Is It Possible to Invert a Homotopy?
  • Thread starter Thread starter Ben2
    Function
Inverting a homotopy raises questions about the existence of an inverse function, particularly in the context of deformation retracts, which are defined as continuous projection maps. The discussion highlights that while the parameterization of the homotopy can be reversed, issues may arise in contractible spaces where a contraction to a point prevents inversion. The concept of homotopy is established as an equivalence relation, implying that if one space is homotopic to another, the reverse is also true. Additionally, the transitivity of homotopy is noted, stemming from the property that compositions of homotopic maps remain homotopic. Overall, the conversation emphasizes the complexities involved in inverting homotopies and the foundational principles that govern these relationships.
Ben2
From Hatcher, "Algebraic Topology" p. 3 line 32: "...[T]hree graphs [two circles connected with a line segment, a horizontal figure 8 and an ellipse bisected by a vertical line segment] are all homotopy equivalent since they are deformation retracts of the same space..."
##F(x,t) = f_t(x)##, fg\cong\\mathbb{1}##, ##X\congY##, where the author's "congruence" sign has an additional line segment
For F: X x I-->Y, defined by F(x,t) = y, next define G: Y x I-->X by G(y,u) = x. Then for t = u, we have
F[G(y,t),t] = F{G[F(x,t),t]}, which will ideally be ##\mathbb{1}##. Given Hatcher's definitions pp. 2-3, to me it's not clear how to "invert" a homotopy without an inverse function--let alone how to "invert" a deformation retract. The latter seems to be a set of continuous projection maps. Thanks again for all feedback!
Please wrap your Latex for easier viewing.
Well, if your parameter on ##I## goes from ##0## to ##1##, your inverse would go from ##1## to ##0##, for one.
There may be issues for some contractible spaces, by cardinality alone, i.e., if you contract to a point, you won't be able to invert. Otherwise, " Homotopic" is an equivalence relationship, so that if X is homotopic to Y, then Y is homotopic to X.
Thanks very much.
I agree with WWGD that the point is simply that a deformation retract is a homotopy equivalence, so the issue is that the latter is an equivalence relation (hence symmetric and transitive).
Maybe Hatcher, Cor.0.21, p.16 will be helpful.
Actually, transitivity seems to follow directly from the fact that compositions of homotopic maps are also homotopic., e.g. as on p.2 of these notes:
https://web.northeastern.edu/suciu/U565/U565sp10-homotopy.pdf
Thanks to all for the references.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
