Is my proof valid for this inequality problem?
  • Thread starter Thread starter r0bHadz
    Inequality Proof
11 replies · 3K views · last reply
r0bHadz
Prove: if 0<a<b then a^(1/n) < b^(1/n)
I've already proved a^n < b^n in another problem. So I have
Assume a^n < b^n => [itex]\sqrt[n^2] a^n < \sqrt[n^2] b^n[/itex] => a^(1/n) < b^(1/n)
I don't really see a proof here? How do you know you're allowed to take the ##n^2## root while preserving the inequality?
What about dividing both sides by ##a## or (##a^\frac{1}{n}##) and using the fact that nth roots are non-negative? I.e. comparing ##1 \lt \frac{b}{a}##
Then you have something greater than one vs one. Should be easier to work with.
edit: my suggestion would be ##c:=\frac{b}{a}## where ##1 \lt c## but assume for a contradiction that you have ##c^\frac{1}{n} \leq 1## and see what happens
edit 2: if you want to use your existing setup, consider setting ##x : =a^\frac{1}{n}## and ##y : =b^\frac{1}{n}##. Now you know that ##0\lt a \lt b##. You have two cases to consider-- suppose ##x \lt y## what happens when you use your results about raising to the nth power? You also need to consider the other side of the coin: what happens if ##y \leq x##? One case is consistent with desired outcome, but that isn't enough... you need to show that the 'opposite' case raises a contradiction and hence can't be true.
What exactly did you prove? That if ##0 < a < b## then ##a^n < b^n##? For what ##n##? Just positive integers? Did you prove the converse, that ##a^n < b^n \implies a < b##? I'm guessing not, since that's what you're trying to prove here (in effect).
But then I don't understand your first step. How can you take the n-th root of both sides and then just declare it's true, since that's what you're trying to prove?
Personally, I might appeal to use of a logarithm, first establishing that the log function (with any base) is monotonically strictly increasing.
Maybe you can also use the fact that ##x^{1/n}## is differentiable to see when it is increasing.
As others have pointed out, your use of a ##\sqrt[n^2]{\cdot}## inequality is really just the use of a ##(\cdot)^{1/n^2}## inequality, which is what you are trying to prove.
If I were doing it I would look for a proof by contradiction, using all the results available so far.
How about proving a more general lemma:
If ##f## from A onto B is strictly monotone increasing then its inverse, ##f^{-1}## from B onto A exists and is strictly monotone increasing.
A proof by contradiction seems easier to me.
Anyways, guys I'm confused when it comes to writing proofs.
So in a previous proof I showed that, if a<b then a^n < b^n for positive n>1
I want to start this proof off as follows:
If 0<a<b, we know a^n < b^n from previous results
we also know a<a^n for n>1**
I put stars because it seems to me like I am just making an assumption there. Would the proof be valid if I said:
we also know a<a^n for n>1 because any number x times more than 1 of itself will always be bigger than x
or do I need to prove that as well?
This conclusion is not true in general. If 0 < a < 1, then a > an for n > 1. For example, if a = 1/2, a2 = 1/4
However, if a > 1, then it is true that ##a < a^n##.
I see. Do I have to prove the case of a<a^n for a>1, a=1, and for a>a^n for 1>a>0? or can I just state "assuming this is true" so I don't have to prove everything
No, I don't think that stating "assuming this is true" will fly. You are given only that 0 < a < b, so you can't come along and assume that a is somehow also larger than 1. Depending on how you go about doing your proof, you might have to make a couple of cases: one for the interval (0, 1] and another for the interval (1, ∞).
I don't see where/how you would need this. It seems all you need, if I understood correctly is whether a>b => a^k>b^k.
hmm it seems you are right. It looks like there are a lot of ways to do this proof and I was getting too caught up in finding which is the easiest but it seems like proof by contradiction is the easiest way? Does my following proof look correct?:
I am asked to prove: if 0<a<b then a^(1/n) < b^(1/n)
I am proving by contradiction so my proposition: if 0<a<b then a(1/n) ≥b(1/n)
Let a= x^n, b=y^n
we have x^n < y^n from the proposition
Since I have proved if a<b => a^n < b^n in a previous result, I know the converse a^n < b^n => a<b is true
so from x^n < y^n => x < y
since x = a^(1/n) and y = b^(1/n), there is a contradiction
