Is My Method for Calculating Pressure Difference in a Venturi Meter Correct?
1 reply · 6K views · last reply
Gorz
Water flows through a venturi meter, with an inlet diameter of 25cm and a throat diameter of 15cm. The pressure difference is measured using a manometer, which displaces the mercury by 12mm on the throat side.
Bernoulli's
Mass continuity
P=rho.g.h
Handwritten working for a venturi meter problem: a sketch of a pipe narrowing with flow arrows, then diameters 0.25 m and 0.15 m, static pressure from a manometer (ΔP = 13600 × 9.81 × 0.012 = 1600.992 N/m²), Bernoulli's equation and continuity giving V2 = 2.778 V1.
Handwritten working on lined paper: 2.778V1^2 - V1^2 = 2(1600 x 0.012), then 6.717284V1^2 = 3.2, V1 = sqrt(3.2/6.717284), V1 = 0.69 m s^-1, mass flow in = rho A V = 1000 x (0.25^2 pi / 4) x 0.69 = 33.87 kg/s.
Is this correct? I have no answers available as its from a past paper. My exam is tommorow and I would just like to clarify that the method I have used to find the pressure difference is correct.
Thanks.
No one able to help with this?
My exam is tommorow morning and I wouldn't mind some closure on my quiery.
