Is it safe to drink lab ethanol?
In summary, it is very dangerous to try and brew your own alcohol at home, and you may risk death if you do.
bjon-07
84
I have been thinking about order 100% ethonal(^^OH) from a chemical supply on line. I know that i need to get undenatured/pure ethanol.
What other kinds of contaiments way be present in ethanol (i.e. methanol?). Should i dilute it, I have had strong alchol before (151 proof).
I know enough to no let me or any of my friends drink enough to get alchol posioning. Thanks for your time.
Chemistry news on Phys.org
Please don't drink reagent grade ethanol...I can't see that any good can come from that.
The primary impurity is methanol. If methanol concentration in your blood gets high, you will first suffer from nausea, vomiting and mild nervous damage including impaired vision. Consumption of about 10 ml of methanol will make you permanently blind. About 25 ml usually kills you.
Even, pure ethanol, being lipid soluble, affect the normal working of membrane proteins by messing with cell membranes. Consuming any reasonable quantity of pure ethanol can cause acute ethanol poisoning. Acute ethanol poisoning may present with symptoms ranging from slurred speech, ataxia and incoordination to coma, potentially resulting in respiratory depression and death. At blood alcohol concentrations of greater than 250 mg% (250 mg% = 250 mg/dl = 2.5 g/L = 0.250%), the patient is usually at risk of coma.
There is a reason why they don't sell lab grade ethanol to the general public.
You should never drink lab grade ethanol. There are two main reasons one of which is technical and the other is so-called administrative...
Technical is, you cannot have %100 grade ethanol to use in the lab. The major impurity methanol exhibits a azeotrope with the ethanol that is impossible to separate.
So-called-administrative is that the commercially availible ethanol is denaturised with methanol. This is about taxes. Drinkable ethanol is taxes at the highest ratio (or very high; I am not sure about the rates). When it is denaturised, then this tax is decreased and it can be used as lab grade.
If you really want to drink, then I recommend you to learn the fermantation of grapes to make "homemade" wine. Fermented alcohol will absolutely be much more safer ;) and making homemade drink is a nice hobby :)
Also technical grade ethanol contained pyridine as additional denaturizing agent in the past, in order not to be drunk (and as Mertas said, for tax-related purposes), but this treatment is not used much I think.
Home fermented alcohol might not be necessary safer if the proper sanitation and other steps are not done carefully. Brewing beer at home is one of my hobby. You get inexpensive alcohol (50 cents to 1 dollard a bottle, and that Canadian money) at a reasonnable quality, better than most commercial breweries but not as good as some artisanal or micro-breweries. I also had to use the knowledge I acquire in my microbio degree.
Here's my question. Why? Why would you want to do such a thing?
Beleive it or not one of the chemlab attendant was charged for drinking lab grade alcohol. Funny thing is they say he had been doing it for a long time until the teacher noticed that alcohol simply vanished. i read that u need 98 to 99% pure alcohol to drink. There could be an addition of methanol, pyridine,acetone and even formaline and some aldehydes.
It is very dangerous to try and brew ur own alcohol at home as more than 50 people have died recently as the result of home made poisonous alcohol in my country. :cry:
I can be safe to brew your own alcoho at home but you have to follow strict guideline in order to have quality materials. I know people that have been brewing beer, wine and mead at home for over 20 years. However, I personnaly would not encourage people to try to recreate hard liquor because these process require a good knowledge of distillation and a good training in chemistry.
Thanks for the warning
I wasn't sure about the impurities. What if I were distill the ethanol out of vodka, or buy undenatured ethanol. I will be preforming distillation next week in lab. Thanks for your advice.
Why don't you just put 20 dollars down on a bottle of everclear and see how you handle that? 190 proof. I doubt it'll be too fun though after you feel the burn.
bjon-07 said:
I have been thinking about order 100% ethonal(^^OH) from a chemical supply on line. I know that i need to get undenatured/pure ethanol...
If it is only ethanol it is very good... I did Limoncello with that, but be careful that nobody has mixed with other sumstances!
I thought that the principle impurity in lab grade absolute ethanol was benzene. Trust me, you don't want to drink any benzene, no matter how small the amount.
BTW, you'll never be able to get 100% ethanol by simple distillation. You have to use azeotropic additives, like benzene.
Related to Is it safe to drink lab ethanol?
1. Is lab ethanol safe to drink?
No, lab ethanol is not safe to drink. It is a highly concentrated form of ethanol, also known as ethyl alcohol, which can be toxic if ingested.
2. What are the potential dangers of drinking lab ethanol?
Drinking lab ethanol can lead to serious health consequences, including damage to the liver, kidneys, and nervous system. It can also cause dizziness, nausea, and vomiting.
3. Can the effects of drinking lab ethanol be reversed?
In most cases, the effects of drinking lab ethanol can be reversed if the person receives immediate medical attention. However, prolonged or excessive consumption can lead to permanent damage to the body.
4. How is lab ethanol different from drinking alcohol?
Lab ethanol is much more concentrated than typical alcoholic beverages, with a purity level of 95% or higher. It is also not subject to the same regulations and quality control measures as drinking alcohol, making it more dangerous to consume.
5. Are there any safe uses for lab ethanol other than drinking?
Yes, lab ethanol is commonly used as a solvent in scientific experiments and in the production of various products such as perfumes, medicines, and cleaning agents. However, it should never be consumed as a beverage.
  • Chemistry
  • Electrical Engineering
  • Biology and Chemistry Homework Help
  • Materials and Chemical Engineering
10K
  • Chemistry
11K
