Is metalworking in college a physically demanding task?
  • Thread starter Thread starter siddharth
51 replies · 6K views · last reply
Homework Helper
In my college, I have a workshop on metalworking in the first semester which involves obtaining a cube out of a Mild Steel cylindrical rod.
First, I have to file (using a 14 inch steel file) the upper and lower surfaces of the rod to level. Next, I have to mark a square on one face of the cylinder and then using a hacksaw, I have to cut off three sides. The fourth side must be chiselled using a hammer and a chisel.
The major problem I have is in chiselling off the fourth side. To me, this looks like an impossible task. After 3 hours of chiselling ( a mild steel rod), I have progressed very little and even hurt my finger with a misplaced blow.
So, does any College in other countries have tasks which require a lot of physical effort? Or is it mechanised where most of it is performed with the help of automated machines?
you could always cheat... Hacksaw it off, but leave a extra space, and then chisel it down the few more milimeters. If you do it well it'll be impossible to tell.
ok if you where ever to do this in the real world then you would use machines(normally), but they are showing you things which you need to know how to do, ie
file a block correctly (probably using engineers blue)
saw a straight line (not as easy as it sounds)
how to use a chisel. etc etc
when i started engineering for the first two weeks i cut round bar with a hacksaw, believe me i have no probs in cutting metal to follow a scribed line and even without one.
lmao and its not going to be the last time you do this. ;) make sure the chisel doesn't have a mushroomed head.
I believe some German training programs use this approach.
The objective is to teach the student to appreciate the difficulties associated with machining a material.
What kind of chisel? I hope it is hardened.
The German Government did offer technical assistance in setting up my college. So I guess that's where this came from. I do "appreciate" the difficulties now!
I'm using a cold chisel.
Wow! And I was thinking of lathes and milling machines!
What are the to lances you need to hold?
You project sounded fine till you said chisel! That is a bit extreme.
I once watched a documentary of an old Native American making arrows by hand. His comment "Precision does not know time"
If you want precision work you have to be patient, filing to a line will teach you this.
Chiseling even mild steel can only teach frustration. I would recommend a good sharp chisel , see if you can get a chip running?
Good Luck
I believe that the old guy meant 'tolerances'. One must allow for his rheumatism and failing eyesight when reading his posts.:-p
If he uses the same terminology that I do, a 'chip' would be a strip of metal that peels off as you chisel under it, sort of like peeling an apple.
opps! sorry about that my vision is not all that sharp right now. That should read ,,,,tolerances...
I initially misspelled it, then assumed that my spell checker had fixed it... Unfortunately it was still wrong.
When cutting metal with a machine tool (lathe for instance) the thin strip of metal being cut off often forms a long very thin strip which usually curls into a long helix. This is referred to as the "chip" .
A dull chisel will simply deform the steel it will not remove any material. To actually remove material with a chisel you will need to cut into the metal. Try clamping your "cube to be" into your vise (I hope you have a vise!) with say .5mm above the plane of the vise jaws. Now attack that edge with your chisel, if it is sharp enough you may be able to get under a bit of the steel. Hammer away.
I do not envy you your task!
You are exactly correct... even to the cause!
I guess all it takes is another blind old geezer to understand me!
:smile:
In my case it's arthritis, not rheumatism. The vision thing is irritating for sure. I have to wear my glasses for the monitor here at work, and have to have them off for the one at home.
don't want to correct you, but why not?
Integral said:
When cutting metal with a machine tool (lathe for instance) the thin strip of metal being cut off often forms a long very thin strip which usually curls into a long helix. This is referred to as the "chip" ...!
this is swarf :)
dmail said:
this is swarf :)
I thought swarf was that little blue dude from B.C.:confused:
this is swarf :)
Interesting, I have not heard that term. Could it be regional?
I didn't pursue that link too deeply, but it appears that 'swarf' is fine-grained particles as opposed to the ribbon-like stuff that we call 'chips'.
Your link seems to be referring to something different from the chip, which is scrap, not the desired product.
In this link http://woodworking.about.com/od/glossaries/g/swarf.htm" is the term for the results of a grinding process, yet again something different from the chip produced by a lathe. Though this time it is used to refer to the waste product of grinding.
I could see where it could be generalized to any waste product. Is this common terminology where you machine?
I worked in machine shops here in San Diego for ten years. If you called chips swarf no one would know what the heck you were talking about.
No, that's smurf. Different.
I went to shop school here in the states about 20 years ago, and we never had to do any major work by hand like this. You would never encounter a work situation where something like this would have to be done. Squaring up parts, especially a special single part, would be done on the mill. All the dimensions would be rough cut with the cut-off saw. The hack saw is only used for small, quick cuts. You would never be required to take off a large amount of material with a hack saw. As for chisels: I never saw anyone use one for any metal work in ten years; not in school or in real work situations. That's like something from the 1850's. I don't think it's ever done anymore, except by people who are going to machine flats on large cast parts: I believe the hard outer skin is sometimes removed by hand with chisels. That's not precision work, though.
Most machine shop work nowadays is done on CNC machines: Computer Numerical Control, and if you ask me the most important thing for a young person learning shop to shoot for would be learning how to program a print into the CNC. That job makes more money. Set up and operation of the CNC, which involves choosing and installing the end mills or drill bits, or lathe cutters, and running trials, adjusting the settings till the parts are in tolerance, involves knowing how to make changes to the program, but it's a lot more "hands on" than the programmer job. Once the set up guy is done, the actual running of the parts might be turned over to a machine operator who is less skilled, and whose main job is to put the parts in and take them out, and to keep an eye on critical tolerances, and watch for tool wear.
A manual machinist sets up and operates only non-CNC machines. This is the kind of work I did. Sometimes we cut and squared parts up for the CNC, and other times we did second operations to them after the CNC was done. Sometimes we did whole runs of parts that were never sent to the CNCs. The boss made the decisions about which operations were better done by which method.
Integral said:
... which is scrap, not the desired product.
this is correct
nice link pitty its talking about woodwork lmao.
i machined on lathes and mills both cnc and manual for different companies for about 10 years and have never heard it called anything else, infact it was even in my city and guilds exam. i thought it was called the same no matter of the place, but maybe it is a british engineering term.?
It must be British. I haven't ever heard chips called "swarf". Haven't ever seen it in books for that matter.
Me neither, like I said WAY up thread... Regional. What region are you from? Guilds imply somewhere Euorpe, I do not know of anywhere in the US that uses that term either.
That's an excellent suggestion. Till now, I have just been hammering different parts trying to get pieces of metal flying out. I have 12 hours of worktime left to get the cube.
The diameter of the cylinder was 45mm and the hieght was 35.7mm. I filed the cylinder to 32mm (±.01mm). Then, the marking was done with a vernier hieght gauge. The side of the cube must be 30mm, which means I must file once again after chiselling around 6.5mm of the fourth side.
I don't know anything about metalworking, but cutting steel with a chisel sounds REALLY HARD!
I thought I'd cut steel most ways that were possible...and I've never heard of, nor would I care to try to cut steel with a chisel. Honestly, I just can't see it working ! :confused:
I am wondering if this is a lesson to demonstrate the need for machine tools? Seems like an exercise if frustration and a waste of time. I would not spend to much time in the endeavor.
Gokul, Did you not have do the same thing when you were at IIT-M? In fact, my instructor was telling me that my batch is lucky as we have to chisel only 1 side while the previous batches had to chisel 2 sides.
This is exactly how they used to work metal in metal shops back before shapers and milling machines: chisels and files, but it became pretty much obsolete with the introduction of the metal lathe. You can square things up on a lathe if that's all you have.
