Is it possible to have synchronized clocks in a rotating system?
  • Context: Undergrad
  • Thread starter Thread starter Foppe Hoekstra
    Clocks Rotating System
  • #31
Foppe Hoekstra said:
If two coinciding clocks, that have the same constant speed in the same direction, are sync in their co-moving frame, I should say that they are also sync in the observing rest frame. Isn't it?
Then they are the same clock because they have exactly the same movement and will always coincide in all frames.
  • #32
PeterDonis said:
No, it won't, because the clocks were never synchronized in the rest frame of the track to begin with. You said they were originally synchronized in the co-moving inertial frame of the train while it was on the straight track. That means that, in the rest frame of the track, the clocks were not synchronized: the clocks towards the front of the train were behind and the clocks towards the rear of the train were ahead. And since all of the clocks continue to have the same speed in the rest frame of the track (they just change direction as they go around the circle), their tick rates, as seen in the rest frame of the track, remain the same. Which means that when the clocks at the front and rear of the train meet momentarily as the front clock completes the circle, they will not read the same: the front clock will be behind the rear clock by the same amount it always has been.
Quite a few posts ago you were told that the easiest way to analyze this problem was in the ground frame (i.e., the rest frame of the track). Now you see why.
But in the moving frame they are sync. Let's throw in an extra clock at the rear that is sync wtih the other clock at the rear.
How is the rest frame to see the difference between the two sync rear clocks and the sync rear and front clock?
  • #33
jbriggs444 said:
Thanks. I was trying to figure a way to phrase that quibble without becoming confrontational.
As long as you write in clear language that is not more complicated then necessary (I am not a native speaker in English) you may be as confrontational as necessary.
  • #34
Only before the train enters the circle. Once parts of the train start accelerating, it not even clear what the "moving frame" is. But whatever frame you construct for the train on the circle, it will have to conclude that the clocks have an offset when they meet, for this simple reason:
They are initially not in sync in the rest frame, and their offset doesn't change until they meet.
  • #35
First of all, I think we should be just as less interested in the rest frame (of the rail) as in any other frame
The reason we choose to work in the rest frame of the rail is that it's the easiest one to work in. The clocks are initially incorrectly zeroed, and tick at a constant rate. Therefore the front and rear train clocks do not show the same time. The end.
You want to repeat this analysis in another frame where the clocks are initially synchronised but then have different speeds, so tick at different rates. The rear clock remains stationary while the front clock moves and is time dilated, so will not accumulate as much time. You seem to think that this frame is somehow exempt from time dilation - or at least that's what you need to believe for the clocks to remain synchronised.
  • #36
This looks to me like circular reasoning.
And the reason why I do not start at the rest frame is because the outcome of that is already clear to me. I just think it should agree with reasoning that starts at the moving frame. But strangely it doesn't.
  • #37
You haven't presented any analysis of the whole process from the "moving frame". In fact, you haven't even properly defined the "moving frame" for the whole process.
  • #38
It's an accelerating frame. That is a clue that it needs to be analyzed more carefully than "two clocks are moving at the same speed in the same direction at the same event, therefore they are synchronized in spite of their different histories".
  • #39
By whom?
From the moment the front clock reaches the junction between the straight track and the circle, the front clock is moving with speed v in a circle for the time that is necessary to round the circle and during that time the rear clock is also moving with the same speed and precisely ends up at the junction.
  • #40
Relative to the track frame, yes. Relative to the train frame (if it exists), it is stationary. Pick one. Do not pick both.
during that time
A strong hint that the relativity of simultaneity has not been considered.
  • #41
I thought it is clear that for both the rear and the front clock I chose the track frame (the junction).
  • #42
In the inertial frame in which the train is at rest before it reaches the circle, they are in sync. But once the train starts around the circle, that is no longer true.
By the fact that the two rear sync clocks are always at the same position, so their synchronization is frame independent (they both have the same worldlines). The rear and front clocks are not always at the same position, so their synchronization is frame dependent.
  • #43
In the track frame, the clocks are not synchronized because they were never properly synchronized. Instead, they were systematically de-synchronized.
  • #44
No, that's not at all clear. You specified that the train clocks start out synchronized in the frame in which they are all at rest while the train is on the straight track. You cannot specify that and also have the clocks synchronized in the track frame. It's not possible.
  • #45
Do you not see that the last car (Homer) and the first car (Romer) have just performed the classic "twin paradox"?? In the (inertial) frame of Homer, Romer just made a high speed voyage with return.
  • #46
There isn't one while Homer is moving around the circle. That motion is non-inertial.
  • #47
Shouldn't Romer return to the same place he started his voyage? In the frame of Homer he made his space voyage plus a voyage from the front to the back of the train.
  • #48
No, they haven't. They didn't start out co-located.
  • #49
By whom?
By you. You synchronised the clocks in the frame where the trains were initially at rest. Thus they do not show the same time in the track frame.
Come on! In the frame where the train is initially at rest, the clocks do not start out in the same position but end up in the same position. One of them must have moved and they were initially at rest.
The track is not a circle in this frame. Nor is the speed of the train constant. And for the synchronisation to remain the clock must remain at its initial constant speed - zero in this case.
  • #50
OK Romer walked to the front of the train...
  • #51
I thought Homer had just gotten to the circle.
  • #52
But that would lead to his clock being out of sync with the front-of-train clock.
I agree the situation has similarities to the twin paradox, but there are key differences too.
  • #53
Don't blame me for that! That is what the Relativity Theory requires.
  • #54
I was positing that all re-locations on the train were after the speed-up but prior to circular motion. The twin analogy assumes synchronization after the speed-up...perhaps I misread the OP intent.
  • #55
It seems like you have. None of what you say looks anything like the scenario we are discussing.
  • #56
And relativity theory says that, given your statement that the train clocks are initially synchronized in the rest frame of the train while it is on the straight track, when the front and rear clocks meet after the front clock has gone around the circle once, the two clocks do not show the same reading. So if you are accepting what relativity theory requires, then you have to accept that.
I am closing the thread because the correct answer and analysis have been given and there is no point in going around in circles.
  • Haha
  • · Replies 32 ·
  • · Replies 35 ·
  • · Replies 59 ·
  • · Replies 67 ·
  • · Replies 34 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 58 ·
