Is mass the source of spacetime?
  • Level: Undergrad
  • Thread starter Thread starter Angelika10
    Mass Source Spacetime
68 replies · 5K views
Ibix said:
A paper was recently posted here based on the idea that if one accounted for gravitomagnetic effects dark matter was not needed.
Note, though, that this is not a case of an asymptotically flat model being claimed to be less accurate than a model that is not asymptotically flat. It is a case of two asymptotically flat models, one claimed to be more accurate than the other. So asymptotic flatness itself is not the issue.
How do we know that galaxies are asymptotically flat? Sounds like a circle: we assume them to be asymptotically flat and so we suppose them to behave in a certain way.
Is there a hint/evidence that galaxies are asymptotically flat? Because at the weak field limit, the velocities are constant (independent of r) in most galaxies - could that just come from them not being asymptotically flat?
And is asymptotically flat the same as the free fall condition?
We don't. No real system is exactly asymptotically flat, because there is always more stuff in the universe outside of the system. A truly asymptotically flat system would be alone in the universe, with nothing outside it.
We use models that are asymptotically flat as reasonable approximations. That's all they are; reasonable approximations. Nobody is claiming that real systems like galaxies are actually asymptotically flat; as above, we know that's not exactly true.
No. There are free-fall geodesic worldlines in any spacetime, whether it is asymptotically flat or not.
A note: you marked this thread as "A" level, indicating a graduate level knowledge of the subject matter. The questions you are asking don't indicate that you actually have that level of knowledge. How much background do you have in GR?
"Note, though, that this is not a case of an asymptotically flat model being claimed to be less accurate than a model that is not asymptotically flat. It is a case of two asymptotically flat models, one claimed to be more accurate than the other. So asymptotic flatness itself is not the issue."
Could you explain this, please? If both models are asymptotically flat, which one is the one that claimed to be more accurate than the other? The solar system is more accurate?
No. Asymptotically flat means that all the components of the Riemann tensor tend to zero as you go to infinite distance.
An isolated galaxy in an otherwise empty spacetime would be expected to produce an asymptotically flat spacetime: seen from a distance it is indistinguishable from a point mass, so its spacetime must look like Schwarzschild or Kerr at great distances. You could solve the field equations explicitly (numerically) if you wanted to check.
We live in an FLRW universe that is not asymptotically flat.
One particular researcher claims that a model including gravitomagnetic effects correctly predicts galactic rotation curves without needing dark matter where a simple Newtonian model does not. This has nothing to do with our solar system and nothing to do with asymptotic flatness - both models being proposed are at the galactic scale and asymptotically flat.
I was merely noting that you are not the only person wondering if a full GR model of the galaxy would explain away dark matter. As I said, I don't think very many prople are convinced at the moment.
The two models in question are both models of a galaxy (a generic galaxy, not our particular galaxy), not of the solar system. One includes gravitomagnetic effects, the other doesn't. Roughly speaking, one is based on Kerr spacetime, the other on Schwarzschild spacetime. Both of those spacetimes are asymptotically flat.
What is the reason that the stress-energy tensor curves the space-time?
The Ricci - tensor represents a volume gain and is on the left side of the field equations, on the right side is the stress-energy tensor as a source. So, stress-energy-tensor causes a volume gain. All objects in the universe are moving in a gravitational field. Having said this, how can we assume that there is something like flat spacetime? (Of cause, there is no because of the expanding universe, but leaving aside this, we assume there would be flat space without matter, don't we?)
Leaving aside this expanding universe-things, is the asymptotically flat space time kind of a background field (background spacetime) of everything in the standardmodel?
My background in GR is (I have to admit) not so deep, only some lectures on youtube and a textbook. So as I learn it by myself there might be huge gaps in my knowledge.
The Einstein Field Equation.
The Ricci tensor is not on the LHS of the field equations; the Einstein tensor is. The Einstein tensor is not exactly "volume gain"; but even leaving that aside, what the LHS of the EFE represents is not just "volume gain" but "volume gain or loss". For normal matter with "attractive gravity", the EFE predicts volume loss, not gain. (More precisely, the volume of a small ball of test particles will decrease.)
This paper by Baez and Bunn gives a good basic treatment:
https://arxiv.org/abs/gr-qc/0103044
We assume local flatness as an approximation that is useful for certain purposes. Nobody claims that spacetime in our actual universe is actually flat anywhere; of course it isn't, since there is matter present in the universe.
No. There are vacuum solutions of the EFE that are not flat.
No.
There is another heuristic argument which we haven't yet mentioned, that gives a justification for using an asymptotically flat model for an isolated system like a solar system or a galaxy. It is based on the shell theorem, which says that if we have a region of spacetime surrounded by a spherically symmetric distribution of stress-energy, the spherically symmetric distribution outside the region has no effect on the spacetime geometry inside. For the case of perfectly empty space inside the region, this means the spacetime in the empty region is flat. For the case of an isolated system inside the region, this means the spacetime in the region can be well approximated as asymptotically flat.
Of course the above premise is not exactly true in our universe either; our solar system is not surrounded by an exactly spherically symmetric distribution of matter, nor is a galaxy. But it is true to a good enough approximation to make asymptotically flat models of isolated systems useful.
I am changing the thread level to "I" based on this.
Ah, ok. Do one of you know if somebody has tried to just calculate a metric out of the constant velocity curves? Would it make sense? I'm just thinking that there, in the really-measured weak field limit, the real metric would show itself best. If the cause for the constant velocities is a metric and not dark matter.
It would be one which is not asymptotically flat (instead, the space-time itself would vanish in the infinity, this is highly speculative, but that's why I was asking whether "energy stress tensor is the source of spacetime", not spacetime curvature, could be true. And we are in an asymptotically flat regime only in the solar system.)
What do you mean by "constant velocity curves"?
There's a very good simplified non robust (8 step) derivation of the EFE on YouTube from Stanford from memory. Wheeler said "mass tells space how to bend and space tells mass how to move" (from memory). Basically my understanding is- Einstein asked the question "what if distortion in space time was equal to energy" and this produced the EFE.
EFE introduces some obscure mathematics such as Christoffel symbols- largely you can understand the essentials without them.
I guess the derivation of EFE is only the start of GR.
Some of the questions Angelika is asking seem to be on the edge of physics- things that physicists are struggling with- that no one knows the answer to- the question about what is the fundamental reality of "our" universe. The approach that seem to me to have the most potential is cellular automa- the question is how to build complex physical laws from simple ones that are perhaps created randomly by chance. Lee Smolin and Leonard Susskind have had interesting discussion on related things.
Thank you for the paper! I will have a look on it! Hm... volume loss... I have to check this. Was sure until now that it's a volume gain...
PeterDonis said:
...It is based on the shell theorem, which says that if we have a region of spacetime surrounded by a spherically symmetric distribution of stress-energy, the spherically symmetric distribution outside the region has no effect on the spacetime geometry inside. ...
Has the shell theorem an analogy in electromagnetic fields? If I assume a spherically symmetric distribution of current density tensor, surrounding a region - is there NO field inside?
The velocity of the stars at the edges of many galaxies appears to be independent of the radius r. The reason for the dark matter assumption.
The theorem in electromagnetism is that the electric field inside a hollow conductor with no charge-current density inside must be zero. This is not quite analogous to the shell theorem for gravity, although it has some similarities.
Dark Matter is an attempt to explain why Galaxies appear to have more mass than the light in the Galaxy indicates.
Dark Energy is another thing- and appears to be relate to the expansion of the universe- some explanations involve exotic matter (negative mass and energy) from memory.
Ah, ok, you are talking about galaxy rotation curves. See further comments below.
None of this is correct. Most of it does not even make sense. Spacetime can't "vanish in the infinity". It makes no sense to say the cause for galaxy rotation curves is "the metric", because the metric itself depends on the distribution of stress-energy. "Dark matter" is just a way of describing the fact that the distribution of stress-energy that astronomers have to assume to account for galaxy rotation curves does not match the distribution of visible matter--there must be additional matter that is not visible. That's why the only alternatives to the dark matter hypothesis involve modifying GR itself--modifying the physical law that links the distribution of stress-energy with the motion of matter.
Finally, it is not correct that "we are in any asymptotically flat regime only in the solar system". I have already explained why in several previous posts in this thread.
Newton perfectly fits for the solar system, but not for whole galaxies. Of course it can be dark matter. But to gain alternative approaches, one could ask: What is the difference between the solar system and the whole galaxy? One big difference I find is that the solar system surrounds the galaxy-center, which possesses a much bigger mass then itself. The galaxy is not moving so fast around a bigger mass.
What follows from the movement of the solar system around the galaxy center?
  • Skeptical
This is not correct. Newtonian gravity with an appropriate mass distribution can fit galaxy rotation curves just fine. Newtonian gravity is not limited to point masses with an inverse square gravitational force.
The mass distribution; the solar system is well approximated by a small number of point masses interacting with an inverse square force. The galaxy as a whole is not; it is better approximated by a continuous mass distribution with a density that varies with position. (Strictly speaking, one could try to model a galaxy as a large number of interacting point masses, but this is computationally intractable because the number of point masses required would be so large--a hundred billion or more.)
Yes, it is. Our galaxy is part of the Local Group, which in turn is part of a larger galaxy cluster, which in turn is part of a supercluster.
Um, the fact that the galaxy is composed of a large gravitating mass?
I'm not sure what you're trying to say here.
Angelika10 said:
they explain that introducing new fields to the EFE and introducing unknown particles is equivalent.
That is basically correct, but it doesn't mean what you think it means. See below.
Angelika10 said:
Therefore, modifying GR is not an alternative to dark matter, its conceptually the same.
Wrong. Modifying GR means modifying the EFE itself. Dark matter just means modifying the stress-energy distribution, not the EFE.
PeterDonis said:
Yes, the EM field can be interpreted as a curvature in an internal, abstract "space". But that is not the same as saying that the EM field is curved. It's the internal abstract space that is curved (in this interpretation).
Yes, but mathematically it's the same concept, namely gauge invariance. GR can also be understood as a gauge theory. The global symmetry gauged is the Poincare group, i.e., the symmetry group of Minkowski space, and that's why in this case the connection, pseudo-metric, curvature etc. refer to the spacetime geometry and not to an "internal abstract space" (a fiber bundle).
Angelika10 said:
And the Galaxy center? We're moving with 220km/s around the galactic center, in comparison to 30 km/s Earth around the sun.
Therefore, the field of the galactic center is big at our place!
But, since we're moving in free fall (with the solar system), I would suppose we do not measure any derivation from the flat space in the solar system.
Angelika10 said- "Therefore, the field of the galactic center is big at our place!"- Newton's 1st Law (of linear motion)- Speed is not dependent on force. In this case the motion is rotational motion w= v/r. Centripetal Force = mv^2/r and this is proportional (equal) to the field strength. Though the masses are the same the radii are different. The Earth is 150 M km from the Sun but much further from the Galactic Core (27,000 ly- 1 ly = 10 T km= 10x 10^12 km). So the greater the radius the smaller the Centripetal Force.
In fact if the field due to the Galactic core was greater than the Sun I suspect that the Galactic tidal forces would tear apart the Solar System.
I could be wrong... this is just a classical analysis.
You could probably argue that spacetime is approximately flat on the scale of the Solar System.
No you couldn't - the planets wouldn't orbit. You could argue that the contribution to the total curvature from masses outside the system is negligible on the solar system spatial scale and thousand year timescale.
Yes sorry that's what I meant. Thanks Ibix for the correction.
Also Murray Gell- Mann has a TED Talk on why physics is beautiful at different scales because it's similar.
Don’t think so... if two gravitating bodies produce the same field strength at a given point, the tidal effects are weaker for the larger and more distant one.
(No GR needed for this calculation, the Newtonian approximation is fine).
ok, they write, that a volume of a small ball of testparticles will decrease in time. And that's the basic meaning of "gravity attracts".
My question is another: If I the mass is increased, will the volume increase or decrease because of the additional mass?
... can the metric tensor help? diag(B, -A, -r², -r²sin(theta))
