to the bottom of a hole, it's best to stop digging.
What they are doing is not dissolving since the water does not contain any carbon in solution afterwards.
pkt said:
stump the egghead and I got two on the first try
Again, when you get to the bottom of a hole, it's best to stop digging.
Or a laser. Does that mean carbon dissolves in light?
Any form of erosion will etch
But the process of abrasion with a non solvent will only form a suspension not a solution
  • · Replies 18 ·
