Is my work correct? (Two students running on a track)
  • Thread starter Thread starter bekishe004
    Relative velocity
16 replies · 2K views · last reply
bekishe004
I am not sure if my working out is correct because I have 2 values
d=vt
Two students run around a 400m sport field. A goes anticlockwise (i.e., 1-2-3-4-1) while Bruns clockwise (i.e., 1-4-3-2-1). Students A and B can run 400 m in 75.0 s and 65.0 s,respectively.
Diagram of a 400 m oval track with straight sides of 100 m marked on top and bottom and semicircular ends of 100 m marked on each side, corners labelled 1 to 4 and an arrow labelled B/A near corner 1.
Students A and B should meet at some point of the run. Where do they meet? Assume the cross-over position is P. What is their relative velocity at position P.
My working out:
Lets first find the relative velocity, which going to be 12
t=d/v
400/12 = 33.33... seconds
d = 5.33 * 33.33 = 177.67m
d= 6.67 * 33.33 = 222.32m
Now, whats confusing me is that I have two values and I am not sure what to do with them.
Any help will be appreciated :)
bekishe004 said:
I hope this time and I haven't violated any rules.
I don't think so. How do you know that the relative velocity is "12"? 12 what? What are 5.33 and 6.67 and how did you get them?
Suppose you cut the track at point 1 and you straighten it out to get a straight 400-m track. The runners start at each end going towards each other. Do you see where this is going?
Sure,
Student A v=d/t= 400/75=5.33m/s
Student B v=d/t=400/65=6.15m/s
It appears I made a mistake, its not 6.67 but 6.15m/s my bad
"Suppose you cut the track at point 1 and you straighten it out to get a straight 400-m track. The runners start at each end going towards each other. Do you see where this is going?"
Not really sorry
bekishe004 said:
Not really sorry
In the oval track, the runners start and meet at point P such that the sum of their distances from their respective starting points is 400 m.
In the straight track, the runners start and meet at point P such that the sum of their distances from their respective starting points is 400 m.
If you can find P in the straight track case, you have found point P in the oval track case.
Now do you see?
Ohhh
Now do you see?
Now do you see?
With my new values and understanding,
this what I am getting
5.33t+6.15t=400
11.48x=400
x=400/11.48
400/11.48 = 34.84s
5.33*34.84 = 185.70
6.15*34.84 = 214.27
sum of two these values gives 400m
I still kinda confused where I go from here
5.33t+6.15t=400
11.48x=400
x=400/11.48
400/11.48 = 34.84s
5.33*34.84 = 185.70
6.15*34.84 = 214.27
I don't think I am wrong because when Student A travels to 214m thats where Student B who has travelled 185 m.
I want to thank everyone who has helped me or trying too.
I did pretty well in chemistry and precalc but I dunno why physics is kicking my butt
5.33t+6.15t=400
11.48x=400
x=400/11.48
400/11.48 = 34.84s
5.33*34.84 = 185.70
6.15*34.84 = 214.27
Answer the question. Where is point P?
Student B is faster than student A.
Therefore, when B completes 400 m, he will be at point 1 again, but student A has not reached point 1 yet (he may be moving between points 4 and 1).
The meeting time must be the same for A and B and its value should be between 65 and 75 seconds.
You could create a distance versus time diagram for both students in order to visualize the relative movements more clearly.
I am unsure
but am I close?
I have tried that it didnt help me out
Graph of two nearly straight lines from the origin, a red line above a blue line, both rising across axes labelled 0 to 40 horizontally and 0 to 400 vertically.
haruspex said:
Your graph is as though they go the same direction around. Try reversing one.
Can you help me with that please?
I know that y=6.15x
and y=5.33x
I am so confused
Graphing calculator plot of two straight lines: red line y = 6.15x from the origin rising steeply, and blue line y = -(5.33x) + 400 starting at 400 and falling, crossing near x = 35, y = 215.
This might be it
I apologise for being slow
Again, thank you to everyone for helping me
